JUICEDMOTORSPORTS
Old 09-04-2010, 01:22 PM   #1
GLBL WMR
Booya
GLBL WMR's Avatar
Drives: Black 2010 2SS/RS
How normal/acceptable is chatter on this clutch?
I've noticed some slight shudder/chatter when letting the clutch out from a stop at slightly higher RPMs (~1500) - its definitely not noticeable all the time. I see many posts on here around clutch issues, but I don't want to be concerned about something if it's normal. I've heard some GT500 guys say that some chatter is normal for their clutches - not sure if the same applies to ours.
Wasn't there an issue with some bolts backing out causing clutch problems? I can't find the thread in search.
2010 Camaro SS/RS RP6 | 2SS package, M6, black, black leather
2000 Blazer LS | winter beater
GLBL WMR is offline   Reply With Quote
Old 09-04-2010, 04:14 PM   #2
flyby
Drives: 2010 Silver SS
Chatter/shudder not normal. Has your clutch pedal stuck halfway down yet? How many miles on the car? You may want to swap out clutch/brake fluid in the reservoir.
flyby is offline   Reply With Quote
Old 09-04-2010, 08:43 PM   #3
GLBL WMR
Booya
GLBL WMR's Avatar
The pedal has not stuck yet.. I thought shudder was indicative of a physical problem with the flywheel, not a fluid problem?
Old 09-12-2010, 03:24 PM   #4
hillbennerdeluxe
the legend
hillbennerdeluxe's Avatar
Drives: 2010 Camaro 2SS 6 speed manual
mine shutters too when i push the clutch in!
hillbennerdeluxe is offline   Reply With Quote
I want a new clutch, you too????? Sign here tjbusa V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 370 08-10-2013 04:27 AM
Clutch fluid contamination problems on Vette fixed for Camaro??? LDGn63 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 11 05-28-2012 10:17 PM
Clutch Problem phenixdragon Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 20 08-22-2010 11:51 AM
Oil Change Ramp mjlash22 Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 17 01-21-2010 11:40 PM
