Old 08-21-2010, 08:13 PM   #1
xpanda305x
Banned
Drives: Dark Knight
whining noise when steering the wheel?
what can cause this? maybe power fluid pump or fluid needed??? anyone? i its weird..
xpanda305x is offline   Reply With Quote
Old 08-21-2010, 09:26 PM   #2
Kwaz1335
The Kwaz
Drives: Black 2010 Camaro 2SS/RS
Send a message via AIM to Kwaz1335
Check you power steering fluid levels. Under your hood while looking at your motor on the right side you will see a black box thing with a logo of a steering wheel on it. If your levels are low..fill I back up and if it continues to whine...check your levels again. If they are low you have a leak in your system. If your levels are fine but your pump is still whining have your power steering pump replaced as the pump is bad.
Ordered:3/13/09
1100: 3/13/09
3300: 5/12/09
Picked up and brought home 6/26/2009
2010 Black on Black SS/RS Camaro
Silver stripe package
Ground effects package
6 Speed Manual Transmission with Hurst short throw, Magnuson Supercharger, SLP loudmouth 1 kit.
Kwaz1335 is offline   Reply With Quote
Old 08-22-2010, 01:35 AM   #3
xpanda305x
Banned
Drives: Dark Knight
^ will do first thing in the morning capt!
Old 08-22-2010, 02:17 AM   #4
nards444
nards444's Avatar
Drives: 1SS/RS Black
power steering fluid, or pump is defective
2010 1SS/RS Black, CGM stripes, polished Rims, Tinted windows, Hurst shifter
nards444 is offline   Reply With Quote
Old 08-22-2010, 04:45 PM   #5
Motorhead79
Motorhead79's Avatar
Drives: 2010 Camaro 2SS/RS
I just started hearing the same thing, my fluid was actually low. I serviced the system and it still whines. I just happened to glance down at the lower cross member in the engine bay to check the condition of the hoses and found a bad fitting, all my fluid was on the lower cross member.
Motorhead79 is offline   Reply With Quote
Old 08-22-2010, 04:47 PM   #6
KeepItGreasey
So It'll Go Down Easy
KeepItGreasey's Avatar
Drives: Camaro SS/RS
had the same problem. fluid was low. where did it go? i don't know. the dealer topped it off and told me they didn't find a leak. i'll have to give it a good look at for myself.
KeepItGreasey is offline   Reply With Quote
Old 08-22-2010, 06:26 PM   #7
Cal 20112SS
Drives: 2011 2SS/RS
Mine sounds like it's releasing air out of the wheel?? I turn it slightly and it stops.
Cal 20112SS is offline   Reply With Quote
Old 08-23-2010, 05:28 AM   #8
Big Brunsy
Drives: 2010 supercharged LS3
I had the same thing, pump had a leak in it....only the problem wasn't so much the fluid getting out (resivor was full), it was the air getting in. Trapped air in the system caused me to not have any power steering. The fix was they replaced the pump.
Big Brunsy is offline   Reply With Quote
Old 08-24-2010, 08:15 PM   #9
Peter W.
Drives: 2011 Camaro 2SS
I have the same problem. I have like a slight whisteling sound but it goes away when I turn the wheel. I brought the car in for my first oil change and addressed this issue to the dealership. They said they started an L99 on the lot and it did the same thing, they said it was normal. Are they Bullshitting me?
Peter W. is offline   Reply With Quote
Old 09-13-2010, 01:27 AM   #10
Motorhead79
I actually found the problem with mine a couple weeks ago, actually about a day after i posted my last message. Wouldn't ya know it the power steering line that runs along the bottom portion of the engine mount where the line goes from being a flex line to the steel line had burst. Not bad though but it did let go, so that day I set an Appointment with the local dealer told them the problem, they had me in the next day. (BTW the factory line was made by Yokahama) It was covered under warranty, and to top it off they replaced it with a CSM line (Used on Corvettes) I was concerned that the system was going to wine after they changed the line cause when i was low on fluid I serviced it up with DOT4 ATF Fluid (NON synthetic BTW States that in the manual) and it still whined. Well the Dealer told me that when the fluid got low it got air in the System so they bled it and all was well!
Old 05-21-2012, 01:38 PM   #11
Maker
Nice to meet you.
Maker's Avatar
Drives: '11 Black 1SS/RS
they just told me they are going to replace my entire rack
Maker is offline   Reply With Quote
Old 07-23-2012, 09:40 AM   #12
spd2612
Drives: Black SS2/RS LS3
GM is aware of this issue. I just went to dealer with my 2011 ss2 I didn't think the noise was a big issue, I went in to get 4 new tires and a alignment
I was told they would get me a car, they opened a ticket with GM and they said replace the rack.
spd2612 is offline   Reply With Quote
Old 07-23-2012, 12:13 PM   #13
Maker
Nice to meet you.
Maker's Avatar
well, are they replacing the rack with a new version of the rack? mine was replaced and now i hear the noise again. if they are replacing it with the same faulty parts, what's the point? i love this car to death, but i am not going to endure this lunancy. how many times can they fix it?
what if they put a new steering wheel in like from the '13 model? is anyone with the newer wheel design having this issue?
Old 07-23-2012, 01:01 PM   #14
spd2612
I didn't like the design of the 2012 steering wheel, did they change it again in 13 ?
GM told them to replace the rack so Im guessing its a new design. I have a 2011 ss2 rs
I love the car I was just going in to buy tires didn't know I had a issue just a slite squeak
I got 26000 miles out of the Perili tires so I am sticking with them
Leather Wrapped Steering Wheel danifox 5th Gen Camaro SS LS LT General Discussions 16 06-21-2010 10:21 PM
Question about leather wrapped steering wheel... King T Cosmetics and Lighting Modification Discussions 6 01-15-2010 08:19 PM
steering wheel controls mod AdnanHfuda Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 1 01-11-2010 10:00 AM
steering wheel issue Fotowns Finest 4th Generation Camaros 2 11-03-2009 04:18 AM
QC missed something-- AC Compressor making a whining noise under engine load Kyle.Gilmour Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 12 10-09-2009 11:42 PM
