Jason 98 TA
Old 08-25-2010, 10:43 PM   #1
LineofPerfection
LineofPerfection's Avatar
Drives: 2010 2SS Camaro "Big Blue"
4000 miles and in need of a new rearend
I took my car to the dealer for a clunking / backlash problem in the rearend. Any time I change gears at a slower speed you can really feel and hear the backlash. My car only has 4,200 miles on it and the dealer sais that the pinion bearing needed to be replaced along with the ring and pinion, bearings and seals. The opted to put a new rearend in it. I am happy for that. Has any one else had this problem? They are also replacing the radio because it has blurry spots on the display screen from the inside(looks like finferprints).
Big Blue
LineofPerfection is offline   Reply With Quote
Old 08-25-2010, 11:36 PM   #2
SSLarry
Drives: 2SS LS3
Thats exactly the kind of thing they wouldn't replace under warranty if you had any forced induction. Yours failed because of a manufacturing defect, but if you had a blower, they would claim it was over stressed due to increased power.
This is the kind of thing that is keeping me from getting a Maggie.
SSLarry is offline   Reply With Quote
Old 10-06-2010, 10:31 PM   #3
LineofPerfection
Dealership replaced rearend now after about another 500 miles the problem/noise has returned. It has been sitting at the dealership all week waiting on an engineer to look at it and make some kind of determination of the problem. On a side note the serviced department "curbed" my front right wheel but will not own up to it. When I found the damage it had yellow paint on it, funny so does the lift in the shop !!
Big Blue
Old 10-07-2010, 09:55 AM   #4
Skyblu
Skyblu's Avatar
Drives: 2010 Aqua blue 2SS/RS M6
Just curious, before they replaced it was yours making a roaring noise especially when you turned at slow speeds? Mine does that and the first time they replaced fluid and added limited slip additive and worked for about 2500 miles it's doing it again but they claim they can't hear the noise this time so I have to wait till it gets louder. I know another guy on here has the same issues as mine just wondering about yours?
Skyblu is offline   Reply With Quote
Old 10-07-2010, 09:44 PM   #5
LineofPerfection
Mine doesn't have a roaring noise it has a lot of backlash and backlash clunk. The dealership called today and said that the GM rep aknowledged a problem and said other people had the same noise and complaint but at this time they had no remedy and said it wasn't an issue at this time. My dealership told me to call GM direct and complain. On another note they replaced the wheel that they damaged off another new car, unfortunately the new car is an RS and mine is just A SS therefore the wheel is midnight silver instead of just silver. Now they are ordering me another wheel. Can you believe they took a damaged wheel and used tire (5,000 miles) and put it on a brand new Camaro to sell? CRAZY !!!
Big Blue
Old 10-08-2010, 09:43 AM   #6
Skyblu
Skyblu's Avatar
Thanks for the info, but I do believe about the tire and rim because the same thing happend to me at a dealer after getting my tires balanced they damaged my rim I told them I wanted it replaced and they did in the same day, so I assume they did the same thing except they did put my tire on a new rim I had about 9000 miles on mine when it happend.
Old 11-05-2010, 01:19 AM   #7
My 5th
My 5th's Avatar
Drives: 2010 2SS/RS M6 Black on Black
I just had the differential oil changed and I'm hearing a kind of growling sound when turning. The noise is louder when the turn is tighter. Is it possible that going into an open parking lot and making a bunch of tight turns will work the oil into the differential clutches and make the gowling go away? I also have noticed more backlash noise as well. I recently had the Pedders bushings kit installed along with the Xa coilovers, and thought maybe the clunking sound was more prominent because of the bushings, but maybe I'm getting too much back lash in the ring and pinion.
Meh
My 5th is offline   Reply With Quote
Old 11-05-2010, 09:50 AM   #8
kaos_ss
kaos_ss's Avatar
Drives: 2013 Camaro ZL1
Curious??
I was just wondering if you called GM...and did you get any positive results. I'm in the same boat. My car doesn't shift properly (auto) and after attempting to repair it the dealer said GM knows there is a problem but doesn't have a solution to it at this time. I was so upset because it isn't just a noise but a performance issue.
So after calling and complaining for what seems like an eternity I didn't accomplish anything. Just wanted to see if you had better luck...
kaos_ss is offline   Reply With Quote
Old 11-05-2010, 09:04 PM   #9
Iomss
Drives: IOM SS2
My car 2SS is having th e same problem with 3900 miles on it today the dealer changed the fluid and pit in the additive and told me to give it a week because it's still making the same noise so I'll soon see with some added mile.
Iomss is offline   Reply With Quote
Old 11-05-2010, 11:25 PM   #10
Rage
TRI-COUNTY CAMARO... FTW!
Rage's Avatar
Drives: 2010 Camaro 2SS M6 Cyber Grey
What is this backlash noise you are describing? Clunking, whirring, popping? Sorry, never heard of backlash.
CAI inc. cold air intake, LG G6x3 cam, Patriot Gold Extreme Dual springs, Titanium retainers and locks, LG SuperPro 1 7/8 Long Tube headers with full 3" exhaust, DynoMax VT mufflers, SLP 4" tips, Moroso catch can, Race Ready electronic exhaust cut outs, Full painted Razzi body kit, Headlight Armor Smoke taillight and marker blackouts, T-Rex aluminum upper and lower grille, Polished aluminum front and rear bowties. Professionally installed and Dyno Tuned by HorsePower Sales, Pompano Beach FL.
Rage is offline   Reply With Quote
Old 11-05-2010, 11:33 PM   #11
Jeanius
Jeanius's Avatar
Drives: Blk/Blk 2018 Sierra SLT
I just had my driveshaft replaced due to a clunking noise coming from the center console, are you positive the noise is coming from the rear end?
SOLD: 2SS LS3 M6 - MGW - Dynatech LT's HF Cats - Magnaflow Street CB - ADM Race CAI - Pedders Xa Coilovers - Pfadt Sways
TRADED: 2016 2SS M6
Jeanius is offline   Reply With Quote
Old 11-07-2010, 07:44 PM   #12
SSLarry
Drives: 2SS LS3
You can get a power train warranty through Magnacharger for $250 or so for up 36,000 miles. Edelbrock offers up even better warranties.
2010 CGM 2SS LS3, born: 4/10
Old 11-08-2010, 11:33 AM   #13
Skyblu
Skyblu's Avatar
I goes away for awhile but mine does the same thing and after they replaced the fluid it is now making the same noise and I had taken it back but they claimed could not hear it, so I waited till it got louder and will be taking it back again, It is very loud now so they should be able to hear and fix it right this time!
