Cold Air Inductions
Old 08-30-2010, 11:51 PM   #1
KB2010
Drives: 2010 Camaro SS
Did I just ruin my clutch?! Help please!
Hi all, I've been reading all sorts of complaints and such about the Camaro's clutch, and other connecting parts that I have no idea about.
My Camaro: 2SS, Manual.
So I had my little cousin over, and he wanted to go for a ride. I did a hard start from 1st gear at about 5-6k RPMS. When I went to shift to second, I noticed my clutch was only coming back up half way. Now when I press the pedal, it is very soft coming up. I thought maybe I over heated it or something, so i let the car sit for a bit. When I went back, I didnt see anything leaking underneath, but when I sat inside and pressed it (car was off), it was still soft, and I could hear like a puff of air or something when the clutch came all the way back up.
Im going to call the dealer tommorow, but I want to be armed with some knowledge first to see if I can get them to replace it (which seems to be a task and half based on what I am reading here). Has this happened to anyone else? Can anyone explain to me what I may have done to the car (and if I should NEVER do that again? This was probably the first time I ever drove the car REAL hard, I babied it otherwise.) The car has about 12 000 KILOMETERS on it.
Thanks all
KB2010 is offline   Reply With Quote
Old 08-31-2010, 01:02 AM   #2
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
Drives: To many to list
Sounds like you got the clutch hot and that got the clutch fluid hot to the point that it dos not let the pedal come back all the way back, Its normal on this car that is why some of us went to dot 4 and got a second Reservoir for the clutch, One more thing is change the clutch fluid once a month.
Old 08-31-2010, 01:04 AM   #3
KB2010
Thank you so much for the reply. Will my clutch pedal get stiff again once it cools down a bit?
Old 09-01-2010, 12:49 AM   #4
MillerTime
Blowin the doors off!
MillerTime's Avatar
Drives: A 2013 SS RS 6M SR
Dosn't the 2nd clutch reservoir negate having to change out the fluid?
2G1FS1EWXD9163847
MillerTime is offline   Reply With Quote
Old 09-01-2010, 08:03 AM   #5
SlingShot
SlingShot's Avatar
Drives: 2012 ZL1 - #670
Thanks all
From 5k-6k launch ... You're lucky you didn't break something ...
Old 09-01-2010, 08:46 AM   #6
Russell James
Russell James's Avatar
Drives: '69 Z28, '10 NASA TA2, '15 1LE SS
Location: In the garage fixing stuff, track breaking stuff, at work paying for stuff. Or check the bar.
If it doesn't after a day or so of driving, it's going to need to be bled.
There is a procedure in the service manual and dealers have a tool to do it.
I wouldn't do that again. High rpm clutch dumps will trash everything between and including the flywheel and axles.
Old 09-01-2010, 11:30 AM   #7
2SSRS@Gen5diy
You still need to change the fluid before and after track days.
Old 09-01-2010, 03:41 PM   #8
KB2010
Thanks for the responses guys. Lesson learned on doing what I did. In any case, I took it to the dealer, and they took it for a ride...
"Everythings ok!" Is what they said
However, I know how the car FELT and how it feels now, and they are NOT the same. The clutch pedal is too soft coming back up. So can I conclude that bleeding the line is what will probably remedy the issue?
My other issue is, if any of you experienced chaps can help... The dealer is insisting it is fine, I think they gotta get down there and look. How did you guys convince them to do so? I know I can just yell and scream and have them do it, but I'd like to stay at a reasonable status with the techies at this point, just in case the damage (if there is any that is) done was my fault, they may be forgiving and warranty it.
Old 09-01-2010, 04:05 PM   #9
Russell James
Ask if they have any other 6 spd SS's there you could sit in and compare the clutch feel. If it feels different ask them to look this up in the Service Manual:
Clutch
Clutch Symptoms
Clutch Pedal Spongy, Low Pedal Effort, Hesitates on Return
When you go to that symptom, the first step is to bleed the hydraulic system. The manual then links you to the directions for bleeding.
If that doesn't correct it, it then lists the parts that could cause it and order they should be checked and replaced if needed.
Basically the pedal should go in and out, no odd feelings, same as the day it was new.
I want a new clutch, you too????? Sign here tjbusa V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 370 08-10-2013 04:27 AM
Clutch fluid contamination problems on Vette fixed for Camaro??? LDGn63 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 11 05-28-2012 10:17 PM
Clutch Problem phenixdragon Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 20 08-22-2010 11:51 AM
Oil Change Ramp mjlash22 Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 17 01-21-2010 11:40 PM
