08-31-2010, 01:32 PM | #1 |
Oil Level Question
I'm posting this from my Blackberry so I hope it works out.
OK, I proceeded with the first oil change yesterday - it all went smooth as butter. 8qts of oil went in as indicated for LS3 & L99 engines. When I checked the dipstick, the oil level appears to be at the top (highest) dimple mark within the cross-hatched area. IOW, top of the operating range. Maybe I'm being over-cautious, but is that considered too full or is it good to go?
08-31-2010, 02:02 PM | #2 |
Older Than Dirt
Drives: 2010 & 2013 Camaros Join Date: Apr 2010
You are good. If it drops from there between oil changes, now THAT would be bad.
2010 2SS TE, 1 of 822/2013 Camaro ZL1 vert, 1 of 54
08-31-2010, 04:15 PM | #3 |
Drives: 2011 2SS m6 Join Date: Apr 2010
Same thing happened to me, you can read my fiasco at http://www.camaro5.com/forums/showthread.php?t=101639
From what I understand there could be some residual oil left over, depending on how you drained it. I used ramps so most likely there was a good bit left over. The dipstick was measuring slightly over that 3rd dimple. I'm not sure how much extra would be warrant for concern, I didn't want to take a chance so I just did it again.
7/7/10 Status: Delivered
08-31-2010, 04:56 PM | #4 |
Hmmm, let's hope I don't get "Nards444" upset because of my post here. Har har.
My backyard has a relatively decent slope, so I rolled the car onto a couple 2" thick paving stones. It made the vehicle quite level and offered plenty of room to get to the pan. I may just let out the 1/2qt so the dip-stick reads like it did from the factory.
08-31-2010, 05:07 PM | #5 |
So It'll Go Down Easy
Drives: Camaro SS/RS Join Date: Aug 2010
is this your first oil change, ever? or have you just never read a dipstick before? the dipstick is usually marked at the bottom with a "range" to shoot for and to keep track of.
08-31-2010, 05:53 PM | #6 |
Greasy:
I assure you this is not my first oil change ever; this is the first oil change for the Camaro, though. I have read many a dip-stick from lawnmowers to Mitsubishi diesels; I only asked since some people are very finnicky about their oil levels, while others let the higher reading slide. Some are of the thought that these performance-oriented cars have slightly different engine parameters than a truck or SUV. The original reading on the Camaro's dip-stick hardly ever changed from the factory fill: mid-mark of operating range.
Similar Threads | ||||
My V6 oil change experience | convert | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 38 | 04-08-2014 04:15 PM |
First Camaro DIY Oil Change = 4 Hours -FML | Infern0 | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 63 | 09-25-2010 03:18 PM |
L99 Lifters | Ohten | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 25 | 06-29-2010 09:33 AM |
Major U.S. oil source is tapped | KILLER74Z28 | Off-topic Discussions | 32 | 10-30-2007 09:47 AM |
