sjm autoprod
View Poll Results: What do you think of the look?
Do you like it? 17 35.42%
Do you hate it? 31 64.58%
Voters: 48. You may not vote on this poll
Old 09-02-2010, 09:40 AM   #1
aberafik
MURDER SS
Drives: Black 2010 Camaro SS Murderd Out
Send a message via AIM to aberafik Send a message via Yahoo to aberafik
Painted inside my Engine late at nite in the dark
I started around 11pm finished at 7am let me know what you guys think
aberafik is offline   Reply With Quote
Old 09-02-2010, 09:43 AM   #2
camaropete
I love crepes
camaropete's Avatar
Drives: 2010 Camaro SS RS
Send a message via AIM to camaropete Send a message via Yahoo to camaropete
Not too bad. I would probably give the two covers a light sanding and drop a couple more coats on there in order to get a nice gloss look like the air intake pipe.
camaropete is offline   Reply With Quote
Old 09-02-2010, 09:58 AM   #3
ducq
ducq's Avatar
Drives: 2010 Camaro 1SS/RS LS3 blck w/ IOM
what did you spray the big chevy padding lining under the hood with?
ducq is offline   Reply With Quote
Old 09-02-2010, 10:38 AM   #4
aberafik
MURDER SS
Regular Red sprey paint. I had to use lots of coats.
Old 09-02-2010, 11:52 AM   #5
Stovall-SS
Stovall-SS's Avatar
Drives: 2010 SS RS M6
Yeah im gonna have to second that! Give it a nice 1000 or more Grit sand before each coat and a thick clear coat. And dont do it in the dark!
*2010 2SS M6 RS 6.2 "LSX 427 to come"
*2008 Z71 X/cab Silverado 4x4 5.3
*2001 2500 Suberban 4x4 8.1 "The Beast"
RIP 1998 S-10 4.3 V-6 Turbo "You will be missed"
Stovall-SS is offline   Reply With Quote
Old 09-02-2010, 12:00 PM   #6
DocHolliday
DocHolliday's Avatar
Drives: '14 Blade Silver Z51
Looks pretty rough brother. I've seen some very nice DIY paint jobs here that look like they were done in a spray booth, this looks like a rattle can job. Sorry man, just my opinion.
Say When
DocHolliday is offline   Reply With Quote
Old 09-02-2010, 12:08 PM   #7
aberafik
MURDER SS
So what should i use to remove and start over, Plus im used a 2 megapixal camara phone with no flash to take all pics of my car. And what items you dont like. The hood roof is ruff texture material.
Old 09-02-2010, 12:09 PM   #8
JB @ C and L Machine
Drives: Ordered 2011
Did you paint that or did Stevie Wonder??
JB @ C and L Machine is offline   Reply With Quote
Old 09-02-2010, 12:10 PM   #9
aberafik
MURDER SS
And can you guys recomed a paint to use? Im not going to a body shop to paint under the hood. So far i like the look of the red and black engine. It looks better then before but it needs to be redone.
Old 09-02-2010, 12:34 PM   #10
clg_98ta
clg_98ta's Avatar
Drives: 2010 Camaro 2SS
Why did you paint in the dark?
Old 09-02-2010, 12:38 PM   #11
se7en
Drives: 87 Pinto on 32's
Sandpaper and your see a big difference
se7en is offline   Reply With Quote
Old 09-02-2010, 12:40 PM   #12
se7en
On the cover's you need to use paint specifically for plastic. Dupont makes some that i've used before.
Old 09-02-2010, 12:50 PM   #13
aberafik
MURDER SS
I dont have a garage i live in a apartment
Old 09-02-2010, 12:53 PM   #14
Rockin the BlueSS
The New Guy
Rockin the BlueSS's Avatar
Drives: 2010 2SS/RS IBM M6
use some sand paper and paint thinner to try and remove the paint...
then take 1000 grit to it ans see how flat you can get it (i wouldnt use a machine sander it has a tendancy to melt the plastic)
then try a nice layer of spray on primer... (you may want to use a plastic adhesion promotor before this step but its up to you to try...)
let that dry for a while (a thick layer takes a long time to set to be hard) then sand that down with 200-400 gritt this will help smoth out the grainy testured cover...
then try the paint, then wet sand (200-400 grit wet) and then the clear coat...
see where that gets you... good luck
BTW: i like the what you are trying to achieve just a little more work is needed...
Rockin the BlueSS is offline   Reply With Quote
engine, paint, red
g5cr cai system anybody install or looking at one "pics" camarossrs2150 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 41 07-14-2011 09:26 PM
AirAid Cold Air Intake anyone? Flynnaz Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 12 01-01-2010 10:05 PM
LS9 SC old news. Here comes the LSX. 850HP, 840 lb-ft of Torgue 13F20 5th Gen Camaro SS LS LT General Discussions 15 09-22-2008 05:35 PM
Dark Sucker Theory Angrybird 12 Off-topic Discussions 9 08-04-2008 10:17 AM
