JUICEDMOTORSPORTS
Old 09-01-2010, 09:29 AM   #1
autobotaz
Drives: Black 2010 Camaro LS
Barton Shifter Vibration Disappears w/ windows down
Sounds weird I know but it was repeatable several times this morning.
Installed my Barton shifter about two weeks ago and absolutely love it but it does tend to have some vibration feedback, at upper rpms (4k-5k), that I can hear and feel through the stick.
I am 100% sure it is installed correctly and yes the vibration is coming from the shifter as I can feel it and see it also. At least it is translating through the shifter.
Morning temps the last few days have been around 70 degrees here so I had the windows down driving to work. I noticed yesterday that I neither heard nor felt any of the vibrations through my shifter when accelerating hard. On the way home when it was close to 100 degrees I had the windows up and yep there was my shifter vibrating when briskly accelerating.
So this morning had the windows down again and same thing no vibrations. Put the windows up and accelerated hard and there it was again. Immediately put the windows down and accelerated hard, no audible vibration or vibrations felt through the shifter.
Now I would call myself crazy and this a fluke if I couldn't repeat it which I have been able to so far. I am going to test again this afternoon.
Curious to see if any Barton or Hurst owners having vibrations can test this as well.
I am wondering if by opening the windows the lack of pressure in the cabin is dissapating some overall vibrations that just happen to be translating through the shifter. If the tranny was the source of the vibrations, I don't see how the windows would make a difference.
Any ideas???
autobotaz is offline   Reply With Quote
Old 09-01-2010, 09:53 AM   #2
Blade
Blade's Avatar
Drives: 2016 Camaro 2SS BVM 2SS
I am guessing you have the M6. From what I have heard some of the aftermarket shifters have had vibration issues, might want to check with Barton, and see if they have a quick fix solution for it.
Blade is offline   Reply With Quote
Old 09-01-2010, 10:08 AM   #3
autobotaz
Yeah I talked with Dave already and he suggested some dynamat on the transmission link where it connects with the shifter.
Its not that bad but the fact that it goes away with the windows down is puzzling.
Old 09-01-2010, 10:47 AM   #4
lock
lock's Avatar
Drives: 11 2SS/RS E-Force Supercharged
I wrapped teflon tape on the shifter shaft and a nylon washer on the shift ball jam nut. Removed all my rattles. You will probably always feel it but hearing it can be fixed.
11 IOM 2SS/RS E-Force Supercharged. 616 RWHP/578 RWTQ. Click link for my journal!!!
lock is offline   Reply With Quote
Old 09-01-2010, 11:10 AM   #5
autobotaz
Like I said the weirdest thing was the affect the the windows being down had. There was no noise or vibration from the shifter at all. I just want to know why that would happen.
Mine vibrates even without the shifter ball installed.
Not saying that the teflon or washer wouldn't help though.
Old 09-01-2010, 12:05 PM   #6
armysig
Catch me if you can
armysig's Avatar
Drives: 2012 IOM ZL-1
Check the dust boot under the shift. If is not attached correctly it can give the effect of a shaking shifter.
armysig is offline   Reply With Quote
Old 09-01-2010, 12:19 PM   #7
autobotaz
Thanks, I'll double check it but I know it was on correctly last time I was underneath the car.
Baffled by the windows being up or down having an affect on it.
Old 09-01-2010, 03:27 PM   #8
Nutbutt
Nutbutt's Avatar
Drives: 2011 RJT 2LT/RS Convertible
Are the centering springs installed correctly?
1st IPF Supercharged 2011 2LT/RS RJT Convertible
Nutbutt is offline   Reply With Quote
Old 09-01-2010, 03:53 PM   #9
ddunerider
So-Cal Race team!!
ddunerider's Avatar
Drives: Tahoe LTZ,2010 2SS/M6 Camaro
Send a message via AIM to ddunerider
Really I'm going to try this.......mine is not bad at all but just a little.Doesnt brother me but some others hear it...
WE RACE DEEP!!
BBK Intake, Flowmaster AT cat back Barton shifter,Painted stripes,,Heritage grill,LED DRLs, Smokin Tires!!
ddunerider is offline   Reply With Quote
Old 09-01-2010, 03:55 PM   #10
ddunerider
So-Cal Race team!!
ddunerider's Avatar
Windows down I'm sure you cant hear it with the exhaust and wind make more noise than the shifter
WE RACE DEEP!!
Old 09-01-2010, 06:11 PM   #11
autobotaz
Nope I have excellent hearing but I can't feel any vibes through the stick at all. Did it on the way home too.
Old 09-02-2010, 10:32 AM   #12
clg_98ta
clg_98ta's Avatar
Drives: 2010 Camaro 2SS
I've done the dynomat and teflon tape and still have vibration at higher RPMs - not bad, but its there.
Old 09-02-2010, 03:16 PM   #13
ffrcobra_65
shifter noise and window being up/down...I can't imagine a connection. Like someone said, road and wind noise will drown out faint rattles/vibrations in the cabin. If the rattle noise comes on with window up, and goes away with window down...maybe the noise is not from the shifter, maybe it is from the window or door panel and your left ear is no workie workie very well.
Old 09-02-2010, 03:49 PM   #14
oachalon
Drives: 2010 Camaro 1SS
The windows down might change the resonant frequency of the body enough for the particular problem not to vibrate. The frequencies the body exhibits will change based on temperature, windows up, windows down, loading (people in car, objects in car), etc.
oachalon is offline   Reply With Quote
TAG's 2010 THRSS #2 TAG UR IT Member Car Journals 3129 08-14-2014 10:29 AM
Barton Industries Shifter handle valed4313 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 14 12-11-2010 12:01 PM
Barton Shifter motor1 Transmission / Driveline 1 07-31-2010 10:13 PM
Barton Industries shifter Chief Bob Vendor and Seller review / feedback / experiences 1 07-16-2010 08:44 PM
The BEST upgrade for your new Camaro - Camaro Six Shooter shifter MTI Racing V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 19 07-23-2009 03:52 PM
