Old 08-30-2010, 10:15 PM   #1
cwalms
cwalms's Avatar
Drives: 2SS Red Jewel Tint
Send a message via Skype™ to cwalms
Hot Air from Vents
Has anyone else had a problem with hot air leaking from the dash vents. I noticed it was getting hotter inside the car over the past couple days and today felt hot air coming from the vents. The t-stat was on cool and the fan was off and still heat was coming in the car. If anyone has experienced this please let me know.
Thanks,
Chris
cwalms is offline   Reply With Quote
Old 08-31-2010, 01:23 PM   #2
TooCool5
TooCool5's Avatar
Happens to me on hot days after the car has been parked in the sun.
Hit the recirc button and it should go away.
Old 08-31-2010, 01:43 PM   #3
Waco
Layla
Waco's Avatar
Drives: '10 2SS/RS, LS3, CGM/IO
Yep...turn on the fan for a minute to clear the warm air out of the tubes.
Waco is offline   Reply With Quote
Old 09-01-2010, 02:02 PM   #4
cwalms
cwalms's Avatar
Thanks, I'll give it a try.
Old 09-07-2010, 09:08 AM   #5
ZombieEatsYou
ZombieEatsYou's Avatar
Drives: "Bmblbee" 2010 RY 2SS/RS. VIN 12043
I noticed it also and wondered if I was crazy. Also feels like hot air coming from under the steering wheel as well. I've done the fan trick but doesn't help much. Sometimes it's so bad I have to close the vents.
ZombieEatsYou is offline   Reply With Quote
Old 11-10-2010, 11:40 PM   #6
kbui
kbui's Avatar
Drives: 85 Vette, 07 Escalade ESV, 03 GMC,
I was searching this problem as well. Even when the temp outside is in the 60-70's, I can't just turn on the fan with the air off. It gets fairly warm. My options so far are to roll down the windows or have the air on. I was expecting colder air if I have the fan on high and temperature to cold and the air off with colder outside temperatures. Am I missing something? or do I need to take it back in to the dealer?
ADM Performance installed and tuned: Maggie, Stainless Works Power LTs, ADM race cai, ADM ZL1 scoop
Whiteside Customs Super Street 2 Package w/ coilovers
BC Racing Coilovers and lowered, Whiteline Bushings & Swaybars
MBRP catback exhaust, ZL1 bumper conversion, Drake billet shifter, Hurst paddles, NLP rear spoiler, OEM GFX, Vis Racing hood, ASA GT5 wheels
kbui is offline   Reply With Quote
Old 11-11-2010, 12:00 AM   #7
christianmotox
christianmotox's Avatar
Drives: ( . )( . )
You also want to make sure the temperature knob is set to cold.
christianmotox is offline   Reply With Quote
Old 11-11-2010, 04:30 PM   #8
kbui
kbui's Avatar
Went to the dealer today about the warm vented air and was told that the outside air basically flows thru the engine compartment and very little of the outside air goes directly to inside the car. Hence you do not really get cool outside air??? This is even more noticeable as the engine heats up and the "outside" gets warmer. Things might improve a little bit as the car is cruising at higher speed. It doesn't have real vents to get the outside air directly into the interior of the car.
Old 11-11-2010, 05:22 PM   #9
Reaper1a
Reaper1a's Avatar
Drives: 2010 Summit White 2LT/RS
Sure it does...they're called windows
But seriously, just set your dial to recirculated air and it should stop pulling the air out of the engine bay That mixed with the previous post that said to make sure the temp is set to cool should fix the problem. If it doesn't, I would have the dealer check the seals around the vents.
Every man is a damn fool for at least five minutes every day; wisdom consists in not exceeding the limit.
-Elbert Hubbard
Reaper1a is offline   Reply With Quote
Hot air Intakes -By Kenne bell ADM PERFORMANCE Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 66 02-08-2011 09:33 PM
**K&N TYPHOON and AIRCHARGER Intake kits ~ 18+ HP! ~ Lowest Prices!** Circuit Motorsports V8 Bolt-Ons & Tunes 81 05-24-2010 05:21 PM
List of Intakes that will work with the TVS-2300 MagnaCharger JJ2010 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 26 03-19-2010 03:11 AM
Tuning for dummies Milk 1027 Tuning / Diagnostics -- engine and transmission 43 03-17-2010 09:06 AM
Why RAM Air is a myth!!! Long Read (Wall of text) live2well Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 80 11-02-2009 04:34 PM
