Old 08-19-2010, 04:54 AM   #1
michael's maro
RAM'S CAMARO
michael's maro's Avatar
Drives: 2010 camaro ss
Reccomendation on Road coarse/Autocross Tires
I am looking for the best set-up for road coarse racing and autocross racing.
I have a full set of factory 20x9 rims (4 corners) I am looking for the best brands and tire size for front and rear. I would like to to hear from form members and vendors about there opinion's and that has been tested on the track.... Thanks
My current mods on my car are
Front and rear sways
Coil-overs
3.73 gears
Maggie charger
michael's maro is offline   Reply With Quote
Old 08-19-2010, 07:12 AM   #2
mickss
mickss's Avatar
Drives: 2010 Camaro LS-M6 67 Chevelle Wgn
Here is some information you may find useful. Also as a side note for those considering tires larger than recommended for a specified rim width please read the last two paragraphs.
http://www.aimtire.com/typ_category.asp?ObjectID=6637
"WHAT TIRE SHOULD I BUY?"
Description: We're always asked this basic question. First and formost there are different tire types that best fit your purpose.
The TOYO Proxes RA-1 continues to be the very best all around tire for driving to and from a high performance driving or track day event.
The TOYO RA-1 is unsurpassed in it's ability to 'heat cycle' better than any other tire on the planet.
At full or near full tread depth it provides excellent grip and long life for a "R" compound tire. And at a shaved tread depth of 4/32nds is has proven to be a very quick and predictable tire. So much so it was chosen to be the SPEC MIATA Spec tire for 2006 to 2009.
Also, the all NEW R-888 is molded at 6/32nds is an instant hit with track day and HPDE competitors as well as the various spec tire series now using the R-888 tire. This tire has the renown TOYO capacity for resistance to the dreaded 'heat cycling' which other tire brands cannot seem to duplicate! The R-888 is the designated replacement for the RA-1 which has been in the USA since 1992! The R-888 is the new tire used by the Speedvision World Challenge Touring and GT series! Thus proving it's ability to perform under extremely harsh conditions.
Plus at full tread depth it provides excellent grip in on a wet track.
All around the Proxes new R-888's and the famous RA-1 are a great buy for your money.
DIFFERENCES between the R-888 and the RA-1? The R-888 has a stiffer sidewall which provides greater grip under hard braking as well as giving you more mid-corner grip.
The HANKOOK VENTUS Z-214 is the new kid on the block but has established itself as a true champion. The Hankook Z214 continues set record race wins as well as track records in SCCA Improved Touring, NASA classes.
With a molded 4/32nd TWO GROOVE tread patten the Hankook Z-214 is a ringer for the look of the HOOSIER and R-6 and A-6 but has proven to be much quicker and more durable.
Competitors have documented over 25 heat cycles on the Hankook Z214 without the tire slowing!
Additionally Hankook has the best contingency program in the entire USA.
All in all there is only one downside and that is the Hankook Z214 cannot be driven on the street although it is considered a DOT tire as is the Hoosier R-6 and A-6 by sanctioning bodies
Competitors are reporting setting new records at tracks, autocrosses and hill climbs across the nation with the HANKOOK VENTUS Z-214 competition tire.
As a competition tire we DO NOT RECOMMEND this tire be driven on the street. It is a true competition tire just as the Hoosier R-6 and AVON TECH R tires.
Hankook offers the Z214 in 2 compounds depending upon the size. The c7 is the softer compound providing instantly quick laps with little or no warmup. Excellent for Autocross or for someone wishing to set a new qualifying record!
The c5 compound is considered the work horse of the Hankook line but don't think for a minute it is slow! The C-5 compound provides all around amazingly quick times lap after lap on road courses while showing very little wear
. The Hankook Z-214 provides nearly the wear of the TOYO while performing like the Hoosier.
PLUS Hankook offers the best contingency program of any manufacturer covering most club events, endurance events and rally events.
And speaking of RALLY TIRES take a look at the full line of HANKOOK Ventus R201, R202, R203, R203 and R204 Rally Tires. Currently the Hankook Ventus Rally Tires are setting the competition on edge by providing superior rally performance at a very low cost!
HOOSIER R-6 road race, A-6 autocross tire: The industry standard for years. The new R-6, A-6 line incorporates years of track data into the new improved design. Still the #1 choice for SCCA open competition with a huge assortment of sizes to fit virtually any application.
A special note for all: So many times customers will attempt to put a tire that is wider than is recommended for a specified rim width.
This WILL ABSOLUTELY affect the performance of the tire causing an increase in tire wear, inconsistant and poor performance.
DON'T DO IT!
