Cold Air Inductions
Old 08-29-2010, 07:26 PM   #1
010 Camaro SS
010 Camaro SS's Avatar
Drives: 2010 Camaro SS 2SS
Hypertech Tuner
Anyone else running the Hypertech 32006 tuner...I have
no issues at all would just like to here from others...There
was a update i did today 0 - 60 throttle restriction...Can't
wait to run it...
010 Camaro SS is offline   Reply With Quote
Old 08-29-2010, 07:30 PM   #2
ArkySS
Camaroless for now...
ArkySS's Avatar
Drives: 2014 Blue Topaz Silverado
That takes the Torque Management off and it makes a difference in acceleration. I wish they would add the option to change the shift firmness like they have on other models.
It was fun while it lasted.....
ArkySS is offline   Reply With Quote
Old 08-30-2010, 12:02 PM   #3
grocerygetter
instigator
grocerygetter's Avatar
I used it...it was awesome.
-John S.
Thanks to:
Tony@ dv8motoring
TCAudio in Benton AR
Old 08-30-2010, 12:05 PM   #4
Ivan @ Southwest Speed
PM us for a quote if you're interested in on of their products.
We are an authorized Hypertech Dealer.
Thanks,
Ivan
Old 08-30-2010, 02:08 PM   #5
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
I have one as well. Very nice setup with lots of options. I wish it would have a monitoring program but that's about the only drawback. I happen to know the tuner for HT, so that helps. The 0-60 throttle restriction is tuning of the TM for best results. As many tuners will tell you, turning TM totally off isn't ideal for a DD. TM is what gives you smooth take off and saves your drivetrain. It makes for a better daily driving experience. We can all agree that GM put in too much TM from the factory. Dialing it back is definitely a plus and gives you a more "muscle car" experience without being too harsh.
ArkySS:
The HT unit does have the option to change shift firmness. You dial in a % firmer than stock. You can also adjust gear change RPM as well as rev limiter increase.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 08-30-2010, 02:29 PM   #6
ArkySS
ArkySS's Avatar
It does not have it for the 2010 Camaro SS per they e-mail I got from hypertech?
Max Energy Power Programmer - Part #32006
Performance Gains
Premium Octane: +20HP +18TQ
Regular Octane: +14HP +13TQ
Adjustable Features
* Shift Point -500 to +500 RPM
* Speedometer\Odometer Correction For Gears 2.56, 2.73, 3.08, 3.23, 3.42, 3.73, 4.10, 4.56, 4.88 & 5.13
* Speedometer\Odometer Correction For Tire Sizes 24-30 inches 1/4 inch increments
* Top Speed Limiter 25 - 75 MPH in 5 MPH increments, 81 to 255 MPH to match speed rated tires
* Rev Limit 5700 to 6700 RPM in 100 RPM increments
* 0-60 MPH Restriction
* DTCs Read and Clear
* Return Back To Stock
* Internet Updateable
* Disable Active Fuel Management System
Old 08-30-2010, 02:34 PM   #7
axis
Search Ninja
axis's Avatar
I was looking at my HT tuner disk and it says it's there. I haven't personally messed with it, but I thought I remembered it having that option. I'll have to plug in my HT unit to see if it's actually there. You're making me think too much,
Edit: Just plugged mine in and it's not there. Guess the disk is a generic disk.
Halltech CF 102 fed
Old 08-30-2010, 03:42 PM   #8
ArkySS
ArkySS's Avatar
Yeah I hinted at helping them 'develop' that part of the tuner.......they said keep checking the website.....gee thanks for that :(
Old 08-30-2010, 03:46 PM   #9
axis
Search Ninja
axis's Avatar
I'll call my guy and see if there's any plans to do so. I'll let you know when I find something out.
Halltech CF 102 fed
Old 08-30-2010, 09:21 PM   #10
010 Camaro SS
Axis...What's not there...I'm missing something here...And after
reading this is taking off the throttle restriction is hard on the car...
Just trying to understand all this...
Old 08-31-2010, 12:01 AM   #11
axis
Search Ninja
axis's Avatar
The firmer shifting isn't on the Camaro tuner. You can adjust gear change RPM though.
Yes taking off throttle restriction is harder on the car. Basically it's decreasing the amount of torque management that GM put into the tune. I wouldn't worry about it being detrimental though. You will definitely be able to feel the difference and you'll like it. It's one of the first things all of the tuners decrease when doing the tune. You can also experiment with AFM on and off. I only noticed a 0.2mpg difference in a month long experiment of daily driving. Needless to say, I turned mine off.
Halltech CF 102 fed
Old 08-31-2010, 12:43 AM   #12
ADKINS PERFORMANCE
Banned
Drives: boosting camaro
Have tuners instock will beat ones price. Also i called on the firmness of shifting and they said they are coming out with more and going to make it where you can download off there site for people that already have it
ADKINS PERFORMANCE is offline   Reply With Quote
Old 08-31-2010, 10:41 AM   #13
ArkySS
ArkySS's Avatar
Torque Management (as I understand it) is there to prevent 'flair ups' aka hitting the rev limiter more frequently. Let us know a timeline on when they plan on upgrading the software!
Axis did you change shift points?
Old 08-31-2010, 11:31 AM   #14
ArkySS
ArkySS's Avatar
Hypertech lives! So anything you can share????
Need help with SCT X3 tuner... Fiftydriver Tuning / Diagnostics -- engine and transmission 3 07-12-2010 07:54 PM
Hypertech Tuner RobbRock V8 Bolt-Ons & Tunes 0 04-02-2010 02:50 AM
SCT Tuner question JustaCamaro Tuning / Diagnostics -- engine and transmission 3 02-28-2010 07:32 PM
TUNER GALLERIA Chicago Car Show @ Donald E Stephens Convention Center! CarNutzCustomz USA - Great Lakes 0 01-24-2010 12:40 AM
TUNER GALLERIA | Houston, TX | Nov. 26-29 CarNutzCustomz USA - Texas 3 12-07-2009 04:07 PM
