JUICEDMOTORSPORTS
5th Gen Camaro SS LS LT General Discussions General 5th generation Camaro topics not covered by other subforums.
Old 12-04-2008, 11:00 AM   #1
Captain Awesome
Drives: 2010 Camaro 2SS/RS
Sequential Turn Signals?
Not long ago on this very forum we were having a discussion about the afterburner tail lamps and how to make the Camaro more advanced in the lighting department and I proposed using sequential turn signals like on the old 1969 Mercury Cougar.
Someone here linked to a bunch of laws and safety regs online that pretty clearly showed that these types of lights were illegal and you could not use them or put them on as aftermarket components without breaking the law.
Now I read that the 2010 Mustang has them as standard equipment? How can they put illegal sequential turn signals on this car?
Does that mean someone can retrofit them on the Camaro legally now?
Captain Awesome is offline   Reply With Quote
Old 12-04-2008, 11:01 AM   #2
theholycow
theholycow's Avatar
Drives: '02 GMC Sierra, '80 Lesabre
Interesting...
http://www.autoblog.com/2008/11/17/l...ally-unveiled/
The tail-lamps, which still feature the traditional three bar look, have been re-shaped and now feature sequential turn signals. When the turn signals are on, the three lamps light in sequence from the innermost to the outer.
Removing weight has surprisingly little effect on fuel economy
Engine break-in procedure | Gear ratios
2002 GMC Sierra 4x4 5.3 (190,000 miles and going strong)
1980 Buick Lesabre family heirloom with 36,000 miles
2008 Volkswagen Rabbit 2 door I5-2.5 5spd DD lease
she really underestimates the damage i would do to her reproductive organs
http://allOffTopic.com is the place for all the naughty stuff you can't get away with on this forum...
theholycow is offline   Reply With Quote
Old 12-04-2008, 11:12 AM   #3
zebra
just can't seem to leave
zebra's Avatar
Drives: your mom wild!!
i don't see how sequential lights can be illegal. even some of the new semi trucks, school buses, & fire trucks have the animated arrow LED turn signals. how is that any different?
Old 12-04-2008, 11:16 AM   #4
Captain Awesome
Someone quoted the DOT regulation to me on this forum. It was pretty clear.
Old 12-04-2008, 11:19 AM   #5
theholycow
theholycow's Avatar
Here's the quote you're probably talking about:
Originally Posted by cannondalerider View Post
Unfortunately, sequentials are illegal, however there are aftermarket companies that make kits to do it. They were outlawed in the early 70's.
http://en.wikipedia.org/wiki/Turn_signal#Turn_signals
Actually, this is the part about sequential turn signals:
http://en.wikipedia.org/wiki/Turn_si...l_turn_signals
U.S. Federal and Canadian motor vehicle safety standards currently prohibit sequential turn signals. However, Federal standards do not apply to vehicles in use, and so extension of this prohibition to vehicles in use is left as a matter of choice for each state or province. Sequential turn signals are sometimes used on emergency vehicles.
Old 12-04-2008, 11:39 AM   #6
theholycow
theholycow's Avatar
Ok, found the federal standards document...
http://edocket.access.gpo.gov/cfr_20...cfr571.108.htm
Old 12-04-2008, 01:57 PM   #7
Mr Twisty
Mr Twisty's Avatar
I read thru the FMVSS and didn't see anything about sequential signals. Someone else want to read it?
Wikipedia is ok, but, it can be outdated or just...wrong. FMVSS does require 2 rear signals, one on each outermost corner blabla
-- Benjamin Franklin
Great Racing Quotes
"Never run out of real estate, traction and ideas at the same time."
"I was doing fine until about mid-corner when I ran out of talent."
"Don't brake until you see God, just don't meet him"
Old 12-04-2008, 02:10 PM   #8
TJ91
:chevy:
TJ91's Avatar
Drives: 2LT/RS
I dont see why it should be illegal, but it sure does look great, i juat want some afterburner tailights to come out...Aftermarket shall be my best friend
Old 12-04-2008, 02:14 PM   #9
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
I'd like to see if someone can come up with some LED Afterburners or something. I think that would be at least as good as sequentials, IMVHO.
"...What IS true: We anticipated that this would happen - we are never finished - and yes, Ford DOES deserve to win now and then. To think that GM can come out with a car to make ford throw in the towel is simply foolhardy..." - fbodfather
Old 12-04-2008, 02:16 PM   #10
theholycow
theholycow's Avatar
The closest I could find was this:
S5.5.10 The wiring requirements for lighting equipment in use are:
(a) Turn signal lamps, hazard warning signal lamps, and school bus
warning lamps shall be wired to flash;
(b) Headlamps and side marker lamps may be wired to flash for
signaling purposes;
(c) A motorcycle headlamp may be wired to allow either its upper
beam or its lower beam, but not both, to modulate from a higher
intensity to a lower intensity in accordance with section S5.6;
(d) All other lamps shall be wired to be steady-burning.
That specifies that they must flash, but doesn't specify that they can't flash sequentially if there's more than one arranged linearly.
