Billet Custom
Camaro ZL1 Forum - ZL1 Specific Topics Camaro ZL1 specific topics
Old 08-29-2010, 06:27 AM   #1
R6P
R6P's Avatar
Drives: 2010 Camaro
Cool Why wait for the Z, LS9 TVS2300 available now
Sorry if this is a re-post, I just came across this info.
I'm NOT Taking orders, just posting the info
To: Buick, Cadillac, Chevrolet, GMC, HUMMER and Pontiac (including MD)
DESCRIPTION:
GM Performance Parts announces the release of the LS9 Supercharger Kit.
THIS KIT IS BEING RELEASED FOR "OFF-ROAD" USE ONLY AND WILL HAVE NO WARRANTY
EFFECTIVE DATE:
Currently Available
GENERAL INFORMATION:
The supercharged LS9 is the most powerful production engine ever offered by GM—a company with over a 100-year tradition of building very powerful engines. State-of-the-art supercharging technology is one key to the 6.2L LS9's remarkable performance. This Gen IV V-8 represents the first original-equipment application of Eaton's twin-rotor R2300 supercharger—one of the company's Twin Vortices Series (TVS). The LS9 supercharger displaces 2.3 liters, compared to more conventional superchargers of 1.5 liters or less, and generates maximum boost pressure of 10.5 pounds per square inch (0.72 bar).
The TVS takes supercharging technology to new levels of refinement and efficiency. Each of its two rotors has four distinct lobes, or spiral-shaped vanes that intermesh precisely with those on the other rotor as they spin at high speed. Efficiency gains with the four-lobe rotors are substantial, compared to comparably sized, previous-generation superchargers: approximately 20 percent more airflow, with an improvement in thermal efficiency up to 15 percent.
The R2300 supercharger case and integrated intercooler have been tailored to the space available in the Corvette's engine bay. Despite its relatively large displacement, the supercharger sits neatly atop the 6.2L LS9. The air inlet and drive pulley are located at the front of the case, and the LS9's overall height is only slightly taller than the standard Corvette LS3 V-8.
Integrated Dual-Brick Air-to-Liquid Intercooler
An advanced intercooling system increases the 6.2L LS9's performance and extends its supercharger's benefits. The engine's charge cooler is integrated in the supercharger case just above the rotors, with two air-to-liquid cooling "bricks" that substantially lower the temperature of air used in the combustion process.
It uses two low-profile, aluminum tube-and-fin heat exchangers mounted longitudinally above the rotors in the supercharger case. The bricks are cooled by their own coolant circuit, with a remote pump and 3.62-liter capacity heat exchanger.
Center-Feed Fuel System
The 6.2L LS9's fuel system was developed to deliver adequate fuel volume precisely consistently and quietly. To ensure appropriate fueling in all conditions, GM has equipped the LS9 with a dual- pressure fuel system. The system delivers 250 kPa (about 36 psi) at idle or low speeds. Yet the electronic throttle management system can almost instantaneously increase fuel pressure to 600 kPa for sustained high-speed operation or wide-open throttle. It also ensures adequate fuel delivery when the LS9 demands its maximum flow rate of 58 grams per second.
The LS9 also employs a new center-feed fuel rail that delivers gasoline to the center of the injector rail an each bank. The delivery point is roughly equidistant to each of the injectors, which have a maximum flow rate of 6.52 grams per second at 400 kPa. Fuel pressure variation among the injectors is reduced and so is noise. An 87-mm, single-bore throttle body draws air into the engine. The electronic throttle maps have been optimized for excellent response and modulation in a multitude of driving scenarios.
Heavy-duty Accessory Drive
The supercharger drive is integrated into the main accessory drive system. The LS9's two-belt accessory drive has one belt turning the air conditioning compressor and alternator, and another operating power steering, the water pump and the supercharger. The supercharger requires the most force to turn, so its circuit uses a wider, 11-rib belt.
