BeckyD @ James Martin Chevy
Old 08-21-2010, 09:44 PM   #1
autobotaz
Drives: Black 2010 Camaro LS
Bolt size for V6 M6 shifter?
Can anyone tell me the size of the bolts that hold in the shifter underneath the car. They are the two inside the rubber boot that go into the shifter housing. Found somewhere thay might be a 6mm x 1 (pitch)but I dont know the length and I don't want to guess. Need to find them at maybe an Ace Hardware.
Thanks
autobotaz is offline   Reply With Quote
Old 08-22-2010, 12:00 AM   #2
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
Drives: To many to list
I have them right here there 20mm long will try to get you the size and pitch
Old 08-22-2010, 09:53 AM   #3
autobotaz
Hey thanks for the response. Was using my torque wrench and one of my bolts stripped. Only had it at 7 foot lbs as instructions said and the head twisted right off. If you can confirm the size and pitch for me that would be great. Pretty sure they are M6 x 1 (pitch). Had to order new shifter mount for $130. Might be able to drill it out but...Gonna be an expensive bolt.
Gut told me to back off and just snug up w/o the torque wrench but I didn't listen.
Live and learn right.
Where in AZ are you?
Old 08-22-2010, 10:21 AM   #4
2SSRS@Gen5diy
Lake havasu city, Did you do your torque to In" lbs or foot lbs, Any way Ace opens in 1 Hr will post after that
Old 08-22-2010, 10:39 AM   #5
autobotaz
foot lbs as instructions said. Might just have to take a cruise up there and buy you lunch! Thanks for helping me out.
Old 08-22-2010, 12:36 PM   #6
2SSRS@Gen5diy
So yes the bolts are 6mm 1 pitch got back from Ace and that is the nut that went on the bolts. Good luck.
Old 08-22-2010, 01:33 PM   #7
autobotaz
Thank you my friend. If we take a drive up your way some saturday I'll PM you and take you to lunch. I owe you one.
TAG's 2010 THRSS #2 TAG UR IT Member Car Journals 3129 08-14-2014 10:29 AM
Hurst Billet/Plus 2 Shifter $319.95, get Skip Shift Eliminator FREE! Apex Motorsports Transmission / Driveline 22 06-15-2010 10:55 AM
Shifter Party at MTI Racing MTI Racing Kevin Transmission / Driveline 12 03-01-2010 09:17 AM
Thread size of shifter knob Badger V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 3 01-24-2009 09:57 PM
Thread Size on Hurst Shifter? r0cketdr Cosmetics and Lighting Modification Discussions 0 11-18-2008 02:29 PM
