BeckyD @ James Martin Chevy
Old 08-25-2010, 11:17 AM   #1
tjh
Drives: blue
Unhappy Low oil pressure TSB
I have low oil pressure at idle and when I first start up in the morning I can hear something like lifters clacking for about 20 seconds. The oil is full and there are no leaks. Should I take it to the dealer or is this normal?
tjh is offline   Reply With Quote
Old 08-25-2010, 12:22 PM   #2
LS3 SS
LS3 SS's Avatar
Drives: 2010 Cyber Grey Camaro SS (LS3)
What is your oil pressure reading? (even though its not completely accurate)
GPI SS3 Cam / PRC 255 heads / Forged 376ci bottom / Fore level 2 fuel system / D1SC ProCharger on 12lbs / Alky control dual nozzle / 770 whp / 649 wtq tuned by Ryan Stevens at GPI
LS3 SS is offline   Reply With Quote
Old 08-25-2010, 12:41 PM   #3
67 Convertible
67 Convertible's Avatar
Drives: 67 Camaro Convertible
You don't mention if you have a V6 or a V8.
I have a V6 and have a slight "ticking" noise all the time.
I have been told this is normal.
I can't speak for the V8.
I haven't heard of any TSB's for low oil pressure, but if you are absolutely sure you have an oil pressure problem, you should take it to the dealer.
2LT/RS RJT, Blk Rally Stripes, Beige Interior, Sunroof
Placed order at dealer 4/24/09
1100 - 4/28/09
2000 - 5/01/09
2500 - 5/05/09
3000 - 5/05/09
3300 - 5/30/09
3400 - 6/05/09
3800 - 6/18/09
4000 - 6/18/09
4B00 - 6/18/09
4200 - 6/22/09
5000 - 7/01/09
6000 - 7/01/09 It's Home!!
0000 - 7/14/11 Traded in with 24,000 miles. Currently 5th Gen less
67 Convertible is offline   Reply With Quote
Old 08-26-2010, 10:35 AM   #4
tjh
Drives: blue
I have the SS v8
Old 08-26-2010, 10:36 AM   #5
tjh
Drives: blue
The oil pressure goes from half way between 0 & 30 at idle and around 50 while driving.
Old 08-26-2010, 12:53 PM   #6
reason
reason's Avatar
Drives: 2010 Camaro 2SS / RS
take it in -
i had my oil bypass valve worked on because of the TSB
- 2 weeks later had a similar problem pop back up and now its looking like my engine may be shot as they cant find where the oil pressure problem is coming from. Been in the shop for 2 weeks now and still no resolution....
reason is offline   Reply With Quote
Old 08-26-2010, 01:13 PM   #7
tjh
Drives: blue
Thanks everyone. Does anyone know what the TSB number is?
Old 08-26-2010, 02:44 PM   #8
reason
reason's Avatar
http://www-odi.nhtsa.dot.gov/tsbs/tsbsearch.cfm
Do a search on here- sorry im on my phone and dont have it readily avail. It should be the oil pressure bypass valve-
Old 08-26-2010, 03:37 PM   #9
Bogie
Drives: SKY Redline
V6 is Direct Injection (DI). The DI high pressure pump often makes a ticking sound, which is normal.
V8 isn't DI, so it shouldn't have the same tick.
Bogie is offline   Reply With Quote
best synthetic oil to use hollywoodjose Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 130 01-26-2014 09:51 AM
Oil Changes Dave McFly Off-topic Discussions 6 05-18-2010 05:50 PM
Oil Change Ramp mjlash22 Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 17 01-21-2010 11:40 PM
I think i'm done waiting. pinkcamaro10 Off-topic Discussions 332 05-13-2009 05:56 PM
