Old 09-04-2010, 01:36 PM   #1
BalogUK
THE architect.
Drives: 2SS/RS M6
Exclamation oil issue--it shouldn't bere [here]- help!
okay,
I like to take care of my own car as much as I can- so I'm underneath performing an oil change and see this.... but I don't know a ton about whats going on- gasket between oil-pan and block??
there was residue all over the pan- had cleaned off the bottom already. My garage floor is clean, so there have been no "drips"
Is it a problem; if so how severe?
Thanks guys,
-Justin
#34122 EMPTIED, AT YARD ON 8/26/09; Delivered 9/07/09
MODS: Borla ATAK Cat-Back GFX (#140378), 35% Ceramic all-around, CAI, Inc. Intake w/ Scoop, Hurst Short Throw, Heritage Grille, GM Dove Tail, Laser Interceptor Triple v8.9, Passport Max, Pfadt ZL Stage 2
BalogUK is offline   Reply With Quote
Old 09-04-2010, 03:41 PM   #2
camaro5's Avatar
Drives: 2019 Louis Chevrolet Camaro
There are two causes common with the LS3:
Block porosity - causes leak where pan seals to block
Rear main seal
GM is well aware of them, and there are TSB's on both.
http://www.camaro5.com/forums/showpo...31&postcount=8
camaro5 is offline   Reply With Quote
Old 09-04-2010, 03:50 PM   #3
BalogUK
THE architect.
Drives: 2SS/RS M6
Rear main seal
daaang! I just changed the oil too!
this isn't where my oil is coming from (very possible for the final pick where it the Trans is mounting up to the engine) but not for the leak up at the pan...
thanks for the tsb list. any idea where I can find those with the noted "images"?
Found the images...
Old 09-05-2010, 08:20 AM   #4
BalogUK
THE architect.
Drives: 2SS/RS M6
bump
Old 09-07-2010, 08:08 PM   #5
BalogUK
THE architect.
Drives: 2SS/RS M6
shop wants the car ASAP tomorrow- no such documented leaks at this area yet he says...just at the rear case and the oil cooler. ugh. could be just a faulty gasket or a larger issue he says.
20,000 miles on odo. 1yr old today.
2010 Camaro V6 Oil and Oil Filter Change azamazonqueen Camaro DIY & HOW-TO instructions & discussions 116 03-19-2017 02:36 PM
DIY: Camaro Oil Change adub4185 Camaro DIY & HOW-TO instructions & discussions 180 04-23-2014 07:11 PM
Great Read and Info on Oil Weight Banshee Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 1 11-23-2009 10:03 PM
Save Money on Oil and Oil Filters! 7CAMARO7 Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 4 10-07-2009 09:21 PM
