JDP Motorsports
Old 09-03-2010, 10:44 AM   #1
rudack
Rudack
rudack's Avatar
Drives: ABM 2SS/RS
Send a message via AIM to rudack Send a message via MSN to rudack
Question for those with a sunroof
Quick question for those with a sunroof, when you shut your door does your sunroof appear to pop out a little from the roof due to the air pressure in the car? I noticed this the other day, I closed my door and I watched the sunroof pop up from the roof a little. Has anyone noticed this? Is it normal?
ABM 2SS/RS #33390
rudack is offline   Reply With Quote
Old 09-03-2010, 10:45 AM   #2
aldaron327
Onward and Upward.
aldaron327's Avatar
Drives: '13 Equinox LTZ AWD,'09 Silverado
Send a message via MSN to aldaron327 Send a message via Yahoo to aldaron327
I've never noticed it.
2010 Summit White 2SS/RS LS3
MODS: CAI by CAI, Flowmaster American Thunder Cat-Back, DBA 5000 Slotted/Cross-drilled rotors (Front), Hawk HPS Pads, Russell Braided Brake Lines, DBA 4000 Slotted/Cross-drilled rotors (Rear), Barton Short-Throw Shifter, UM Comp Extractor Hood & Gen I Spoiler, custom paint
aldaron327 is offline   Reply With Quote
Old 09-03-2010, 11:02 AM   #3
ninety6
2xSOM
ninety6's Avatar
Drives: 2002 Camaro SS | 2002 Camaro V6 vrt
i feel like when mine is closed... its not flush with the roof -- but i've never checked to see if it is until i shut the doors...
ninety6 is offline   Reply With Quote
Old 09-03-2010, 11:06 AM   #4
Caspers2SSRS
Caspers2SSRS
Caspers2SSRS's Avatar
Drives: Summit White 2010 2SS/RS Camaro
Hmmmmmmmmmmm, good question. Having always had the inside cover closed...........I've never noticed. I'd think that it wouldn't or couldn't ever happen with the cover closed.
I'm not paranoid, they're following me !
Caspers2SSRS is offline   Reply With Quote
Old 09-03-2010, 11:11 AM   #5
CaniacFan
CaniacFan's Avatar
Drives: '10 SS CGM #75,288, '14 Stingray
Just ran out to the garage, my sunroof doesn't move when closing the door and it is pretty flush with the roof. My door window indexed when I opened closed (which it should).
I'd schedule a visit with your service department just to get it checked out.
CaniacFan is offline   Reply With Quote
Old 09-03-2010, 11:11 AM   #6
bluetooth-ss
bluetooth-ss's Avatar
Drives: 2010 ABM 2SS/RS A6 and 2005 TITAN
I just checked mine after reading this and it does it also. I have also noticed my seal is turning white. Any one know whats uo with that?
BLUETOOTH-SS
Old 09-03-2010, 11:24 AM   #7
VictoryMuscleCars
VictoryMuscleCars's Avatar
Drives: 2012 Camaro SS RS Convert
I've never noticed it, but will go check at lunch. I keep the slide closed when not driving etc.
Tom P
VictoryMuscleCars is offline   Reply With Quote
Old 09-03-2010, 11:26 AM   #8
rudack
Rudack
rudack's Avatar
Drives: ABM 2SS/RS
Perfect, Thanks much!
ABM 2SS/RS #33390
Old 09-03-2010, 11:30 AM   #9
recontango
recontango's Avatar
Drives: Synergy Green
I would think with the way the windows index down slightly whe the door is open and don't go back up until a split second after the door closes that there wouldn't be positive pressure upon closing the door... I haven't noticed it on mine.
recontango is offline   Reply With Quote
Old 09-03-2010, 11:37 AM   #10
kjd15
Finally!!
kjd15's Avatar
Drives: '10 2LT Summit white, '68 Camaro
I haven't noticed either, but like others, my shade is always closed when I get out of the car.
I would think, though, that the windows indexing would prevent any pressure inside the car for that to happen.
-Karen
SW 2LT Ordered 9/30/09
November 28, 2009 - Delivered!!!
kjd15 is offline   Reply With Quote
Old 09-03-2010, 02:03 PM   #11
My 5th
My 5th's Avatar
Drives: 2010 2SS/RS M6 Black on Black
Wax on the rubber from waxing the paint is my guess. Try "Back to Black" trim treatment, maybe that'll help if you can't get the wax off.
Meh
My 5th is offline   Reply With Quote
Old 09-03-2010, 02:27 PM   #12
Dack
Dack's Avatar
Drives: Black 2010 Camaro 2SS/RS
Send a message via Yahoo to Dack
Haha, funny this thread took root today. I took my 2ss/rs to my local service department to have my sunroof looked at because it rattles any time you close the doors with the windows up (it rattles from the air pressure). So I took it to them and told them the story and also added that it pooled water in one corner so it may be a little offset (I wasn't worried about pooled water, it wasn't much, only something I noticed when I was washing it). So what do they do? They raise the other side up so it sticks up above the level of the car, and now it rattles FAR worse than it ever had before. Now I can't close my door without it rattling (including when the shade is closed, which surprises me).
This fine work coming from the same dealership that told me (they also messed up my wheel by putting a inferno orange stitching one on first then I bitched so they ordered the correct one to put on and mounted it, then my car would drive straight with my wheel cocked 5 degrees to the left) that CamaroScotty's service manager is wrong in thinking they were a tooth or two off mounting the wheel (they said it is keyed so it only goes on one way) so they adjusted the toe out so it drives straight. Now it drives way differently than the first 10,000 miles on the car (not as responsive and stiff). And it's hard to get to a decent service center since the closest one is 45 minutes away and I work the same time as the service center is open. I'm just screwed... :(
Dack is offline   Reply With Quote
Old 09-03-2010, 03:09 PM   #13
MG
MG's Avatar
Drives: 2011 Camaro
I think this is a good place to ask........my sunroof express opens but does not express close, even though the close button has a 2 stage push to it just like the open button. Anyone else noticed this? 2011 2ss.
MG is offline   Reply With Quote
Old 09-03-2010, 03:10 PM   #14
gr8daneh
460 RWHP 420 RWTQ
gr8daneh's Avatar
Drives: 2SS/RS - IBM LS3 M6
+1
gr8daneh is offline   Reply With Quote
To sunroof? Or not to sunroof? Blakout 5th Gen Camaro SS LS LT General Discussions 197 07-15-2010 03:13 PM
Just ordered a 2011, and a question Lurker67 Camaro Price | Ordering | Tracking | Dealers Discussions 29 05-15-2010 09:32 PM
Custom wheel offset question ... Bowtie Junkman Wheels and Tires Talk Sponsored by The Tire Rack 4 04-23-2010 06:16 PM
Question Involving 4.10 gears & Bushings Deric884 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 1 02-13-2010 07:53 AM
Well sunroof question answered (PIC) Black5thgen 5th Gen Camaro SS LS LT General Discussions 152 08-29-2009 11:23 PM
