Flowmaster Exhaust
Old 12-02-2008, 02:33 PM   #1
devildogcollier
semper fidelis
Drives: 95 z28 lt1 6-sp,73' nova 350
not sure what the deal is
my 95 6speed>..... heres the problem: once i drive it home from work and let the car sit all night it starts just fine the next morning.... now once i drive to work and turn the car off i can let it sit for a few hours but when i go to get back in the car and try to start it it takes a couple of times + some pedal pumping to get the car to start.......any ideas about what the problem is??? would it have to do with the ignition system???? help!!!!
devildogcollier is offline   Reply With Quote
Old 12-02-2008, 02:57 PM   #2
Hylton
Hylton's Avatar
Drives: fanboys and ass kissers crazy.
I had that problem with my '93 LT1 auto. It was the ignition switch at the bottom of the steering column. Car was fine when cold or not used for a while but a bitch to start if hot or recently driven.
Hylton is offline   Reply With Quote
Old 12-02-2008, 03:56 PM   #3
craigd853
Drives: 199 SS Camaro
I've had that on at least three occasions where when the fuel pump starts to go bad it will do this. Do yourself a favor and if you can hook up a fuel gauge to your fuel rail located under the hood and visually look at it while your cranking the engine. If it's below 40 psi there's your answer. Also, you say your car is hard to start after it has run a while, could also be ignition system. The next time you run the car for a while, shut it off and pull the fuse on the fuel pump and crank the engine over with a plug out and grounded against a metal object on the car. Ensure that the spark is a big blue deep spark and that your plugs and wires are in good shape. I believe on your model year that the place where the ignition system is located which is down around the harmonic balancer that there were a lot of problems with this. Good Luck
craigd853 is offline   Reply With Quote
Old 12-03-2008, 12:52 PM   #4
CamaroSpike23
Truth Enforcer
CamaroSpike23's Avatar
first off, dont pump the pedal when starting. all you are doing is flooding the motor while its trying to start adding to your problem.
is it cranking slowly or stumbling at all when starting?
check the fuel pressure with a pressure tester. there is a schrader valve on the back of the fuel rail
http://shbox.com/1/fuel_schrader_valve.jpg
it should be around 41-47 psi when you turn the key to on (not starting)
another thing to look at is your coil. when the ignition control module gets hot, they start to crap out.
the coil is located on the drivers side bolted to the head.
http://shbox.com/1/coil_loc.jpg
I piss excellence
and fart awesomeness
Old 12-05-2008, 08:53 AM   #5
devildogcollier
semper fidelis
i shall check
Old 12-05-2008, 12:28 PM   #6
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
Good luck
05 Hummer H2 SUV on OEM Air Ride
Forged 11.4:1 408 LQ4 (K1 crank & rods; Mahle pistons)/CPP LS3 CNC heads/BTR Stage IV LS3 cam/home ported L92 intake manifold/ported 90mm TB/custom Volant CAI/mid-length headers/AFE dual 3" CB/Corvette Servo/el cheapo lift/Cognito UCAs/Sphon poly adjustable TA/Sphon adjustable rear LCAs/e'fan conversion/DirtyMax radiator/Moroso catchcan/HPTuners/HID conversion/LED exterior lighting/LED interior accents/Autometer Cobalts/AEM WBPioneer AVH-5600BHS/Pioneer GM-9601/2-Pioneer TS-W310D4s/Obcon Labyrinth dual-12 box/lots of other little stuff
COMPROMISE REACHED FOR BIG 3 Moose General Automotive + Other Cars Discussion 68 11-28-2008 06:35 PM
Happy 100th GM Sierra General Automotive + Other Cars Discussion 21 09-17-2008 08:44 PM
What a deaL Cessna510 Camaro Price | Ordering | Tracking | Dealers Discussions 7 08-03-2008 02:51 AM
What's your deal breaker? LSxcellent 5th Gen Camaro SS LS LT General Discussions 103 06-24-2008 12:26 AM
GM reaches deal with UAW at strike-hit Kansas plant camaro5 General Automotive + Other Cars Discussion 3 05-21-2008 07:22 PM
