Jason 98 TA
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Other Generations > 1st & 2nd Generation Camaros
Old 06-07-2007, 12:54 PM   #15
JWz28
Drives: 2012 Z28 (I'm hoping)
Sweeeet! I love a story that has a happy ending. The two of you were meant to be together.
JWz28.
JWz28 is offline   Reply With Quote
Old 06-07-2007, 03:17 PM   #16
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
Engine swaps are tough if you haven't done it before. My brother is somewhat mechanically inclined and pulled the engine out of his Toyota all by himself (WHILE IN HIGH SCHOOL) with the help of a book. He broke it down and took the damaged parts to a shop where they were rebuilt. You can do it. It just takes time and determination...
Sorry. Not trying to highjack the thread.
No, i know that...I'm "mechanically inclined", too. But, physically, how do you get the damn engine out of the car!?! Not with your bare hands I'd expect...
Old 06-07-2007, 03:33 PM   #17
JWz28
Engine Hoist. You can rent them at some local Auto Parts stores. Pull the motor and tranny in one piece. Take 'em a part, lift the motor up to an engine stand bolt 'er up and start disassembly.
JWz28.
Old 06-07-2007, 09:24 PM   #18
Mr. Wyndham
JWz28.
Gotcha...And instead of taking them apart, some people - the ones who are actually swapping the engines, just put a new one in? That clears things up - thanks!
Old 06-08-2007, 02:25 AM   #19
TAG UR IT
www.Camaro5store.com
TAG UR IT's Avatar
Drives: 2014 ZL1 #705
Yeah...but in most cases, it's a lot more than just a swap. Tranny usually has to be changed, larger radiator, and a whole mess of other beefier parts. When putting twice the power (or in some cases more) to the ground, you need to start thinking about all the suspension parts and rear end as well. But, for just swapping the engine and going larger, there will usually be a lot more than just the engine that needs changing.
Old 06-08-2007, 10:20 AM   #20
AFSNightrod
Back in Black
AFSNightrod's Avatar
Drives: 2005 Cadillac CTS-V
Send a message via AIM to AFSNightrod Send a message via Yahoo to AFSNightrod
Yeah you have to do all the supporting mods if you want your setup to last.
AFSNightrod is offline   Reply With Quote
Old 06-08-2007, 11:37 AM   #21
Mr. Wyndham
Damn...
Old 06-08-2007, 11:43 AM   #22
AFSNightrod
Back in Black
It isn't too bad. You just have to make smart investments and really research the parts you need so you don't need to do multiple installs of the same part. It will save you money in the long run.
Old 06-08-2007, 03:20 PM   #23
KILLER74Z28
MOD SQUAD
KILLER74Z28's Avatar
Drives: 2G1FT1EW9A9100666
Engine swaps are always a hassle unless you are replacing you engine with the exact same engine ie small block to small block, big block to big block. Computer controlled engines are a whole different breed because of the ECM/PCM (Computer) and wiring harnesses. GM is really good about interchangeable parts on the earlier SB and BB. I on the other hand, am running into clearance issues with the Big Block. Come to find out I have more room in my Camaro than I do the Blazer… Time and patience, that’s all it takes…
KILLER74Z28 is offline   Reply With Quote
Old 06-09-2007, 11:39 AM   #24
JWz28
When doing an engine swap you want to pull all of the accessories off of the old motor like the all the alternator, water pump, a/c condenser, intake, carb / fuel injection..etc (it's a long list).... and transfer them over to the new motor. What ever will work on the new motor or dosen't require to be upgraded..use it. As they say..if it ain't broke...
JWz28.
Old 06-09-2007, 01:43 PM   #25
Punk_rider
Punk_rider's Avatar
Drives: VW Typ 166 + Black 1LE
Originally Posted by KILLER74Z28 View Post
The engine swap is under way. Pulled the 402 Out of the Camaro and am in the process of installing it into the 72 K5 Blazer. Soon the Camaro is going to have a 500 horse 427 resting under the hood.
to me, changing the engine is changing the soul.
the car is not original anymore. not a true one anymore. I 'm against mods.
am i the only one?
Punk_rider is offline   Reply With Quote
Old 06-11-2007, 12:38 PM   #26
Camaro_Man_101
Camaro_Man_101's Avatar
Drives: dont have one
damn man thats one kick ass engine you have there if only you could put and audio file on how it sounds..... hmmmm.............
Camaro_Man_101 is offline   Reply With Quote
Old 06-11-2007, 03:54 PM   #27
Mr. Wyndham
am i the only one?
No, me too. I only approve of minor modifications..."performance enhancers" I call them - there's no replacement for displacement. Superchargers, intercoolers, intakes, cyllinder heads - you know the simple stuff.
The only reason I'd approve of a complete engine swap is if the car is so old - milage OR age, whatever, and the car couldn't go on.
Old 06-13-2007, 03:27 PM   #28
Punk_rider
Punk_rider's Avatar
agree. only when the engine's dead
New Camaro SS to get LS9 Engine? Some say maybe.. Tran Forced Induction - V8 18 05-20-2010 10:31 PM
5th Gen Camaro LS3 info from Chevy Hi-Po...READ TAG UR IT Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 295 03-07-2008 11:06 AM
Yeeha!! 2008 Corvette Gets Big Boosts of Both Power and Torque frodo General Automotive + Other Cars Discussion 24 10-02-2007 03:20 PM
LS7 Swap into V6 cheaper than factory? LSxcellent Off-topic Discussions 26 03-24-2007 12:20 PM
Making Modern Horsepower the Old-Fashioned Way KILLER74Z28 General Automotive + Other Cars Discussion 14 02-02-2007 02:50 PM
