| Mechanical Maintenance: Break-in / Oil & Fluids / Servicing Discussions on mechanical maintenance and servicing of your Camaro |
Thread Tools |
#1 | ||
www.Camaro5store.com
A large group of us went to a driving school this past weekend to "learn high performance driving skills."
During my 4th and final 20 - 24 min course run, my brakes hit the floor at about 80mph. Needless to say, I mumbled, "awe shit..." as we approached the corner. I pumped the brakes a few times and went into the corner with too much speed throwing me at the very edge of the track. Luckily, it was a corner that I could go into a bit faster...and not a corner that had a barrier, creek, trees, etc. It could have been bad. So, with that happening and losing my brakes (so not cool), I figured my brake fluid began to boil. If that happens, condensation and air begin to build up in the lines. From here on out, I learned that my brake fluid will boil more quickly and my brakes won't work to the best of their "Brembo" ability. I can't ever let this happen again on ANY track or ANY street. So, I bought Super Blue Racing DOT 4 brake fluid. Yes, the cap on the cylinder says DOT 3. This confused me and I wanted to make sure I was not about to screw something up. So, I began reading and reading. In my search, I found this to be EXTREMELY helpful. I wanted to make SURE that everyone here go the same info I just had and was able to make a well informed decision on their own if they ever decide to head out to a "driving school," 1/4 mile track, road course, or plain flat out, RACE. Check out the link here. It could SERIOUSLY help. Quote:
Not bad. ![]() Here's some more info for those wanting to know how to bleed those brakes. Quote:
Móderator
Wow, great info so glad u shared this with us...
I'm not the one with the Atti2de problem it's everyone else that has a problem with my Atti2de!
SST...
Drives: SST Camaro 2010 Join Date: Oct 2008
TAG -
Thanks for posting such a great article. Again, it's the little things that really add up to make a safe vehicle, especially in racing conditions. I use Wilwood EXP 600 fluid in my "HP" vehicles for that very reason. No one thinks of brake fluid, just brakes, but you found out first hand - it makes a BIG difference. Thanks again for the Thread. Should help some others stay out of trouble. |
Happy to help.
![]() Now....I'm thinking of upgrading to stainless steel brake lines. (Honestly, losing my brakes like that kinda got me prettttttty damn nervous. I am NOT going to let that happen again!) |
#5 | |
SST...
Absolutely upgrade to BSS brake lines. MTI on this site has a good set. Goodridge makes them, StopTech makes them. Hate to sound like a broken record, but all our HP vehicles have been equipped with BSS brake lines. |
#6 |
Doesn't sound like a broken record to me! This is EXACTLY the kind of information that I'm looking for. What type of stainless steel brake lines?..."BSS, carried by MTI." THIS helps!
![]() THANK YOU! |
#7 |
Dances With Mustangs
In addition to allowing some heat dissipation through the BSS lines, they also give a better, more solid feel to braking since they don't expand like rubber lines do thus you won't feel your brakes getting spongy as they heat up.
If you want a nice upgrade, especially you guys who've boosted your power, try the Racing Brake 2-piece drilled/slotted rotors. Besides being 6 lbs lighter than the stock rotors, they do a great job of ventilating and dissipating heat. And they look seriously cool too. ![]() Here's how they look on my car (these are the fronts):
Blue Angel is here!! ![]() 1SS/RS LS3 M6 IBM |
#8 |
I remember you getting those....talking about unsprung weight, etc. How are they treating you?
#9 |
Wonderfully Awful Idea
Excellent info. I am wondering though it often says NOT to mix types of fluid. How do you ensure that you are getting all the DOT3 out? There is always a bit left coating in the lines, master and calipers. (may not seem like it but 1oz. or a shot glass full is a very large percentage) Are you running enough thru to "flush" out the old? I upgraded my 57Caddy to front disc, I replaced it with all new. now it stops on a dime. After all if you cant stop don't start. It's just a question, I'm not questioning your intelligence.
#10 |
the old stuff is a black/gray/clear fluid. The fluid that I used is blue (super blue racing DOT 4). You remove (with a turkey baster, etc) from the master cylinder and then pour in the new beginning to bleed one line at a time until you get blue fluid that comes out. Sure, there's going to be a teeny tiny bit left over... But, the majority will be out.