Part Number: 19244103
MSRP: $7,500
The LS9 Supercharger kit includes:
Intake Manifold Assembly
Ø Supercharger
Ø Throttle Body
Ø Fuel Injectors and Harness
Supercharger Cover/Intercooler
Intake Manifold Gasket
SPECIAL PARTS NOTICE:
GM Performance Parts Warranty does not apply for this part, it is considered a racing part.
This part is being sold for Off-Highway application only. Since the installation of this part may either impair your vehicle emission control performance or be uncertified under the current motor vehicle safety standards, it should not be installed in a vehicle used on any street or highway. Additionally, any such application could adversely affect the warranty coverage on an on-street or highway vehicle.
R6P is offline   Reply With Quote
Old 08-29-2010, 10:36 PM   #2
CoolestCamaro873
The Road's A Bad Joke...
CoolestCamaro873's Avatar
Drives: '12 Camaro SS
well your post just answered the original question of "why wait?" the reason is a warranty. and this is why mustang is the best selling pony car over the last 40 years. see ford racing offers superchargers for thier 5.0 GT and 5.4 GT500 and they come with warranties! when is GM ever going to learn?
CoolestCamaro873 is offline   Reply With Quote
Old 08-29-2010, 11:11 PM   #3
Dirtdog
Pro Hide n Seek Player
Dirtdog's Avatar
Drives: 2010 IOM SS/RS LS3
Send a message via AIM to Dirtdog
most people are already voiding their warrenties with ECU chips and other mods... so a warrenty isnt important to those people, right?
Borla S Cat-Back, Roto-Fab CAI, PFADT Swaybars, Springs, and End Links, HURST, Lots of AAC Goodies
ORDERED 02/22/10
3800 04/09/10
6000 04/30/10
Dirtdog is offline   Reply With Quote
Old 08-29-2010, 11:17 PM   #4
boxmonkeyracing
juggernaut
boxmonkeyracing's Avatar
Drives: VRSCF, 2011 SS vert
Send a message via AIM to boxmonkeyracing Send a message via Yahoo to boxmonkeyracing
why not wait for the z? I mean some people think the z will only be an engine with a warranty. others know better.
7,500 for just the charger and intercooler? ouch. so we take a 2SS 34,000 add the price of the charger 7,500, plus install. . .what another 1,000, plus engine tuning (350-400). . .it's adding up quickly. and we haven't even touched on any other modifications that might/should be done. and we haven't even touched suspension which is what the Z will also have. . .along with looks. . .and a warranty. . .hmmmm
so roughly 8900-10000 for just a supercharger installed on a 2SS would place it around 45k. interesting. to me it isn't worth it. I'll wait for the Z.
We do not want to use the Z28 moniker on a car that does not deserve this hallowed name.
boxmonkeyracing is offline   Reply With Quote
Old 08-29-2010, 11:52 PM   #5
Ron66Vette&10SS
C5 Z06 Convert
Ron66Vette&10SS's Avatar
Drives: 66 L79 Corvette & 10 LS3 Camaro SS
Originally Posted by CoolestCamaro873 View Post
well your post just answered the original question of "why wait?" the reason is a warranty. ........ see ford racing offers superchargers for thier 5.0 GT and 5.4 GT500 and they come with warranties! when is GM ever going to learn?
Yup, what he said. I know the warranty isn't important to everybody, but it is to me. No warranty, no interest .
Previous Cars: '78 Z28, '92 Z28, '95 Z28, '85 Corvette, '01 SS, '96 Z28, '04 Z06 Corvette
Current Cars: '66 Corvette (restoring), '04 Trailblazer (rain & snow), '10 SS (FOR SALE )
Ron66Vette&10SS is offline   Reply With Quote
Old 08-30-2010, 07:29 AM   #6
davidcroft
Sellin Chevy's since '06
Drives: 2013 GXH 1SS/1LE 2012 Malibu LTZ
Plus not to mention the Z28 will have better brakes and suspension. Actually if you really couldn't wait Callaway makes a nice option with a warranty too!
davidcroft is offline   Reply With Quote
Old 08-30-2010, 09:14 AM   #7
NickeyChicago
Drives: Nickey Super Camaro
The Nickey Super Camaros also have limited warranties.
