Old 08-31-2011, 03:11 PM   #43
caverman
caverman's Avatar
Drives: '69 SS Convertible
Not trying to get in the middle of a war here and I don't even have the coilovers yet but personally I like how Mike did his using a grommet to cover the hole. That way the adjusting knobs are right there but are hidden under the carpet.
I think as long as the consumer knows there are different ways to do it then they can choose the which way the like. I'm sure there will be some that don't want to cut a 2" whole in the trunk. For me...I like the look if it being flush under the carpet.
It's nice to have choices.
Build Journal
Old 08-31-2011, 03:19 PM   #44
AutoAgenda
AutoAgenda's Avatar
Drives: 69 Camaro, 02 Escalade, 67 Eleanor
Absolutely, both options are completely flush and hidden under the carpet.
AutoAgenda is offline   Reply With Quote
Old 08-31-2011, 05:29 PM   #45
Whiteside Customs
Drives: 2011 1lt/rs, 2010 2ss/rs, 2004 GTO
I agree, nice to have choices. However, I must point out when we installed the coilovers on our shop car with the extenders in place, there was not enough room and they hit under the trunk floor. This caused bowing in the trunk floor and the extenders to bind and not be usable. Our solution was to go and clearance the top with a 2" hole and grommet so the top no longer hit against the floor. In doing this we also found that there was no longer a need for the extenders.
While I am not normally an advocate for cutting on ones vehicle, exceptions can be made as long as the modification made does not in any way hurt structural rigidity of the vehicle. As there is absolutely no stress placed on this area we can give our approval for this process.
You will also notice that the 2012 Camaro has a noticeably larger hump in the floor in the same area we have chosen to drill our 2" hole. So it is entirely possible that the method with just drilling for the extenders may work on 2012+ Camaro's. We should be testing this very soon.
Whiteside Customs is offline   Reply With Quote
Old 08-31-2011, 11:33 PM   #46
bkscott
bkscott's Avatar
Drives: 2010 Camaro 2SS/RS
I have the 2 inch holes drilled in mine, and at 1st I wasn't to sure about it, but Mikes setup make adjusting everything a 40 sec affair. Takes longer to open the hood and trunk than it does to make the changes.
94 Firebird Formula (Drowned 08/30/05)
2010 IBM 2SS/RS 6M Arrived 3/25/10.
ADM CAI, Borla Type S Cat Back, VMAX Ported TB, LG Short Throw Shifter, 1LE Shocks, Hotchkis Sway Bars, Whiteline Cradle Bushings, Custom Powdercoated ZL1's ,Nitto Motivos, Stainless Power Headers, Solo J Pipes, AAC LED Sidemarkers, ZL1 Rockers, SLP Splitter, ADM Stage II Cam,ZL1 Diffuser,Vitesse Throttle Controller.
bkscott is offline   Reply With Quote
Old 09-01-2011, 12:59 AM   #47
Whiteside Customs
Old 09-01-2011, 01:08 AM   #48
Nessal
Drives: Exige, Miata, Ghia
Also, I'm sure that if you didn't drill the first time when you installed it, you can drill from the top if you are careful enough. Make sure you get the drill as short as possible relative to the hole saw.
Nessal is offline   Reply With Quote
Old 09-01-2011, 12:55 PM   #49
AutoAgenda
AutoAgenda's Avatar
Having the adjustment knobs is amazing for that reason, no climbing under your car with a specific tool, just pop the trunk
Only minor disagreement is over the hole diameter. Some are hesitant to drill into their car, which is understandable. Looks like it works both ways!
+1
Old 09-01-2011, 01:27 PM   #50
2010 L99
2010 L99's Avatar
Drives: 2010 2SS/RS L99 RJT/Black
I hope Heintz Racing takes a look at this thread. When they installed my BCRs a couple of months ago I asked them not to drill holes in my truck but to simply set the fronts and rears at 12 and 6 and I'll try that for awhile. I hope the top of the shock isn't hitting the trunk.
USAF Retired 1994
2010 L99 is offline   Reply With Quote
Old 09-01-2011, 01:38 PM   #51
Whiteside Customs
You should be fine as long as the adjuster knobs and extenders are not in place.
Old 09-01-2011, 02:40 PM   #52
AutoAgenda
AutoAgenda's Avatar
We have never had any issues with or without the adjustment knobs. If you decided not to install the knobs then I am certain nothing is hitting. Heintz Racing is top notch they would know if there was a clearance issue.
Old 09-01-2011, 03:46 PM   #53
2010 L99
2010 L99's Avatar
Thanks guys!! They didn't say anything so I'm probably all good!!
USAF Retired 1994
Old 09-03-2011, 05:28 PM   #54
Rogan
No Pain No Gain
Rogan's Avatar
Drives: Yellow 5th Gen 2SS RS
Originally Posted by Whiteside Customs View Post
The BC racing coil overs adjust at the top of the strut in the rear. In orde to reach these a hole must be cut into the trunk. In this thread http://www.camaro5.com/forums/showth...cing+coilovers
we talk about it further.
In our opinion this is the fastest way to mak adjustments. Other companies have chosen other methods and while they work, make more work than has to be done.
All BC racing coil overs come with a set of extenders for the rear. We have found that they are not needed. We chose to use a 2" hole saw to open up the hole in the rear and using a 2" grommet the adjusters can easily be accessed by lifting up the carpet and no one would know you have them as they are hidden away.
Wish I saw this before I put up the other post I made today. So can you confirm if the bearings are needed? I saw a post where someone said they are and another showing something that says no.
2010 2SS/RS/L99 - Headers/CAI/SWAYs/CoilOvers/Tune/Steel Braided Brake Lines/Frozen Slotted Rotors
Rogan is offline   Reply With Quote
Old 09-03-2011, 09:26 PM   #55
Whiteside Customs
Can you clarify when you say bearings?
If you want to be able to adjust the coilovers then an access hole is needed in the trunk. We found through testing that a small hole for just the extended did not work as it was hitting and binding under the trunk floor. The solution is to enlarge the hole with a 2" holesaw. In doing this we found there was no need for the extenders as the adjustment knob is easily accessed. All bcr coilovers ship with the extenders so it's really your choice to use them. But the 2" hole is crucial for proper install.
Old 09-05-2011, 06:59 PM   #56
Rogan
No Pain No Gain
Rogan's Avatar
Originally Posted by Coop View Post
BC Racing has bearings? I have this very same kit and mine did not come with bearings.
Mike(Whitesidecustoms) this is what I was referring to. I don't want to install something then have to go back.
Megan Racing Street Coilover Kits | NOW AVAILABLE| LOWEST PRICE! | FREE S&H!! AJ@ECSMotorsports Suspension / Chassis / Brakes 35 11-13-2010 04:51 PM
Vengeance Racing GIVING AWAY $500.00 CASH.. Step inside for details!!! Ron@Vengeance Engine Internals 4 08-24-2010 07:47 AM
Vengeance Racing GIVING AWAY $500.00 CASH.. Step inside for details!!! Ron@Vengeance V8 Bolt-Ons & Tunes 0 08-10-2010 10:31 AM
Official Victory Racing Turbo Kit Post VictoryRacingEngines Forced Induction 44 07-26-2010 02:45 PM
KW V1/V3 Coilover Kits !!!! SupremacyCustoms Suspension / Chassis / Brakes 38 04-28-2010 11:37 AM
