Old 09-01-2010, 03:07 AM   #1
Arthur 818
Arthur 818's Avatar
Drives: 2010 Camaro 2LT/Fully Loaded
Send a message via AIM to Arthur 818
Wink Wiring LED Halos as my foglights
Since my cars at the body shop, and the bumper is off. The dealer decided to let me do a few mods. First im installing a SUPPER HORNS on it then i want to change my fog lights into HALO RINGS, but i DON'T want to spend over $150 for the oracle ones, instead i was thinking getting the diameter of the foglights and wiring some cheap halos shown in the pictures under(If they fit). If you guys know a better/cheaper way to change your fog lights into halos let me know....Thanks
Arthur 818 is offline   Reply With Quote
Old 09-01-2010, 03:25 AM   #2
CamaroFTW
CamaroFTW's Avatar
Drives: 2010 Camaro 2SS/RS-Rally Yellow
Send a message via MSN to CamaroFTW
Those are from computer fans and meant for indoor use (less then $15) ...will not likely last long from shock and enviroment.
Save up for the ACC ones that are SMD's....seriously
CamaroFTW is offline   Reply With Quote
Old 09-01-2010, 03:29 AM   #3
Arthur 818
Arthur 818's Avatar
Yeah I know Im trying to find good ones the diameter of the foglights. How much are the ACC ones. Im not willing to pay anything over $50 I dont think there worth it. Anything over 150 I can use for better mods. But if anyone out there did something better or found a part worth the money feel free to let me know.
Old 09-01-2010, 05:26 PM   #4
LosXC451
LosXC451's Avatar
Drives: 2010 SS SIM w/ RS
You could always try this
LosXC451 is offline   Reply With Quote
Old 09-01-2010, 05:46 PM   #5
Arthur 818
Arthur 818's Avatar
Wow that might actually work...thanks bro this was actually helpful..
Old 09-01-2010, 05:57 PM   #6
AACstyle
AACstyle's Avatar
Drives: www.CamaroLighting.com
Over $150? We only charge $95
http://www.camaro5.com/forums/showthread.php?t=66251
The halos you pictured are CCFL, not LED, they may work, don't want to come off as negative so I will just leave it at that.
Anyway, if you decide you want to get our halos let me know. We have some incentives like free shipping right now that may help you out.
AACstyle is offline   Reply With Quote
Old 09-02-2010, 02:37 AM   #7
Arthur 818
Arthur 818's Avatar
Not bad...What comes with that package ? Just the halos...its like the whole foglight...and how easy is it to install it ? and how early would it be shipped. Thanks.
Old 09-02-2010, 12:48 PM   #8
Kendell347
Doc
Kendell347's Avatar
Drives: BLACKOUT & Fifty
Personally I like to do a job once and be done with it. If you use inferior products, you will only have to take the bumper off and redo all the work. Personally I would go for the AAC stuff and be done with it. Just remember CCFL's are very sensitive to impact / heat / cold changes compared to LED. Just a tip
1100-7/20/2009 * 6000-2/4/10 Proud Owner of Autographed Litho # 128Mods: CAI CAI, Emblempros Dash Plaque, R/C Lic. Plate, Fbodfathers signature, AAC SMD SML, AAC P13 LED DRL, TF center console, Full dash ABL, Noweed Exhaust Diverters, Heritage Grille, Door Projectors, 20watt LED reverse lights with strobe features, S.S. black billet grille with air scoops, custom designed engine cover, custom designed "BLACKOUT" cross drilled / slotted rotors, Borla S-type exhaust, Elite Engineering oil catch can, Nitto Invo Tires WWW. NY5THGEN.COM
Kendell347 is offline   Reply With Quote
Old 09-02-2010, 06:36 PM   #9
AACstyle
AACstyle's Avatar
You get the actual Halo rings, you install into the existing light housings.
Here is a HD video:
Old 09-02-2010, 10:55 PM   #10
agkelly73
agkelly73's Avatar
Drives: 2010 2SS/RS
Arthur, I have the LED halos for both the headlights and the foglights from AAC. Absolutely love them and the foglights are SIMPLE! Just need a dremel (if you don't have a band saw), some epoxy to hold rings in place and some clear silicone. Wire them in and that's it.
agkelly73 is offline   Reply With Quote
Old 09-02-2010, 11:16 PM   #11
Arthur 818
Arthur 818's Avatar
Ok yall convinced me…ACC ill pm you later...give me info on how to order them...and how long untill it ships. I'm in SoCal..
Old 10-14-2010, 04:21 AM   #12
Arthur 818
Arthur 818's Avatar
Here are the final results enjoy
http://www.camaro5.com/forums/showthread.php?t=110805
dont be a cheapass, foglight, halo, led, supper horn
New Headlight and Tailight LED Halos!!!! Wes@Flashtech Exterior Parts & Accessories 23 12-16-2010 10:40 AM
DIY - Install Flashtech 24 LED foglights (Non-RS) wylde1 Camaro DIY & HOW-TO instructions & discussions 10 12-02-2010 09:46 PM
Group Buy!!! LED Headlight and Tail Light HALOS, Only $99 Each!!! Wes@Flashtech Exterior Parts & Accessories 51 09-27-2010 09:19 PM
Just Installed Halos and LED fog lights steallife904 Cosmetics and Lighting Modification Discussions 26 08-24-2010 10:09 PM
Black powder coated Phantom grille + LED halo headlights and foglights install klove Cosmetics and Lighting Modification Discussions 88 04-19-2010 03:52 PM