NickeyChicago is offline   Reply With Quote
Old 08-30-2010, 10:40 AM   #8
toesuf94
toesuf94's Avatar
Drives: THR #11 E-force supercharged
Send a message via MSN to toesuf94
And how much do they run?
Cars and women are both going to give you problems...but you can pay somebody else to fix your car!
toesuf94 is offline   Reply With Quote
Old 08-30-2010, 10:52 AM   #9
NickeyChicago
Stage I Starts @ approx $12,600.00
Stage II " " $18,600.00
Stage III " " $42,000.00
Old 08-30-2010, 11:09 AM   #10
CamaroMiami
Drives: 2010 Camaro 2SS LS3, 92 Camaro RS
I'm waiting for the Z.
Come on GM - I'm on your side and I know (wishful thinking) you can do it.......
CamaroMiami is offline   Reply With Quote
Old 08-30-2010, 02:22 PM   #11
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
I want a complete package: exterior/interior (as minor as I sure they'll be - no biggie, really); complete powertrain and chassis improvements that will cope with the additional power I believe will be available and be able to put it to the ground. I'm sorry - a supercharger added to an OEM LS3/L99 isn't going to cut it for me. I know there are going to be axles, driveshafts, and differentials that will be stronger, ultimately, but if we get something that will hold up to the power as well as the competition, I'm totally game.
So no - I'd wait
"...What IS true: We anticipated that this would happen - we are never finished - and yes, Ford DOES deserve to win now and then. To think that GM can come out with a car to make ford throw in the towel is simply foolhardy..." - fbodfather
Old 08-30-2010, 03:48 PM   #12
will69camaro
will69camaro's Avatar
Drives: 1969 and 2010 Camaros
Or get the TVS2300 from Magnacharger and have a warranty for much less? I couldn't wait so you know which way I went
Planetlsx.com online magazine rep
will69camaro is offline   Reply With Quote
Old 08-31-2010, 07:53 AM   #13
mondain
Drives: toyota
For me it's because just warrantying the supercharger is not enough. Every bolt, joint, u-joint, driveshaft, gear, and part that a bolt-on supercharger's power flows through is not built for that level of power.
And my guess is GM's drivetrain warranty doesn't cover me just bolting on ~200 more hp.
Unless I get a Z28 that comes with it from the factory, with every part upgraded to handle the power, and everything nicely warrantied by GM. And all I have to do is be patient.
That's why I'm waiting.
mondain is offline   Reply With Quote
Old 09-17-2010, 11:29 AM   #14
OldJedi
Use the Force
OldJedi's Avatar
Drives: 1967 FI Corvette and CRT ZL1 #336
Send a message via AIM to OldJedi
Very nicely put. It is tough waiting for this car. But like you said the Z/28 will be a complete package and not just a S/C engine with a warranty. The pictures indicate that they are making a very special car that most likely is still a year or more away from being in my garage. This is where the expression "patience is a virtue" really comes to play. It will be worth the wait, I just know.
Walk softly, carry a light saber and drive a ZL1!
OldJedi is offline   Reply With Quote
Old 09-17-2010, 11:57 AM   #15
nards444
nards444's Avatar
Drives: 1SS/RS Black
Agreed so many people have already voided warranties with headers, chips, tunes, exhaust etc.
2010 1SS/RS Black, CGM stripes, polished Rims, Tinted windows, Hurst shifter
nards444 is offline   Reply With Quote
Old 10-01-2010, 10:15 AM   #16
scomaro22
scomaro22's Avatar
Drives: 2010 VR 2SS! ,'09 Genesis
arranty!!!!!!!!!
