Old 02-11-2012, 03:56 PM   #43
crosscountry
Drives: Camaro ss 2010
I inspected mine today and found it leaks by the oil cooler and the oil pan(both minor oil leaks no drops just seaping). First I thought it was coming from the main seal but I removed the round inspection cover to discover a nice and clean inside! I don't really wan't the dealer spilting my engine and transmission apart on a car with only 13k. So I guess I will leave it like that for a while and keep and an eye t'ill it starts dripping on the ground.
crosscountry is offline   Reply With Quote
Old 02-11-2012, 05:02 PM   #44
crosscountry
After looking at the TSB for the rear cover maybe mine also has the rear engine cover porosity issue, it's pretty hard to tell which is leaking the oil pan or the rear cover. Pretty well in the same area!
Old 02-11-2012, 06:03 PM   #45
BlemsBumble
BlemsBumble's Avatar
Drives: '13 ZL1 #662; '10 SS; '99 SS
^^Could be both. I had both fixed 8 months ago, no more leaks.
BlemsBumble is offline   Reply With Quote
Old 02-26-2012, 08:40 PM   #46
Jer4251
Camaro Addict
Jer4251's Avatar
Drives: too many
do they need to drain the oil to repair any of the oil leak issues? Im just about due for an oil change and ive noticed oil in the past on my pan and lines under it. i wont bother doing an oil change if they have to do one in the process.
2013 ZL1 Vert
1990 IROC-Z Vert
1996 SS Vert #1468
1991 Z28
2014 Sierra Denali
Jer4251 is offline   Reply With Quote
Old 02-28-2012, 01:52 PM   #47
Chevrolet Customer Svc
Drives: GM Vehicles
Jer, if you haven't checked yet I can always contact your dealer to see if they would need to drain your oil for this repair. I hope this helps. Let us know how things go with your dealer.
Jeff Morris, Chevrolet Customer Service
Chevrolet Customer Svc is online now   Reply With Quote
Old 02-29-2012, 09:26 AM   #48
hoffmk2003
The Hof
hoffmk2003's Avatar
Drives: 2010 IOM Camaro 2SS/RS
Jeff,
Sounds like your from momma GM. Care to comment on this issue or how widespread it is?
Ken
PS- I might take mine in this spring afterall, it seems to be mildly accelerated this winter :(
#6 Bolt on Fast List...best ET 12.01@117 mph
http://www.streetfire.net/video/best...ro_2240734.htm
hoffmk2003 is offline   Reply With Quote
Old 02-29-2012, 01:28 PM   #49
Drives: GM Vehicles
I haven't personally seen anything on this issue as of yet but if I ever do I'll let you know as much as I can.
Old 02-29-2012, 01:39 PM   #50
Russell James
Russell James's Avatar
Drives: Camaros
My '10 had drips off the cooler and pan. First repair was ... leak test dye, cooler seals and gaskets, and 1 qt of oil.
Still leaked. Second repair was leak test dye, new oil cooler, new seals again, 1 qt of oil.
Leak then fixed, and I had bright blue oil. I then changed the oil.
So if, it's just the cooler, I'd bet they top off with a qt after the repair. If the
actual pan is leaking, would probably have to drain all the oil for that. But the cooler can make it look like there is leaks all over under there. They will need to use the dye to find the actual source of the leak.
Old 03-22-2012, 11:47 AM   #51
Ghost78
Drives: 2010 Camaro SS/RS
My 2010 SS leaked drops of oil last summer and brought in to the dealer and they replaced a gasket, noticed the leak again when I took the car out of garage storage and dealer is now replacing the oil cooler block but they have to order the part and keep the car overnight. I am really surprised they do not have these parts in stock, but I hope this fixes the problem.
If this problem continues will they still work on this under warranty even when the warranty expires ?
Ghost78 is offline   Reply With Quote
Old 03-22-2012, 06:10 PM   #52
Badger
Badger's Avatar
Drives: 2010 ABM SS #14 of 2,027
Mine goes in in the AM for this same scenario....they did an oil change and found the issue...they are leaning to the oil cooler as the source...is this new oil cooler gasket an upgrade from the OEM...or just a replacement of the same one.
"One of the ordinary modes, by which tyrants accomplish their purposes without resistance, is, by disarming the people, and making it an offense to keep arms."
-- Constitutional scholar and Supreme Court Justice Joseph Story, 1840
Badger is offline   Reply With Quote
Old 03-22-2012, 06:32 PM   #53
Jer4251
Camaro Addict
Jer4251's Avatar
Drives: too many
Mine is in right now. At first he said the rear seal was leaking. But I pointed out other leaks and the oil cooler was leaking the worst. He replaced the oil cooler and put dye through the engine. Ran it and said it was good to go. the cooler must have been spraying oil back making the rear look like it was leaking. He was ready to pull the trans out before I pointed out the oil cooler.
2013 ZL1 Vert
1990 IROC-Z Vert
1996 SS Vert #1468
1991 Z28
2014 Sierra Denali
Old 03-23-2012, 08:29 AM   #54
Russell James
Drives: Camaros
It will look just like the rear main and pan are leaking. Which they could be, but the only way to actually diagnose it correctly is - clean everything off, add dye, drive it a couple miles, then check with the blue light on where the dye is actually seeping out. And if it's the cooler, don't bother with the seals and gaskets, going to need a new cooler.
If the bill doesn't have leak detection dye on it, they have no clue how to diagnose an oil leak.
My '10 took three tries to actually get the dealer to fix it right. The 3rd attempt where the oil cooler was replaced, along with using dye, actually fixed it. A couple tries with seals and gaskets were wastes of time. Something is feckered up with the coolers.
Old 03-23-2012, 10:08 AM   #55
Drives: GM Vehicles
Ghost78, after your base bumper to bumper or powertrain warranties are over you also get a 12 month 12,000 mile warranty on replacement parts and labor when you pay for both from your dealer. If you buy the part from your dealer you get a warranty on the part and not the labor. Hopefully it doesn't come to that and your dealer can get this taken care of for you.
Old 03-23-2012, 04:57 PM   #56
ffrcobra_65
The oil cooler and any part of the drive train should be covered for 5 years or 100k miles. Am I mistaken?
DIY: Camaro Oil Change adub4185 Camaro DIY & HOW-TO instructions & discussions 180 04-23-2014 07:11 PM
best synthetic oil to use hollywoodjose Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 130 01-26-2014 09:51 AM
GM's OLM & synthetic oils. duder4thgen Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 1 03-24-2010 12:37 PM
Aftermarket cooling The_Stache Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 6 01-11-2010 06:40 AM
