Jason 98 TA
Old 08-18-2010, 09:38 PM   #1
6bloodychunks
6bloodychunks's Avatar
Drives: 2011 2SS/RS SGM
is there a screw on shift knob adapter for the push on shifter?
i found out that the factory option hurst shifter in my 2011 2SS is going to have the push on knob.
is there an adapter that will let me use a screw on knob on the push on stick?
thanks...
---2011 synergy green 2SS/RS---
09/27/2010 - (3800)
10/01/2010 - (4200)
10/09/2010 - (4800) Vehicle on final destination route
10/19/2010 - (5000) delivered to dealer
11/19/2010 - (6000) delivered to customer
6bloodychunks is offline   Reply With Quote
Old 08-19-2010, 01:40 PM   #2
6bloodychunks
anybody make one of these?
09/27/2010 - (3800)
10/01/2010 - (4200)
Old 08-19-2010, 04:52 PM   #3
CamaroCowboy
CamaroCowboy's Avatar
Drives: 2013 Chevy Truck
Wait. So they are installing the Hurst but with a push on shifter knob upper stick? I would just buy a different upper stick from Hurst so you can use whatever knob you want.
You can always check on www.flameball.com
they have a nice selection of knobs and they have a place for you to tell them what type of car you have so they make the right knob.
CamaroCowboy is offline   Reply With Quote
Old 08-19-2010, 05:00 PM   #4
cdn2usa
cdn2usa's Avatar
Drives: 2010 2SS
thanks...
I believe there would be. My Hurst shifter kit came with two shifters. One to retain the stock knob and one that was more retro, chrome with a white ball.
Both were available on the Hurst web site. If they used the same mounting on your OEM 2011 Hurst shifter (which I assume they would) then the chrome one would fit.
Aqua Blue 2SS c/w factory white strips, MT.
Installed options;Tinted Windows, De-badged,
Hurst Shifter,CAI,Vmax throttle body, Kooks LT Headers, High Flow Cats,Borla Touring Axle Back, ADM Scoop, Washwater relocation,Diablo Predator(c/w Ted's Magic), Custom start defeat switch, painted engine cover, shark fin & bow ties, ABL lighting, Rear Camera.
cdn2usa is offline   Reply With Quote
Old 08-19-2010, 05:45 PM   #5
6bloodychunks
so at the most i would have to buy the upper stick right?
i have the coolest shift knob lined up and i gotta be able to use it.
09/27/2010 - (3800)
10/01/2010 - (4200)
Old 08-19-2010, 08:33 PM   #6
Kenji
Kenji's Avatar
Drives: 2SS/RS M6 SW
The Hurst aftermarket shifter is a two-piece design (that can be separated) and can accept just about any Hurst upper stick.
The factory GM/Hurst shifter is a one piece isolated design (much like the current OEM stick) and cannot be separated. You CANNOT bolt a Hurst aftermarket upper stick to it.
Kenji is offline   Reply With Quote
Old 08-19-2010, 09:00 PM   #7
6bloodychunks
i put this in my other thread about the factory hurst shifter, but ill put it here too.
the shift knob im getting isnt drilled in any way, i will have to put my own hole in it.
would there be a way to cut a hole that would fit on the factory hurst shifter?
thanks for all your help
09/27/2010 - (3800)
10/01/2010 - (4200)
Old 08-20-2010, 12:57 PM   #8
6bloodychunks
could i just drill a hole that would fit and use epoxy or something similar to set the knob on it?
09/27/2010 - (3800)
10/01/2010 - (4200)
Old 08-20-2010, 01:18 PM   #9
Kenji
Kenji's Avatar
Not knowing the size, shape, material of your knob... it's hard to say if just drilling a hole (Ø14mm BTW) into your knob and using epoxy would work. My educated guess would be - no. Overtime, it probably would not hold-up. The stock knob has molded in keys (front, back and top) to prevent rotation with a locking feature at the bottom.
Your best bet would be to take out the shifter and have the top portion threaded. And then drill and tap your knob.
The other option would be to use a set screw type collar (if your knob has that provision) knob.
Old 08-20-2010, 01:22 PM   #10
eggydoo
Drives: 2010 Camaro SS
i agree with above statement, would not hold up.
in the past, I bought a generic momo knob and it used a super screw to secure itself, and it didnt hold up. Found an adapter to make it into a screw.
eggydoo is offline   Reply With Quote
Old 08-20-2010, 05:55 PM   #11
1977and2010
Tampa Gulf Coast Family
1977and2010's Avatar
Drives: 1977 Z28, 2SSRS 2010 M6
I bought a pistolgrip handle from Barton that came with a screw on adapterfor the stock shaft. It also works on the mgw shifter I have now. Cool combo between the two.
1977and2010 is offline   Reply With Quote
Old 08-20-2010, 06:01 PM   #12
6bloodychunks
i have been looking ,but i cant seem to find an adapter for the push on knob so that i can use a screw-on knob.
if someone knows where i could find one i would really appreciate a link
09/27/2010 - (3800)
10/01/2010 - (4200)
Old 08-21-2010, 01:52 AM   #13
v6sonoma
v6sonoma's Avatar
Drives: 2010 SS RS
MGW makes an adapter for stock press on.
http://www.mgwltd.com/camaro-5th_generation.shtml
9/26/09 Took delivery!
Old 08-21-2010, 04:02 PM   #14
6bloodychunks
which one on that page is it?
all i see are knobs.
09/27/2010 - (3800)
10/01/2010 - (4200)
DIY - Removing the Shift Knob Brownhornitt Camaro DIY & HOW-TO instructions & discussions 10 06-22-2015 02:45 PM
TAG's 2010 THRSS #2 TAG UR IT Member Car Journals 3129 08-14-2014 09:29 AM
$26.95 Skip Shift FREE w/ purchase of Hurst Billet/Plus 2 Shifter Apex Paul Transmission / Driveline 9 04-23-2010 07:08 PM
Power door Locks how to turn off JCSSCamaro Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 6 02-23-2010 06:42 PM