The best fitment for a tire's performance is for the rim width to be equal to the tread width of the tire. Using rims that are narrower or wider than the tire manufactures recommendations is an extremely poor decision and very unprofessional.
mickss is offline   Reply With Quote
Old 08-20-2010, 04:02 AM   #3
michael's maro
RAM'S CAMARO
Thanks for the info
Old 08-20-2010, 10:52 AM   #4
Jay J
Prince of Zamunda
Drives: XW30
Mick's last statement I agree 100% with...Many people I know are like oh I want to put 275's on a 8.5" wide wheel or 9" wide wheel..They fail to realize that actually causes more flex in the sidewall and reduces the contact patch.
Jay J is offline   Reply With Quote
Old 08-22-2010, 04:18 AM   #5
michael's maro
RAM'S CAMARO
bump
Old 08-22-2010, 02:09 PM   #6
ccdan
Drives: Real Nice
if you are wanting the fastest wheel/ tire package for the track, it will be
315 30 18 front and 335 30 18 rear on 18x11 front and 18x12 rears.
john
ccdan is offline   Reply With Quote
Old 08-22-2010, 03:03 PM   #7
John M.
Drives: 2010 Camaro
Send a message via AIM to John M.
CCDAN has a video of a STOCK SS with that wheel/tire package that is insane. He did my set-up on 20's
John M. is offline   Reply With Quote
Old 08-26-2010, 04:10 AM   #8
michael's maro
RAM'S CAMARO
bump
Old 08-26-2010, 04:14 AM   #9
MSG'
MSG''s Avatar
Drives: 2010 1SS Camaro
mike check out www.scr-scca.com its the south carolina chapter for auto crossing from sports car clubs of america, a nationwide autocross club. Actually they are having two events in september, one at the track you told me about, and one in north charleston, which i am going too.
MSG' is offline   Reply With Quote
Old 09-03-2010, 05:27 AM   #10
michael's maro
RAM'S CAMARO
Anyone else?????
Old 09-03-2010, 10:02 AM   #11
flht99b
flht99b's Avatar
Drives: 2010 Camaro 2SS/RS RJT
Bump
RJT 2SS/RS, AAM 3.70's, MTI Sway Bars, Shifter & SS brake lines, ZLI calipers & rotors, BMR Trailing & Toe Arms, full rear cradle & diff bushings, Pedders XA's, Camber/Toe eccentrics, Radius arm inserts, ZL1 Brembo Brake pads, GTO clutch reservoir, LS9 cam, Comp Cam valve springs, Melling 10296 oil pump, CR 5 timing chain, LS2 damper, CAI Cold Air Induction, ARH LT headers w/HF cats, GMPP touring axle back, Elite Engineering Catch Can, Forgeline 20x9.5 & 20x11 DS3 wheels w/Vredestein 275/40/20 & 315/35/20 tires, '11 Convertible spoiler, Lloyd "SS" Floor Mats, GM Camaro Trunk Mat
flht99b is offline   Reply With Quote
Old 09-03-2010, 10:37 AM   #12
600hp-lpe
Drives: 2010
john
John at CCW built them for my car. They take a little bit of work to make them fit but give you the bigest footprint from a tire you can get on the 2010 Camaro, and help to lower it as well. I have Hoosier A6 tires mounted on C2K's for the track. They stick out of the fenderwell about 1 inch front and rear. My car is lowered about an inch in the suspension as well.
600hp-lpe is offline   Reply With Quote
Old 09-04-2010, 09:59 AM   #13
Erik@Torq
Erik@Torq's Avatar
Drives: '10 SS + '04 Z16 Z06 S/C
Send a message via MSN to Erik@Torq
For stock 9" rims the stickiest option are the Toyo R888. I have them on the same set-up, 4 x 9" rear rims and traction is unbelievable. Of course a square 10" set-up would be optimum, but spending that kind of money may not always be an option.
Here is a video from last weekends track event running the above set-up for the first time.
Erik@Torq is offline   Reply With Quote
Old 09-04-2010, 04:09 PM   #14
michael's maro
RAM'S CAMARO
Thanks Erik for the info, Great video....I just ran Roebling Road last saturday, I had a blast, stock 21" tires are doing so well 3 track events so far...
Drivers Can't Rely on Summer and All-Season Tires, or Electronics for Control on Snow KILLER74Z28 General Automotive + Other Cars Discussion 25 07-22-2011 10:51 AM
Winter Tires - Reminder about TPMS KJS Wheels and Tires Talk Sponsored by The Tire Rack 3 11-22-2009 07:39 PM
Pedders Suspension Benchmark Track Testing and New Jersey Track Day Info@PeddersUSA.com USA - NY / NJ / PA 35 10-26-2009 05:20 PM
RS Package question Richochet83 5th Gen Camaro SS LS LT General Discussions 52 04-13-2009 01:37 PM
18, 19, & 20" replacement tires ... dougmac Wheels and Tires Talk Sponsored by The Tire Rack 3 03-29-2009 05:27 PM