If you want to, you can always take the car to a professional shop. They have machines to properly drain the fluid out of the cylinder. |
#11 | |
#12 |
RAM'S CAMARO
Drives: 2010 camaro ss Join Date: Apr 2009
Great write up...Lots of great info
#13 | |
I have DOT4 in my lines now and if someone makes me a good offer on some new stainless steel brake lines, I'll pick some up. |
#14 | |
The braided lines aren't that expensive; I got mine from Racing Brake but I know Pedder's and other sells them and the price is around $120 I believe give or take a few bucks. It's an upgrade that is WELL worth it.
#15 |
Yep.
$128 on their site. Going to keep on looking...see what I can come up with. Thanks! |
#16 |
Whipped
thanks for this info Tag. . . I myself had the same scare.. . Last Lap the 4th time out. . . I was lucky enough the brakes went out on my cool down lap. . .
Magnaflow Cat back / ROTO-FAB Intake / Whipple Kit / RDP Tune.
580hp - 650Tq |
#17 |
![]() Drives: 2013 IOM ZL1 Join Date: Nov 2009
I have one of these and it works pretty well. I am not sure if there are any issues using it with ABS systems though.
http://www.summitracing.com/parts/MVP-0250/ |
#18 | ||
![]() ![]() Really, there is no difference other than wet/dry boiling points. In other words, DOT 4 can withstand a little more braking and heat. It's good stuff. Super Blue Quote:
#19 | |
How U Doin?
#20 |
WWWWWOOOOOOOOOOOOOOOOOOOOOO
HOOOOOOOOOOOOOOOOOOOOOOOOOO Got my MTI stainless steel brake lines in as a Christmas present from Mrs.Tag! Now...to replace and bleed those brakes once again...lol |
#21 | |
Camaro Owner Since 1987
Drives: 2011 2SS/RS L99 RJT Join Date: Jun 2006
I also used super blue. Worked great. Bill
2011 Camaro 2SS/RS L99 RJT
CAI, Inc. Cold Air Induction;ADM Scoop Rx Catch Can;Rx Breather;Roto-Fab Washer Container VMax Ported RJT Throttle Body XSPower Headers and XSPower 3" Exhaust System Elite Engineering Tunnel Brace, Gorilla Wheel Lock System; Tinted Windows 35%;EFILive Tune |
#22 |
![]() Drives: IOM 2SS RS Join Date: Oct 2009
I'm sold. Going with Super Blue DOT 4 before C5Fest II. How much does it take to flush the old stuff out of the sytem? Owner's manual doesn't have anything about brake fluid capacity.
#23 |
We used just one bottle ...$14 and we were good.
#24 |
and MR. HYDE
Drives: 2010 2SS RJT/BLK 6Spd Man Join Date: May 2009
One other point for those who may not know ( I sure didn't and had to be told) If you are doing any type of track events and you are heating up your breaking system you need to be careful when you are finished and DO NOT APPLY THE EMERGENCY BRAKES it has a tendency to warp your rotors.
I do not know if this will actually warp your rotors but this is what I was told by a track instructor and didn't want to find out the hard way. Great write up about the fluid, and brake line, glad I changed my lines, now need to change my fluid.
MUSTANG...Like Bringing a Hot Dog to a Steak Dinner....There is no comparison.
#25 |
![]() ![]() ![]() ![]() Drives: 11 IOM 2SS/RS M6 w/Hurst Join Date: Nov 2009
I recently used Super Blue in my bike, I liked it and highly recommend it as it makes flushing very easy. Plan on doing the camaro soon.
Cheers K |
| Thread Tools | |
| Clutch fluid contamination problems on Vette fixed for Camaro??? | LDGn63 | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 11 | 05-28-2012 09:17 PM |
| ROTORA BIG BRAKE KITS 4-12 PISTONS/ 15" & 16" ROTORS SPECIAL | ADKINS PERFORMANCE | Suspension / Chassis / Brakes | 0 | 08-03-2010 12:08 PM |
