third_shift studios
Old 08-29-2010, 01:46 AM   #1
Spiffyguitar
Spiffyguitar's Avatar
Drives: 2010 Camaro 2SS/RS
Leaking fluid from rear of Trans
I got under my car today to do an oil change, and to take care of an o2 CEL that I have... while I was under there, I noticed a drip of fluid towards the back of the transmission. I looked for the source of the leak, and it seems to be coming from somewhere around where the drive shaft meets up with the trans.
The brace that supports the rear of the trans was dirty on the once side presumably from small amounts of fluid that have settled there over time. I did change out my transmission fluid (10k miles ago), with Royal Purple Syncormax. Has anyone else had this problem, or noticed any small leaks? I know the simple answer is "take it to the dealer", but with Royal Purple in the there I'm sure they won't play nice. Haha. Any other suggestions or insights?
2010 Camaro 2SS/RS -6M
397whp/393 ft/lbs
Spiffyguitar is offline   Reply With Quote
Old 08-30-2010, 11:16 PM   #2
naga
Always be positive!!!
naga's Avatar
Drives: IMB 1ss/ MT
IMO you should take it to the dealer because, the dealer does not know what type of fluid your using, since you ran a few miles on the trans with RP, the oil will change in colorand will look the same as the factory oil!!! Hope you did not do your trans oil change at the dealer it self!!
The reason i am saying this is because one of my friends had a problem with the rear diff and there was a oil leak and the dealer covered it under warrenty, he changed all the oils to RP on his camaro and the dealer had no idea what type of oil he was running the car on!!!
hope this helps..
Borla ATAK catback/ K&N CAI/ Diablo Tune for now
naga is offline   Reply With Quote
Old 08-31-2010, 01:14 AM   #3
Spiffyguitar
I do almost everything on my own, and swapped the trans and diff fluid Royal Purple pretty early on. The dealership hasn't seen my car since the day I drove it off the lot. In looking a the little drips under the back of the trans, you can see the purplish color, and it looks a lot different than stock.
For now, I picked up a bottle of Lucas trans additive to help with the rear seal. The leak isn't too bad, so hopefully that will do the trick. If not, I might take it to the dealer... changing out that seal has got to be a pain when working on a garage floor with jack stands.
397whp/393 ft/lbs
Old 08-31-2010, 08:54 AM   #4
naga
naga's Avatar
Drives: IMB 1ss/ MT
I spoke to my dealer about the trans oil change and he said that when you change the trans oil you need to remove the trans oil pan and drain out all of the oil before you refill it with a different oil.. did you do that before adding in RP…
Old 08-31-2010, 09:20 AM   #5
justa25thTA
justa25thTA's Avatar
Drives: 2011 Camaro SS/RS LS3
Your really going to try to band aid your new $35k car when it is under warranty?
justa25thTA is offline   Reply With Quote
Old 08-31-2010, 09:57 PM   #6
Spiffyguitar
Hmm. Don't know about the "trans fluid pan"... I used another bottle of RP and did a fluid flush when I swapped it out. That should have taken care of that I would think. I'm wondering if RP isn't playing nice with the factory seals.
397whp/393 ft/lbs
Old 08-31-2010, 10:04 PM   #7
Spiffyguitar
Sadly I paid a little more than that when I bought my SS.. I don't look at it as a band aid personally. Lucas makes some quality stuff, and the leak for the time being is minor. It will keep it from becoming a bigger problem.
I agree that in normal circumstances someone should take a car in that's under warranty that's leaking anything... but by swapping to RP, then having a leak...there's no way that will be covered. They will replace the rear seal, which involves a decent amount of labor, then fill it with the factory 'lifetime' trans fluid, and give me a nice bill since the swap caused the problem. I could always 'give it a shot' and take it in, but Lucas is worth a shot I think.
397whp/393 ft/lbs
Old 08-31-2010, 11:10 PM   #8
MillerTime
Blowin the doors off!
MillerTime's Avatar
Drives: A 2013 SS RS 6M SR
I think what he's getting at is that even if it dosn't pour out..at least it's documented that its starting to weep out and the dealer will have to replace it later on as they have already been made aware of the issue.
2G1FS1EWXD9163847
MillerTime is offline   Reply With Quote
Old 08-31-2010, 11:30 PM   #9
naga
naga's Avatar
Drives: IMB 1ss/ MT
Well the reason to remove the trans oil pan is to also to change the trans oil filter and the gasket sealer. Since you’re going with a new brand you need to change the trans oil filter which also comes with a gasket sealer!!! The flushing is done only if you’re using the same brand of oil which comes from the factory. Again this is what my dealer told me.
Old 09-01-2010, 12:03 AM   #10
MillerTime
MillerTime's Avatar
That would be correct. never mix oil brands especially RP with those others. New filter and dropping that pan to get all the fluid out is the correct way...longer yes..but correct none the less..
2G1FS1EWXD9163847
Old 09-09-2010, 11:02 AM   #11
Tex
Texas Military Forces
Tex's Avatar
Drives: 2017 ZL1 Red Hot Auto
Question: if draining the transmission pan with just the drain plug & not dropping the pan would it be okay to just turn the car on so the rest of the trans oil in the torque converter will come out too?
2017 Red Hot ZL1 Automatic (Sunroof, PDR & NAV)
2/10/2017 status: ordered
2/23/2017 status: 3100 TPW 3/6/2017
3/06/2017 status: 3400 TPW 3/6/2017
3/10/2017 built 4200 VIN# 1G1FK1R65H0193462
3/18/2017 Delivered to me!
2016 Camaro 2SS (wife's car)
M228 Black Wheels
2010 Camaro SS (totalled by son)
Tex is offline   Reply With Quote
Old 09-09-2010, 07:58 PM   #12
Fast vette
Fast vette's Avatar
Drives: 2SS IOM M6, 71 ElCamino, 00 Sierra
You guys weren't following, Spyffyguitar is running a 6M.
But No Tex, you don't want to run your A6 to drain the converter, if you let it sit long enough half the converter is going to drain out anyways. You should always remove the pan and replace the filter though.
There are only two auto manufacturers; GM and everybody else...
Fast vette is offline   Reply With Quote
Old 09-09-2010, 09:10 PM   #13
Tex
Tex's Avatar
ok so then where & how do I refill it? I drained it by accident because I was doing an oil change but took off the wrong drain plug.
M228 Black Wheels
Old 09-09-2010, 09:10 PM   #14
Wesman
Wesman's Avatar
Drives: Trans Am
hope this helps..
Factory fill on the TR6060 is ATF, not Synchromesh. GM says only use Manual Transmission Fluid (Dex III) in the TR6060, and for good reason. Why would you void your warranty by using the incorrect fluid??
Not only is synchromesh chemically different than ATF, but it also smells different, looks different, and has a different viscocity.
Any half decent tech is going to immediately notice that you put the wrong fluid in the trans, and not only will you not get the deal replaced under warranty, but the rest of your warranty on your transmission will be void as well. Not good.
Wesman is offline   Reply With Quote
Rear End Leaking after Competitive Mode Launch 2011Black2SS Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 21 03-25-2011 12:47 PM
rear differential fluid drain/fill plug location Dentyneice Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 9 11-27-2010 10:54 PM
Oil, transmission, rear end fluid cowboy1948 Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 1 07-14-2010 05:16 PM
Changed the Diff and M6 trans fluid today... FirstLSK Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 28 04-15-2010 08:21 AM
Drag Racing Suspension Kits Info@PeddersUSA.com Suspension / Chassis / Brakes 25 02-21-2010 08:48 PM
