Emblempros
Old 08-19-2010, 09:03 PM   #1
5th_GEN_SS
Junkie
5th_GEN_SS's Avatar
Drives: SIM 2SS/RS M6
Reverse lights went out?!
just noticed my back up lights went out.. had to be within the last day or so..
they will not turn on while in reverse or when unlocking the car as they should
the car is a m-6
do the lights have thier own fuse?
any ideas?
"Letty" Murdered out 2013 Camaro 1LE. (Old car SIM 2010 2SS/RS)
5th_GEN_SS is offline   Reply With Quote
Old 08-19-2010, 09:04 PM   #2
PoorMansCamaro
PoorMansCamaro's Avatar
Drives: Really Slow
i'm sure you're still under warranty. let the dealer figure it out.
Old 08-19-2010, 09:15 PM   #3
5th_GEN_SS
Junkie
5th_GEN_SS's Avatar
hmmmm that sucks. i dont wanna go back lol
i didnt see anything about its own fuse in the manual, does any one know which one it shares?
Old 08-19-2010, 09:16 PM   #4
skipj3
Go Gators Baby!!!
skipj3's Avatar
Drives: '11 2SS M6
this is what i would do also
Side Note: Love the Avatar...GO FISH!!!!!!!
Oscar Wilde - “When I was young, I thought that money was the most important thing in life; now that I am old, I know it is."
The Department of Redundancy Department
skipj3 is offline   Reply With Quote
Old 08-19-2010, 09:18 PM   #5
brantley847
v It bites.
brantley847's Avatar
Drives: 2011 IBM 2SS/RS
I had an issue with this previously with a different vehicle (not the camaro) so it may not apply...but a simple fuse replacement fixed the problem if it was both lenses.
2011 2SS/RS
Performance: 439 RWHP A6: 226/236 Comp Cam, Kooks 1-7/8, CAInc, Borla S type, FTI Converter, Vmax TB, Rx Catch Can, Trans cooler, SLP 160 termo, Melling high volume, Eibach Springs/Sways 1" drop, Whiteline complete bushing kit.
Appearance:Smoked side markers and black bowties. Blk / Blue Carbon Fiber interior trim.
Next in order: F14s, 3.70 gears, DSS Axles, End links/Toe rods/trailing arms, Ported heads, S/C.
1100 7/02 Ordered
3800 8/09 Order produced
4200 8/13 Shipped
6000 8/24 HOME!
brantley847 is offline   Reply With Quote
Old 08-19-2010, 09:20 PM   #6
rydahog
rydahog's Avatar
Drives: camaro ss
check fuse box. look for brake lite, tail lights..something along those lines...pull one at a time look for element to be sort of black/brn in color and cut in center..good luck should be easy fix..
rydahog is offline   Reply With Quote
Old 08-19-2010, 09:23 PM   #7
5th_GEN_SS
Junkie
5th_GEN_SS's Avatar
all the other lights work just my reverse are out.. going to start pulling fuses, it doesnt say anything about which fuse it may be in the manual
Old 08-19-2010, 09:27 PM   #8
PoorMansCamaro
Drives: Really Slow
which is odd. it should tell you what every fuse is for. if you find it, let us know!
Old 08-19-2010, 09:37 PM   #9
5th_GEN_SS
Junkie
5th_GEN_SS's Avatar
think i pulled every fuse... didnt see anything that looked bad
Old 08-19-2010, 09:38 PM   #10
5th_GEN_SS
Junkie
5th_GEN_SS's Avatar
is there a seperate ground for the lights? mayeb a wire is lose? i donno... :-(
Old 08-19-2010, 09:43 PM   #11
rydahog
rydahog's Avatar
Drives: camaro ss
fuse help
5th gen maybe this will help??
Engine Compartment Fuse Block Diagram of 2010 Chevy Camaro :
2010 chevy camaro engine compartment fuse block diagram
J-Case Fuses Usage 6 Wiper 12 Starter 22 Brake Vacuum Pump 25 Power Windows Rear 26 Power Windows Front 27 Rear Defog 41 Cooling fan high 42 Front heater, ventilation, and air conditioning 43 Antilock Brake System Pump 44 Cooling Fan Low Mini Fuses Usage 1 Air conditioning compressor clutch 2 Transmission control module 5 Engine control module main 7 Pre-catalytic converter oxygen sensor 8 Post-catalytic converter oxygen sensor 9 Fuel injectors-even 10 Fuel injedtors-odd 11 Cooling fan relay 14 Manifold air flow/chassis control 15 Ignition 16 Run/crank IP 17 Sensing diagnostic module/ignition 18 Run/Crank Body 19 Transmission control module/ignition 20 Engine control module/ignition 31 Outside rear view mirror 32 Canister Vent Solenoid 33 Body Control Module #6 34 Sunroof 35 Front heated seats 38 Washer pump front 40 Antilock brake system valves 46 HID headlamp – left front 47 HID headlamp – right front 50 Fog lamps 51 Horn 52 Spare 55 High beam headlamp – right front 56 High beam headlamp – left front 61 Heated mirror Mini Relays Usage K26 Powertrain K50 Run/Crank K55 Rear Defrog K612 Cooling fan high K614 Cooling fan control K61 Starter K69 Wiper control K613 Cooling fan low K617 Air conditioning compressor clutch K619 Wiper Speed K627 High intensity discharge headlamps K632 Brake, Vacuum Pump
Old 08-19-2010, 10:01 PM   #12
5th_GEN_SS
Junkie
5th_GEN_SS's Avatar
yea but where is the reverse?
Old 08-19-2010, 11:21 PM   #13
rydahog
rydahog's Avatar
Drives: camaro ss
ok here is the service manual.
http://www.camaro5.com/forums/attach...2&d=1248465325
thanks to camaro 5 friends.
Old 08-19-2010, 11:26 PM   #14
5th_GEN_SS
Junkie
5th_GEN_SS's Avatar
thanks but that doesnt really help, i have one...
it doesnt say anything about the back up lights that i saw
Reverse lights always on playr101 Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 24 10-11-2012 10:53 AM
FOG LIGHTS ON RS blueforza Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 17 04-17-2011 08:04 PM
got bored so i tinted my DD's tail lights and sidemarkers UnknownWarrior General Automotive + Other Cars Discussion 22 04-03-2010 06:28 PM
Remote unlock Feedback (lights) ? Kubi 5th Gen Camaro SS LS LT General Discussions 6 04-02-2010 09:23 PM
Looking for a photoshop job of reverse lights. Bentley78 Camaro Photoshops / Renderings Forum 0 04-02-2009 02:23 AM
