Gen5DIY
Old 08-21-2010, 10:43 PM   #1
ITGuy11
Burning up tires
ITGuy11's Avatar
Drives: 2010 Camaro 1SS/RS
Rattle noise when engaging the clutch M6
When I engage the clutch at low speeds I get a rattle and shaking noise that seems like it is coming from the transmission when unloading the drivetrain.
Example driving 12mph in first gear, fully press the clutch and I hear and feel a rattle from the transmission. The sound is very audible from inside and outside of the car. Car has done this from day one and now has 730 miles on it. This sound is annoying and embarrassing.
Any suggestions before I contact the dealer? I don't want them to claim the noise is because of my MGW shifter. The noise was present with the stock shifter when I drove the car off of the lot.
Blower, cam, supporting mods 644RWHP 615RWTQ
My Build Thread COTW 11/19/12
Detroit 5th Gen Camaro Club
ITGuy11 is offline   Reply With Quote
Old 08-21-2010, 11:03 PM   #2
HeaterMan
HeaterMan's Avatar
Drives: 2018 PP GT
I noticed the exact same thing today and my dad heard it from outside the car and said it isnt right. my car is 100% stock, guess a trip to the dealer is in order
HeaterMan is offline   Reply With Quote
Old 08-21-2010, 11:17 PM   #3
reason
reason's Avatar
Drives: 2010 Camaro 2SS / RS
i had same problem-
crawled under the car and tapped on everything i could till i finally tracked it down.
My Front and Rear O2 sensors on the passenger side of the vehicle had started to loosen up ( just 1 or 2 threads) but was enough to give them some play.
May want to just give them a check-
reason is offline   Reply With Quote
Old 08-22-2010, 09:54 AM   #4
ITGuy11
Burning up tires
ITGuy11's Avatar
I know the O2 sensors are tight, cause I installed them in my headers. This is much more than just a little rattle sound, you can feel it. It almost feels like the transmission mount is broken, but it looks okay.
Old 08-22-2010, 01:41 PM   #5
MaxKamai
Mad Ninja Skills
MaxKamai's Avatar
Drives: 2011 Camaro SS/RS M6
It's just the inertia from the drive line. It happens on the V6 as well. Usually at low speeds (1st or reverse) when clutch pedal is depressed quickly. According to the dealer...that is standard operation on our vehicles.
MaxKamai is offline   Reply With Quote
Old 08-22-2010, 08:21 PM   #6
gtbaldini
Drives: 2010 Cyber Grey 2SS/RS LS3
Ya, I've got the same noise. Drivetrain clunk.
gtbaldini is offline   Reply With Quote
Old 08-22-2010, 08:40 PM   #7
Orange Krate
Not just any car!
Orange Krate's Avatar
Drives: Orange Krate DOB - 11/22/2010
I can't believe this noise and vibration is normal coming from a new car. I have seen cars with manual trans and higher ratio rearends cause a shimmy when releasing the clutch. But what you are describing sounds like either a dry throwout bearing or u-joint issue. I am no mechanic and certainly not an expert on Gen 5's, but what you describe doesn't sound like an acceptable situation for a new car (unless it was hammered hard doing burnouts). Even with exceptional quality control (as GM has) there can be infantile failure in a batch of parts or even a singular unit. If the dealer you visit does lip service to your problem you may have to take it to another dealer who has a good drivetrain tech (preferably one that owns a Gen 5!). I hope that sounds reasonable to the experts in Camaro5!
Simi Valley, CA
email: orangekrate2011@yahoo.com
Orange Krate is offline   Reply With Quote
Old 08-22-2010, 08:46 PM   #8
americo
americo's Avatar
Drives: IOM 2SS RS
I have 2350 Km on my car and I have no noise or rattle at any speed during up sifting or down shifting.
americo is offline   Reply With Quote
Old 08-23-2010, 02:47 AM   #9
JUISSD
JUISSD's Avatar
Drives: 2010 White/IOM 2SS/RS M6
Mine does the same exact thing. While under the car installing the shifter I didn't notice anything unusual.
2010 White/IOM Camaro 2SS/RS M6
JUISSD is offline   Reply With Quote
Old 08-23-2010, 03:27 AM   #10
v6sonoma
v6sonoma's Avatar
Drives: 2010 SS RS
Is it making a "clunk" when you lift the clutch pedal or when you depress it? If it's when you lift it it could be do to the IRS's slack when unloaded. If it's when you depress perhaps something is loose. If it doesn't happen when you drive and shift quickly it's most likely do to the slack caused by the slow speed.
9/26/09 Took delivery!
Old 08-23-2010, 06:48 AM   #11
Russell James
Russell James's Avatar
Drives: two 5ths and a 1st
normal.
Every M6 car I've owned does it, and that has been tons of cars.
The driveline has to have a little play in it. Things like the ring and pinion, gears in the trans.... cannot be bound up tight, they have to have a little backlash. When you have a load on the driveline, and then release it quickly, it can give off some clunks.
Has nothing to do with IRS, all my solid axle Gen IV's did the same thing also.
Old 08-23-2010, 08:14 AM   #12
HeaterMan
HeaterMan's Avatar
Drives: 2018 PP GT
my car only does it when depressing the clutch. i have owned many manual trans equipped cars and never heard anything like this. i could understand the noise if it were when engaging the clutch if the driveline was not preloaded
Old 08-23-2010, 08:45 AM   #13
Russell James
The title should probably say - disengaging clutch, as he says it happens when pushing the clutch in. Decelling with the clutch engaged has the engine braking load on the drivetrain. Pop the clutch in and you suddenly take all that load off the drivetrain and you hear all the clearances clank a bit. Those clearances have to be there, it's normal.
When building a trans or rear diff, you'll see a backlash/clearance spec for all those gears. If they were set up with zero backlash, it would quickly destroy itself.
Old 08-23-2010, 09:05 AM   #14
ITGuy11
Burning up tires
ITGuy11's Avatar
You are correct about the title, however I can't change it... I owned a 4th gen M6 and never had this noise when pressing in the clutch at low speeds. I don't feel that this noise/clunk is normal for a brand new car to make.
I just want some ammunition before I go to the dealer with it. I don't want them to say it is the shifter, cause it made the noise bone stock.
I want a new clutch, you too????? Sign here tjbusa V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 370 08-10-2013 03:27 AM
Clutch Rattle and Rough Engage Dukesite 5th Gen Camaro SS LS LT General Discussions 3 01-24-2010 06:15 PM
Oil Change Ramp mjlash22 Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 17 01-21-2010 10:40 PM
Heads Up - Clutch Spring noise ffrcobra_65 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 1 11-22-2009 09:04 AM
