Emblempros
Old 08-20-2010, 12:32 AM   #1
jordan 572
jordan 572's Avatar
Drives: none
steering vibration
My cars steering wheel vibrates when i hit about 70 on up. I dont think it did this when i got it. But i started noticing it after i removed my front wheels. I but them back on the same sides too. Do i need to use a torque wrench to make them sit flat on the hub or is it something else?
jordan 572 is offline   Reply With Quote
Old 08-20-2010, 12:37 AM   #2
oldfriend
Drives: Fiat 500 E
Red face 2SS
You may have lost one of the weights from one of the wheels ,you should take HER to a tire shop and balance the two of them then see [drive ] at the same speed just to double check !
Old 08-20-2010, 12:39 AM   #3
CAMARU
CAMARU's Avatar
Drives: 2011 2SS/RS/CGM/6M/Black stripes
YES you need a torque wrench. It is well worth the investment. Try to get one that clicks when you reach the disired torque. Run all the lug nuts hand tight and then torque the lugs 1/3rd of the recomended torque using the star pattern. You can google the star pattern. Then torque to 2/3rds in the star pattern and then finally to full torque using the star pattern.
CAMARU is offline   Reply With Quote
Old 08-20-2010, 12:41 AM   #4
jordan 572
jordan 572's Avatar
Drives: none
what is the torque rating on the factory 20's?
Old 08-20-2010, 12:44 AM   #5
Boosted IBM
Boosted IBM's Avatar
Drives: 2010 2SS RS
130ft/lb I think.
Every Camaro I have driven steering wheel shakes from 65-80. I rent one every week and own two. I've gone through the road force balancing, dealer trips... just realize with the stock heavy 20's and heavy tires, it shakes.
Boosted IBM is offline   Reply With Quote
Old 08-20-2010, 12:48 AM   #6
jordan 572
jordan 572's Avatar
Drives: none
Originally Posted by Boosted IBM View Post
130ft/lb I think.
does anyone else experience this?
Old 08-20-2010, 12:49 AM   #7
oldfriend
Drives: Fiat 500 E
Unhappy 2SS
130ft/lb I think.
WHY should it shake , if they are balanced well does it should hold the way it should ,nice and smooth ?
Old 08-20-2010, 01:01 AM   #8
Jeremeymt
Jeremeymt's Avatar
Drives: 2016 hyper blue 2LT RS
Mine shakes too. I figure its normal but ive never driven another camaro to know? Its not bad enough to worry me though but yes i have noticed it too.
Jeremeymt is offline   Reply With Quote
Old 08-20-2010, 01:05 AM   #9
Wilder
Synergy Green <3
Wilder's Avatar
Drives: 2010 Synergy Green Camaro
You probably going to need to buy a torque wrench which is worth it
Join my group! "Young Camaro Owners"
http://www.camaro5.com/forums/album.php?albumid=4383&pictureid=93296
Wilder is offline   Reply With Quote
Old 08-20-2010, 01:23 AM   #10
John Shields
"Back in Black"
John Shields's Avatar
Drives: '10 1LT/RS Black w/Silver Stripes
It's likely to cause more damage in the future. Better get it fixed now especially under warranty. My doesn't shake in the slightest bit. I did have a tire patched and they noted 130lbs on there for the torque. So I assume that's right.
To the Jerkoff in SW Denver Driving the Black Camaro:
Quit making us look bad by driving like a tool and cutting people off (my wife included)!
John Shields is offline   Reply With Quote
Old 08-20-2010, 01:29 AM   #11
turtlezx
Drives: 2010 1lt yellow
I agree with OLDFRIEND why should it shake ??
somethings wrong if it does shake i would take it to the shop until its right . Just becuase its a camaro its normal to do this --NO WAY
turtlezx is offline   Reply With Quote
Old 08-20-2010, 01:37 AM   #12
Jeremeymt
Jeremeymt's Avatar
I got mine used so yeh I should prob check the torque then.
Old 08-20-2010, 10:36 AM   #13
stryker755
stryker755's Avatar
Drives: 2013 ZL1 Vert AGM
Mine shakes a little when I hit the brakes if I'm going over 50
Camaros Owned:
-2013 ZL1 Vert A6 Ashen Gray 700HP (Current)
-1986 Z28 Blueprint 383 Stroker 430HP (Current)
-2010 2SS/RS Silver Ice M6 TVS2300 700HP (SOLD)
-2010 2SS Aqua Blue M6 Stock (SOLD)
-1986 Sport Coupe Gray Built 355 (SOLD)
stryker755 is offline   Reply With Quote
Old 08-20-2010, 10:39 AM   #14
Slim2SS
Black Thunder
Drives: 2010 Camaro 2SS/RS
No shaking at all on mine. I have it up to 130MPH with no problems.
JRE 416 9:1 Forged Stroker Package
Edlebrock E-Force Super Charger
JRE Blower Cam package
Cooling Mist Water/Meth
3.25 blower pulley
FAST 65 lb. hr. injectors
JRE Edelbrock fuel system upgrade
GM ZR-1 Clutch
Roto Fab CAI
Kooks Headers Jet Hot Coated
Kooks High Flow Cats
3" Magnaflow Stainless Steel Exhaust
Barton Short Throw Shifter
JRE Dyno Tune
Slim2SS is offline   Reply With Quote
Vibration from 58 to 68 mph. Basenji Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 76 06-16-2013 11:56 PM
Troubleshooting help........ possible car problem....... vibration....... PQ Wheels and Tires Talk Sponsored by The Tire Rack 234 12-17-2010 05:01 PM
F/S: Custom Carbon Fiber and Leather Wrapped Steering Wheel!! SS Mike Interior Parts & Accessories 15 09-02-2010 02:45 PM
Vibration from 58-68. Basenji Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 1 06-13-2010 11:35 AM
Low frequency vibration from 58 mph-68 mph Basenji 5th Gen Camaro SS LS LT General Discussions 5 05-07-2010 12:06 AM