2010 Victory Red 2SS 20" Polished Wheels
Delivered 8/3/09 !!!!!!!!
scomaro22 is offline   Reply With Quote
Old 10-01-2010, 10:32 AM   #17
c_LoW29
c_LoW29's Avatar
Drives: 2011 2SS/RS, 2010 Mustang GT
No matter what, most people who buy a Camaro be it a LS LT SS or Z28 will mod it and void their warranty anyways. So why all this warranty talk? Again this is just my opinion. If you have the money and can afford it then go ahead but we all very well know that the warranty is voided by that mass majority of people who mod their cars anyways.
TEAM L99
RIP Betty 2010 Camaro LS
PLEASE EXCUSE MY SPELLING ON THE FORUM I DO NOT USE SPELL CHECK AND MY IPHONE HAS A MIND OF ITS OWN.
c_LoW29 is offline   Reply With Quote
Old 10-03-2010, 10:28 AM   #18
68vert
68vert's Avatar
Drives: 2010 SIM SS/RS, 1968 RS convertible
I would think it is just the opposite. I doubt the 'average' Camaro buyer is doing enough mods (tune, supercharger...) to void their powertrain warranty.
I see plenty of stock Camaro's around.
2010 SIM SS/RS see garage for mods
68vert is offline   Reply With Quote
Old 10-04-2010, 02:59 AM   #19
LostInMoscow
Exiled Speed Junkie
LostInMoscow's Avatar
Drives: None
My past experience has always been that you should become very close friends with your local service manager. 'Nough said!
LostInMoscow is offline   Reply With Quote
Old 10-08-2010, 03:07 PM   #20
lil_red_v6
one wheelin
lil_red_v6's Avatar
Drives: 2004 yamaha r6
Send a message via Yahoo to lil_red_v6
DESCRIPTION:
this is why i will wait for the z28
lil_red_v6 is offline   Reply With Quote
Old 10-17-2010, 08:47 PM   #21
UCI CamaroFan
Zot!
UCI CamaroFan's Avatar
Drives: Toyota 4Runner
Are we sure that the Z/28 is going to have better brakes and suspension?
UCI CamaroFan is offline   Reply With Quote
Old 10-17-2010, 09:16 PM   #22
Sawyer
Sawyer's Avatar
Drives: '13 5.0
2013 Mustang GT Black M6
Sawyer is offline   Reply With Quote
Old 10-17-2010, 10:15 PM   #23
boxmonkeyracing
juggernaut
why wouldn't it for the price range and power suspected?
look at the videos. it will have improved suspension and brakes.
Old 10-18-2010, 09:05 AM   #24
alrox
Drives: corvette
False. Under 5% of all cars sold get modified in such a way that they lose their powertrain warranty. It just so happens that the majority of the 5% that do modify post on internet forums like this, giving you a biased view of the situation.
alrox is offline   Reply With Quote
Old 10-18-2010, 09:09 AM   #25
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
Hmm... upgrade for Z28?
GMPP releases LS9 Supercharger Kit for Camaro LS3 (and modified L99) Motor !! thecamaroguy Forced Induction - V8 287 03-29-2011 08:49 PM
Lingenfelter Supercharged LS9 Camaro Running Low 10's Tran Dragstrip, Tracking, Autocrossing, Driving Techniques Discussions 19 07-19-2010 10:01 AM
2010 Chevrolet Camaro - LS9 Powered Magazine Cover Car Sales@Hennessey 5th Gen Camaro SS LS LT General Discussions 16 03-08-2010 04:17 PM
LS9 dyno mule at Lingenfelter Performance Robin Lawrence Forced Induction - V8 7 12-09-2009 12:07 PM
I don't want to wait for HUD... (not a rant, just a question) 2kwik 5th Gen Camaro SS LS LT General Discussions 29 08-16-2008 11:20 PM
