Old 08-27-2010, 07:04 PM   #1
macwest
Drives: 10 Camaro 2SS/RS, 70 Cuda, 71 Cuda
Gear change question
Just changed gears to 4.10. but the guy that can adjust the flash can not do it till monday. Otherwise then my speed being off is their anything else I should be aware of? Will the RPMs show correctly?
macwest is offline   Reply With Quote
Old 08-27-2010, 07:58 PM   #2
Roger Ramjet
Motor Head
Roger Ramjet's Avatar
Drives: CTS-V
Assuming this is a M6, the speedometer is the only problem. It will indicate ~16% faster than actual vehicle speed. RPM will be normal.
History Camaro's: 83, 93, 95, 98, & 10.
Roger Ramjet is offline   Reply With Quote
Old 08-27-2010, 11:28 PM   #3
macwest
Thank you
Rear End Gears 101 danhr V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 82 08-04-2017 11:38 AM
Question about Halo Ring, color change JJSoCrazy Cosmetics and Lighting Modification Discussions 31 09-06-2015 11:57 AM
V6 Oil Change Question WVCamaro10 Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 6 07-07-2010 05:03 PM
Camaro on Top Gear chewy4ce 5th Gen Camaro SS LS LT General Discussions 234 03-22-2010 02:14 AM
Order Change Question charleba Camaro Price | Ordering | Tracking | Dealers Discussions 4 07-21-2009 07:53 PM
