Old 12-08-2008, 11:46 AM   #1
SWHCPA
Snow White can be naughty
SWHCPA's Avatar
Drives: '10 Camaro/'67 Mustang
Send a message via AIM to SWHCPA Send a message via Yahoo to SWHCPA Send a message via Skype™ to SWHCPA
Brake caliper upgrades
OK - forgive me for having some time on my hands this morning. I have my Mother's one-owner 1967 Mustang (don't get excited - it's a coupe with 3 on the floor and a 200ci 6-cyl). One of the more significant engineering issues is the lack of braking authority in 4 drums.
Therefore, since I've been old enough to write the check for my own ride, I've over-braked everything I've ever owned...if there was an option, I got it.
Now...there's the 4-piston Brembos on the SS version of the 2010 Camaro. I can dig this with the 8-cyl and all. However, can anyone shed light on the interchangability of the single piston on the 2LT model and the 4 piston on the SS'. Any thoughts on feasibility, cost, etc?
As I get older, my only two criteria on the functionality of a car is to have an air conditioner that blows snow in Dallas in August and brakes that start to stop as I start to move my foot to the pedal.
Thanks~!
SWHCPA is offline   Reply With Quote
Old 12-08-2008, 01:07 PM   #2
LSxJunkie
Snark snark snark
LSxJunkie's Avatar
Drives: RX350
Thanks~!
It should be really straightforward. You just need to make sure you get the caliper bracket; everything else should fit. However, it'll also be expensive. Brembo stuff ain't cheap and OE stuff ain't cheap. You might be able to pick up a set of take-offs from someone with an SS who went bigger.
Cost? No idea. A lot. Brake bling is always pricey.
Oh, and we don't know if the rear 14.4 is going to fit under stock 18s yet, so keep that in consideration.
What is this, CorvetteForum Lite?
LSxJunkie is offline   Reply With Quote
Old 12-08-2008, 03:54 PM   #3
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
I wonder how much, if any, the knuckles will be different between the V6s and V8s. If they're the same, you should be able to pretty much swap them over, with a bracket if necessary. I imagine when some of the members here, who are GM parts guys, start getting catalog information, they'll be able to look it up for us, among many other questions we may have. I imagine the interchangability should be pretty good. There might be a bigger master cylinder by virtue of there being something like twice as many pistons in the brake system.
Yeah - it might be tight with 18s though. Well, ZR1s have 15.0-inch front rotors and 19-inch wheels, so it may be possible, but I'm sure the barrel design in the wheel will dictate a lot of clearance allowance.
05 Hummer H2 SUV on OEM Air Ride
Forged 11.4:1 408 LQ4 (K1 crank & rods; Mahle pistons)/CPP LS3 CNC heads/BTR Stage IV LS3 cam/home ported L92 intake manifold/ported 90mm TB/custom Volant CAI/Kooks 1 7/8" LTs and 3" H-pipe/AFE dual 3" CB/Corvette Servo/el cheapo lift/Cognito UCAs/Sphon poly adjustable TA/Sphon adjustable rear LCAs/e'fan conversion/DirtyMax radiator/Moroso catchcan/HPTuners/HID conversion/LED exterior lighting/LED interior accents/Autometer Cobalts/AEM WB/ Pioneer AVH-5600BHS/Pioneer GM-9601/2-Pioneer TS-W310D4s/Obcon Labyrinth dual-12 box/lots of other little stuff
Brake upgrade 96CAMaro Wheels and Tires Talk Sponsored by The Tire Rack 28 06-03-2009 01:44 PM
SS Brake Cooling Slots Rodrunner Cosmetics and Lighting Modification Discussions 9 12-10-2008 02:32 PM
brake jobs Iroczlover Off-topic Discussions 16 11-03-2008 09:36 AM
Berger panel brake light mod? WillInThe04Ranger 4th Generation Camaros 9 06-03-2008 09:00 PM
