Old 11-30-2008, 12:24 PM   #1
seeknay2000
seeknay2000's Avatar
Drives: 1978 Z28, 1987 Suburb
Lowering the camaro - what's going to happen?
I'm thinking of lowering the camaro - not sure, maybe 1-1.5". I like the lower look, I think it's real bad-ass, just my opinion. My question is how does lowering a car effect the suspension/performance/handling? Is it a good idea or not? How should I lower it?
I don't like the idea of having "bags" on the car but it is a possibility so I can raise it when I need to. I live in Philly (anybody who's been there knows of the potholes - the streets are almost like off-road streets). My main concern is I want to lower it without spending a lot of money, but I also don't want it to negativley affect the performance or handling. For me this car is performance 1st, looks 2nd.
Thanks for you help!
seeknay2000 is offline   Reply With Quote
Old 11-30-2008, 12:27 PM   #2
blackZbandit
blackZbandit's Avatar
Drives: BLACK ON BLACK 2012 CAMARO SS
Originally Posted by seeknay2000 View Post
I'm thinking of lowering the camaro - not sure, maybe 2-3". I like the lower look, I think it's real bad-ass, just my opinion. My question is how does lowering a car effect the suspension/performance/handling? Is it a good idea or not? How should I lower it?
The car is already pretty low, much lower in person than pictures show. At 3" your clearance is going to be complete ass... scraped ass that is!
BLACK CAR + FLAT BLACK STRIPES + BLACK WHEELS = BLK PW3R!!
****Thanks to Silver Streak for the pic I used to make this sig****
blackZbandit is offline   Reply With Quote
Old 11-30-2008, 01:21 PM   #3
TRIXXTERR
TRIXXTERR's Avatar
Drives: 96 Z28(sold)
True.. I Was @ INDY I was Shocked at How Low These Sit From The Factory. I Doubt You Will Want To lower it Once You Get it..
Plus With those HUGE Rims/Rubber you dont have a lot of room to play with if i remember right..
Remember- "It ain't ready 'til it's ready!" Just because we show it to you early, doesn’t mean it’s ready.
TRIXXTERR is offline   Reply With Quote
Old 11-30-2008, 03:44 PM   #4
CamaroSpike23
Truth Enforcer
CamaroSpike23's Avatar
2-3" ? do you want it to set on the ground? this isnt a 67 impala now....
I piss excellence
and fart awesomeness
Old 11-30-2008, 04:02 PM   #5
seeknay2000
Not on the ground, maybe a little above. lol. I honestly have no idea - If blackzbandit is right and it is really low then I won't lower it. I just can't imagine Camaro making it really low off the production line. I'll have to wait and see, mabye only 1.5 inches, maybe nothing at all. Not really sure yet!
Old 11-30-2008, 04:37 PM   #6
haulass350
haulass350's Avatar
Drives: 97 silverado
most of the kits are .5 inchs to maybe 1.5inch at the most, with a full kit your get rid of alot of the body roll from the factory suspension, and will be able to corner alot flatter and quicker, steering response should feel quicker too. although you sacrifice the ride quality somewhat it will still be good depending on how firm you set it up but you wont like hiting potholes or speedbumps with it.
this is a different car but heres the only example i can give you, my friend has a infiniti G35(stock suspension) and took it to a autox course instead of his normal car a 240sx(all aftermarket suspension), either way the g35 had so much roll in it the front bumper was scrubbing on the hard corners. but it rides so smooth with normal driving. his 240sx however drives almost perfectly flat around every corner but damn near beats my brains out on the interstate or any road that isnt perfect.
haulass350 is offline   Reply With Quote
Old 11-30-2008, 04:41 PM   #7
nUcLeArEnVoY
Oldbie that nobody knows
nUcLeArEnVoY's Avatar
Drives: 2011 1SS/RS M6
3 inches will give your undercarriage a very intimate relationship with the asphalt that you could do without. I am going to lower mine, but only in the front. It still won't be by much considering how low they are straight off the conveyor belt.
nUcLeArEnVoY is offline   Reply With Quote
Old 11-30-2008, 04:42 PM   #8
Lex
Lex's Avatar
Drives: 1989 Jaguar XJS w/L98 swap
Lowering the Camaro... Whats going to happen
ummm... its going to get lower and the ride quality is going to get worse
"I thought you didn't give cute girls speeding tickets?"
"I don't..... here's your ticket..."
2 wrongs don't make a right... but 3 lefts do!
Lex is offline   Reply With Quote
Old 11-30-2008, 04:59 PM   #9
TheClassicCarKid
TheClassicCarKid's Avatar
Drives: V45
All of the stang guys in one thread..wow..lol
TheClassicCarKid is offline   Reply With Quote
Old 11-30-2008, 05:39 PM   #10
CamaroSpike23
Truth Enforcer
if not done correctly.
I piss excellence
Old 11-30-2008, 05:44 PM   #11
blackZbandit
After seeing it in person I decided I'll probably drop mine either 1", or .5" in the back and 1" - 1.5" (which is realy pushing it) in the front. 2" - 3"?
If you lower it an inch your handling will definitely improve, but as others have said the ride will be a bit harsher - the shorter your springs the stiffer they have to be. Or you could use drop spindles but that's $$.
Old 11-30-2008, 05:53 PM   #12
seeknay2000
Please note that I edited my original post to 1-1.5" - I now realize that's more reasonable. I haven't seen it in person, only pictures. Some of the pics I've seen it looks like you can lower it 2" and be okay. Thanks for all the imput - do you guys have any recommendations for actually lowering it? How much I lower it really isn't a concern yet b/c when I see the car in person I'll know exactly how much to lower it!
Old 12-01-2008, 02:53 PM   #13
blackZbandit
The guys from Pedder's that post on here have a lowering kit in the works, a Stage 1 kit I beleive () but that may be more than what you're looking to spend. You can always go with some Eibach lowering springs which are a relatively cheap and quality fix, or like I suggested before, drop spindles (if they're made for the Camaro) but they also = $$.
If I got anything wrong or left anything out anybody feel free to correct me... still learning myself!
Old 12-01-2008, 03:10 PM   #14
GTAHVIT
Blessed
GTAHVIT's Avatar
Drives: 2013 Sonic RS MT
^you pretty much got it right.
Camaro Laws ChevyNut Off-topic Discussions 107 11-09-2016 06:40 PM
The new Camaro V6 might be the best model of the entire lineup! Mr. Wyndham 5th Gen Camaro SS LS LT General Discussions 101 12-21-2010 08:48 PM
"2010 Camaro: Just a heartbeat away" - Scripps News 11/13/08 Rallyman6 5th Gen Camaro SS LS LT General Discussions 10 11-16-2008 02:55 PM
