Old 08-26-2010, 08:09 PM   #1
Steve1968LS2
Drives: 1968 LS2 powered - Bad Penny
Prototype Penske shocks are in for our 2010
New struts for the 2010 SS showed up today.. these are serial number 1 and the only set on the planet..
Eventually they want to make it so you can use existing drop springs but the perches aren't out yet. If you notice the ride heigth is not set with the spring but with the body of the shock. They also have some new sort of trick valving inside. I will know more when I interview the engineer on Monday at our track test. The car will be our 600+ blown 416 silver CP/28 project car.
We will be installing them tomorrow at Global West (along with my '68 Camaro's 'Bad Penny" new shocks) and testing them Monday at the track with an engineer from Penske they are flying out.
Anyways, they are simply bad ass. Right now they are single adjustable but reservoirs can be added to the top to make them double adjustable and they can also be made three-way adjustable.
Penske Racing
http://www.penskeshocks.com/Home.php
Global West - dealer
http://www.globalwestperformance.com/
Tech Editor for Camaro Performers Magazine
1968 Camaro - 461 RHS LS 700hp, various stuff, called Bad Penny
1968 Camaro - In progress, called Track Rat
2010 Camaro - DSE Suspension, Baer 6S Brakes, Boze Wheels, Nitto NT05 Tires, JBA Exhaust and long tubes, Magnacharger TVS, 660rwhp Forged Eagle 416 LS3 short block, ADM fuel system, Lingenfelter GT-9 cam, G-Force axles, Anvil and Seibon CF parts, Centerforce Dual-Disc Clutch
www.fquick.com/steve1968ls2
Steve1968LS2 is offline   Reply With Quote
Old 08-26-2010, 08:13 PM   #2
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
Interesting.
Old 08-27-2010, 08:25 AM   #3
Iansane
Drives: 325is
Ooooooo Penske. Sexy!
Iansane is offline   Reply With Quote
Old 08-27-2010, 09:21 AM   #4
BMR Sales
BMR Sales's Avatar
Drives: Race Car
Penske stuff is top of the line stuff, so I dont think these coil overs will be any different. One of the best coil over companies in the market today.
T.C. Davis
Sales Tech, Test Driver
813-986-9302
tc@bmrsuspension.com
Old 08-27-2010, 09:29 AM   #5
BMR guy
BMR guy's Avatar
Drives: 2010 1SS
Simply "bad ass" may be an understatement!
BMR guy is offline   Reply With Quote
Old 08-27-2010, 09:40 AM   #6
Iansane
Drives: 325is
Any pictures of Penske's rear solution?
Old 08-27-2010, 09:57 AM   #7
shevyman
Drives: 2010 Camaro SS IOM
would love to see them on the car and hear how they perform
shevyman is offline   Reply With Quote
Old 08-27-2010, 01:36 PM   #8
Steve1968LS2
I will post something tonight.. they actually have remote reservoirs and utilize the OEM frame mount.
Starting the install right now..
Old 08-27-2010, 02:54 PM   #9
Avalnch
Avalnch's Avatar
Drives: Rally Yellow Camaro+Avalanche
Aw man, I thought they were shock, shocks! Not coil overs!
My old Gen3 had a set of adjustable Tokicos at stock height which made a huge improvement for auto-crossing. I'm hoping for the same on the Gen5's.
Vengeance Kaotik Cam, C.A.I., ARH LT, Pypes Cat Back, ZL1 Shifter+2012LS3VERT bushing, Quantum Brake Ducts, JDP Tow Hook Scorch Yellow Trim Kit, Shark Fin, AAC DRLs+ABLs+SMDs, ZTA Rear Spoiler, R.Y. 1LE Splitter. Pfadt coilovers, camber plates, trailing arms, Pegasus Solid Subframe. Pedders ZL1 barz, radius arm & steering rack bushings. BMR adjustable toe-rods. Hotchkis Max Chassis Brace. ZL1 GMPP Driveline Upgrade. TurnOne P/S pump.
447 HP @ 6180 RPM / 418 TQ @ 5100 RPM
Avalnch is offline   Reply With Quote
Old 08-27-2010, 07:06 PM   #10
MiSTER
Drives: 2010 2SS CGM Camaro, 1988 6.6L IROC
SICCCKKK! For the money Penske was all I'd use for my track motorcycles. Their support has always been pretty good too.
MiSTER is offline   Reply With Quote
Old 08-27-2010, 11:28 PM   #11
Steve1968LS2
I know.. I'm trying to talk Penske into just making some replacement struts.. I can't believe there are still none on the market.
These could be, but they have to finish the rear mount that would accept a factory style "beehive" shaped huge ass spring.
Then again, what are you really saving? These 2.5" springs are pretty cheap.
Old 08-27-2010, 11:29 PM   #12
Steve1968LS2
Yes, they've been great to work with.
And since these are prototypes we did run into an issue on the rears.. the fronts fit great though.
Parts are being overnighted so we can make the change and finish the install Sunday.
Track testing is still set for Monday.
Old 08-28-2010, 03:27 AM   #13
MiSTER
I was pretty surprised that replacement performance struts aren't available as well. Speaking to Sam Strano, he brought up a good point that no one complains about how heavy the BMW's are but they don't feel like they are. Alot has to do with the valving of the Sachs dampeners on them.
A set of Koni replacements and his springs made my 3rd Gen Camaro handle way better than I expected. Well under a price of coil overs for that car and I just didn't see the need for coilovers for a car that used as a daily driver.
Definitely good to see a player like Penske coming out with dampeners for the Camaros though. Any estimate on what these coilovers will run for?
Old 08-28-2010, 12:37 PM   #14
Steve1968LS2
I will ask them on Monday.. I imagine they will be in line with other manufactures. Also, there will be a price for single and double adjustables.
I will also ask about the mounts to use stock style springs, although that wouldn't save you very much cash.
I do like how these use the stock upper mounts and how the fronts adjust by the body and not the spring perch.
CAMARO WIKI Tran Wiki 55 03-28-2017 01:04 PM
Latest Camaro Products - March 2010 Sean@Phastek V8 Bolt-Ons & Tunes 26 08-04-2010 05:42 PM
February 2010 Camaro production & sales figures. Tops Mustang for 9th straight month! Tran 5th Gen Camaro SS LS LT General Discussions 52 03-03-2010 10:39 PM
DEALER ONTARIO CANADA WE SHIP ANYWHERE IN CANADA 2010 CAMAROS FOR SALE IN STOCK NOW! dz Dealer Camaros for Sale 0 03-03-2010 06:43 PM
