JDP Motorsports
Old 01-09-2011, 05:11 PM   #29
buelldude
car enthusiasts
buelldude's Avatar
Drives: 2012 2SS
Mine wasn't that bad, never seen any on the floor. I just seen some on the pan when I did my oil change
<img src=http://www.camaro5.com/forums/album.php?albumid=9196&pictureid=93608 border=0 alt= />
buelldude is offline   Reply With Quote
Old 01-18-2011, 09:23 AM   #30
hoffmk2003
The Hof
hoffmk2003's Avatar
Drives: 2010 IOM Camaro 2SS/RS
I got this as well, going to get the z06 oil cooler gasket this spring.... my cars don't go to the dealer unless its something major under warrenty, I prefer to do my own wrenching.
Ken
#6 Bolt on Fast List...best ET 12.01@117 mph
http://www.streetfire.net/video/best...ro_2240734.htm
hoffmk2003 is offline   Reply With Quote
Old 01-18-2011, 12:07 PM   #31
dukefanok
dukefanok's Avatar
Drives: 2011 Camaro 2SS/RS Black on Black
Dropped my car off yesterday to have oil leak and coolant leak fixed. Oh and they are putting in new lifters too....fml. This car only has 5k on it......Ridiculous.
dukefanok is offline   Reply With Quote
Old 01-23-2011, 01:18 PM   #32
robertway
robertway's Avatar
Drives: 2012 Challenger SRT8 Auto
Ken
Any idea what the part # is for the Z06 cooler gasket?
Thanks in advance
"When the people find they can vote themselves money, that will herald the end of the republic." - Benjamin Franklin
LS3 Camshaft Swap Do-It-Yourself Instructions - 2010 LS3 gone but not forgotten!!!
robertway is offline   Reply With Quote
Old 02-01-2011, 12:19 PM   #33
hoffmk2003
The Hof
hoffmk2003's Avatar
the zo6 and the ls3 oil cooler gasket is the same part number I just checked on it.
Old 02-13-2011, 03:07 PM   #34
Inferno Orange 2SS-RS
US Army Retired
Inferno Orange 2SS-RS's Avatar
Drives: IOM 2SS-RS - A6 (L99)
Just checked mine it is leaking. Need to get it into the dealer.
SMKIN SS
Inferno Orange 2SS-RS is offline   Reply With Quote
Old 02-14-2011, 01:39 PM   #35
ffrcobra_65
there are 4 places for an oil leak.
1) Oil Cooler. If the stains or drops are in the vicinity of the cooler, highly likely, oil cooler gasket/o-ring is the issue
2) if the bottom of the oil pan, front and/or back, is coated with film of oil, the oil pan gasket is the problem
3) if there is oil droplets on the center/bottom of the bellhousing, the problem could be either the rear main seal or the rear engine cover porosity issue........or BOTH.
Old 02-16-2011, 02:56 PM   #36
hoffmk2003
The Hof
hoffmk2003's Avatar
And I have all three.........does that mean I win the prize
To hell with it I'll put oil in the engine before I'm going to tear it apart for a small drop of oil or two.
Ken
Old 02-16-2011, 03:58 PM   #37
Bonemaro
Bonemaro's Avatar
Drives: 2010 RJT 1SS M6
Send a message via AIM to Bonemaro
Mines in the shop now... oil cooler leak, trans leak, anti freeze leak. When i get her back tomorrow i'll post specifics. And to think all this when all i took it in for initially was for a nickel size red spot i noticed on the driveway.
Bonemaro is offline   Reply With Quote
Old 02-16-2011, 04:37 PM   #38
ffrcobra_65
Ken
I agree, if just a drop or two a week, not enough to take to dealer and chance them screwing up something else or getting your car back with dents or scratches that weren't there before.
But if it is something easy like the oil cooler gasket/o-ring, I would get the fixed.
A leak just doesn't go away by itself, in fact, it will get worse over time. The important thing is, get the problem documented with the dealership.
Old 02-16-2011, 10:42 PM   #39
Hebe4
Hebe4's Avatar
Drives: 2010 Black 2SS/RS M6
Ken
Nope, I have all three and the added bonus of a strut leak.
Hebe4 is offline   Reply With Quote
Old 02-17-2011, 05:24 PM   #40
Bonemaro
Bonemaro's Avatar
Got her back today
-found seal at rear of trans leaking k2163 1.40 removed driveshaft and rear yoke replaced leaking rear trans output seal
-found coolant fitting leaking from the block to cooler hose j3170 0.30 removed connector from block cleaned fitting and resealed in into block after repressure tested cooling system had no leaks
-found oil cooler leaking oil at the oil pan j0933 0.60 removed oil cooler and replaced leaking gasket from oil pan cooler engine now running to specs
...little did i know all this was happening from a small spot noticed on the driveway
Old 06-13-2011, 09:00 AM   #41
1stTimeV8r
War Damn Eagle!!
1stTimeV8r's Avatar
Drives: VR 2SS
I noticed a leak with mine yesterday...very slow leak but a leak none the less....I crawled underneath the car and found an image similar to this picture with the leak residue around the oil cooler..Would I be safe to assume that my issue is with the oil cooler gasket? And if so, any chance in h3ll my dealer would fix this knowing I'm supercharged? Is this something I could replace in my garage if my dealer won't? How hard would it be? And a dumb question, do I need to drain the oil before replacing the gasket?
Thanks,
Adam
Originally Posted by luis nunez View Post
When I did the Oil Change I notice Oil close to the filter, I cleaned the area and changed the Oil, recently I decided to take a look and notice oil again...
I read about loose srews on the oil cooler, mine where loose also so I tight them ...Have you had the seame problem? I was resolved with that..
VR 2SS RS M6
Hot Wife, 2.8 KB, LS9 Cam, SPEC 3+ clutch, KW Variant 1 Coilovers, Pfadt F/R Sways, BMR Sub-Frame Connectors, BMR Tunnel Brace, LSR Performance Tri-Ax Shifter, BMR Trailing Arms, Kooks 1 7/8" LT Headers, MagnaFlow 3" Cat-Back Exhaust, Fesler Dual Gauge Pod w/AutoMeter A/F & Boost, ShowStopper UnderHood Accessories.....Tuned by John@APF = 627RWHP/542RWTQ
1stTimeV8r is offline   Reply With Quote
Old 01-29-2012, 11:37 PM   #42
jcollins91106
jcollins91106's Avatar
Drives: 2010 2ss m6
Mines leaking!!!! I am cammed and tuned so no warranty here. Does anyone know how hard it is to replace or maybe a DIY???
2010 2ss M6, TSP 1 7/8 Long Tube headers,dual electric cutouts, 3" pipes all the way back to magnaflows. elite engineering catch can, custom painted engine cover,CAI cold air intake, apex cold air racescoop, jannety racing 470 hp kit, custom JRE hot rough idle blower cam, jannety racing dyno tuned. pfadt lowering springs, lsr short throw shifter, custom sub setup,sony 7" indash nav, interior stiching dye, 20% tint all around, HAVOC spoiler, tail light black out, chevy emblem black out, seibon BBII carbon fiber hood,Front and rear bowtie blackouts. 461 rwhp and not done yet!
jcollins91106 is offline   Reply With Quote
DIY: Camaro Oil Change adub4185 Camaro DIY & HOW-TO instructions & discussions 180 04-23-2014 07:11 PM
best synthetic oil to use hollywoodjose Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 130 01-26-2014 09:51 AM
GM's OLM & synthetic oils. duder4thgen Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 1 03-24-2010 12:37 PM
Aftermarket cooling The_Stache Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 6 01-11-2010 06:40 AM