Old 12-04-2008, 02:22 PM   #11
TomServo
Drives: 2007 Z06
Corvette guys have been modding theirs for years now.
http://www.ecklers.com/product.asp?p...6&dept_id=1384
TomServo is offline   Reply With Quote
Old 12-04-2008, 02:25 PM   #12
Camaro_Corvette
50.335252,6.947103
Camaro_Corvette's Avatar
Drives: Anything with wheels
I would have never imagined that those would be illegal. They really don't make a big enough difference for it to be a problem
Old 12-04-2008, 02:41 PM   #13
Black5thgen
Drives: 2007 C6
I don't want sequential signals, leave that to the pony boys. I wouldn't want them to get confused when they see my tailights, which will be very often.
Black5thgen is offline   Reply With Quote
Old 12-04-2008, 03:26 PM   #14
camaro5's Avatar
Drives: Off Into The Sunset
Man, one of the coolest things I remember from childhood is those Mercury Cougar tailamps.
And now Ford brings them back? Very clever move.
camaro5 is offline   Reply With Quote
Old 12-04-2008, 03:33 PM   #15
SoFlaZ
SoFlaZ's Avatar
Drives: Nothing special :-(
A few months ago I saw a mustang with them and they looked SWEET! The guy kept turning on his hazards to make them constantly sequence or whatever you want to call it.
SoFlaZ is offline   Reply With Quote
Old 12-04-2008, 03:40 PM   #16
LSxJunkie
Snark snark snark
LSxJunkie's Avatar
Drives: RX350
This is why you always look for citations in Wikipedia articles. Clearly FoMoCo knows better than some punk who edits Wikipedia.
What is this, CorvetteForum Lite?
LSxJunkie is offline   Reply With Quote
Old 12-04-2008, 03:59 PM   #17
TJ91
:chevy:
TJ91's Avatar
Drives: 2LT/RS
Really? All he had to do was brake. Ohhh yeahhhh, does the 2010 do the sequential brake, im guessing that it has to, i know thats the case for the sequential tail lights for the 05 up. but seeing as this is factory and not aftermarket, it could be three solid 3 lights instantly, looks nice when it goes 123 solid.
Old 12-04-2008, 04:28 PM   #18
Brokinarrow
Brokinarrow's Avatar
Drives: 1984 Honda Nighthawk 700s
This could be one of those laws that they made a while ago and everyone forgot about and thus no longer cares to enforce. It happens every now n then.
Brokinarrow is offline   Reply With Quote
Old 12-04-2008, 05:12 PM   #19
zebra
zebra's Avatar
yeah... in Memphis, TN it's illegal for a woman to drive a car unless there is a man either running or walking in front of it waving a red flag to warn approaching motorists and pedestrians.
Old 12-04-2008, 06:31 PM   #20
SoFlaZ
SoFlaZ's Avatar
I know but he IS a mustang owner. But we were just cruising at 45 down a straight road so no real need to constantly brake.
Old 12-09-2009, 04:44 PM   #21
BADMAB
Drives: Camaro
I just posted this thread:
http://www.camaro5.com/forums/showth...77#post1266477
Enjoy!
BADMAB is offline   Reply With Quote
Old 12-09-2009, 06:11 PM   #22
Apex Paul
Apex Paul's Avatar
Drives: Wagon Queen Family Truckster
I can't even remember the number of times that someone has tried to use information from wikipedia as "factual". The site is simply not a good source, because the sources are often unverified hearsay.
Apex Paul is offline   Reply With Quote
Old 12-09-2009, 06:12 PM   #23
Revo1
Camaronogamous
Revo1's Avatar
Drives: 2010/2002 Camaro SS!
The Mustang does indeed. Didn't realize that they were illegal :(
Revo1 is online now   Reply With Quote
Old 12-09-2009, 06:13 PM   #24
Apex Paul
Apex Paul's Avatar
Seems reasonable. (slips into bulletproof vest and flame resistant suit)
*sorry ladies, I couldn't resist.
Old 12-09-2009, 07:02 PM   #25
HeavyD
HeavyD's Avatar
Drives: 1SSRS RY L99
In Ontario the highway traffic act mentions nothing about sequential tail lights, as long as they indicated the turn desired and have all the proper intensity, blah blah.
No one has mentioned the 3rd brake light pulser that is a common mod too. In Ontario that would be illegal, as the act says the only light allowed to be "intermittent" are the 4-ways. Seriously, we all know there are cops out there that would pull you over just because they can. I'd hate to give them a reason.
HeavyD is offline   Reply With Quote
can we turn afm on/off? or delete it?? tsg1391 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 29 04-08-2010 09:21 PM
Turn Signal Question kanys Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 50 01-20-2009 04:14 PM
Whats the "MENU" on the turn signal stalk for? fredl11 5th Gen Camaro SS LS LT General Discussions 23 10-11-2008 05:20 PM
Blinker placement opinions CyberGamaro Cosmetics and Lighting Modification Discussions 21 07-31-2008 05:58 AM
