| 3rd Generation Camaros 1982-1992 Camaros |
Thread Tools |
![]() Drives: Camaro Join Date: Sep 2010
'91 Camaro - low oil pressure
Hi there - I have a 91 Camaro with a 305 and 119,000 miles.
My oil pressure has been low the klast few days. The first thing I did was check the level which is fine. I have no means of checking it any other way; I have no gauges, and am not very mechanically inclined. Typically, when I start the car, the psi is @ 60 - now it is at 30. And it slowly decreases to about 15 as the engine works up to operating temp. It will stay at 15, and flooring the gas on an open road does not bring the pressure up - which it used to. Otherwise, everything is fine - no wierd noises, no sputtering, no stalling, nothing. The only odd thing is that when I turn the air on, the oil pressure gauge spikes down into into the red, and then snaps back up when I hit the gas. Is this indicative of a bad fuel pump, or possily something else? Thanks in advance for any ideas. |
![]() Drives: Everything from soup to nuts Join Date: Jul 2010
My guess would be that the bearings are worn out or the oil you are using has too many miles on it or the engine is overheating and using the oil to cool the motor.
Take it to a mechanic and have him find out if it is a bad oil sensor or a bad engine. How many miles are on the oil and what manufacturer and grade of oil do you have in your engine? |
Resident "Fbody" Member
These cars are famous for Oil Pressure sending units going bad ($20 part) that bolts into the bottom driver side of your block, change that first and you might be surprised!
Good Luck. Mark
CCFBG-1 1991 Camaro RS Phantom Grey/CCFBG 2-2010 2LT RS Black on Black Mark....President/Founder of www.CCFBG.com |
| Thread Tools | |
| DIY: Camaro Oil Change | adub4185 | Camaro DIY & HOW-TO instructions & discussions | 165 | 07-17-2012 01:59 PM |
| best synthetic oil to use | hollywoodjose | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 111 | 12-13-2010 12:22 PM |
| Pedders Suspension Benchmark Track Testing and New Jersey Track Day | Info@PeddersUSA.com | USA - NY / NJ / PA | 35 | 10-26-2009 05:20 PM |
| Answeres to questions I have stumbled on | dieseldave24v | 5th Gen Camaro SS LS LT General Discussions | 13 | 02-23-2009 06:56 PM |
