Jason 98 TA
Old 12-09-2008, 07:45 AM   #1
devildogcollier
semper fidelis
Drives: 95 z28 lt1 6-sp,73' nova 350
manifold removal
ok. here's an update with my 95..... last night i removed my intake manifold completely, took about 2 hours because of some pain in the a$$ bolt under the number 5 cylinder fuel injector..... THE main reason i am doing this is to change the manifold gasket which i thought was causing the cars problems. HOWEVER, now that i have removed the original gaskets i can find nothing wrong with them...... CAN ANYONE SUGGEST ANYTHING ELSE I SHOULD CHECK WHILE THE MANIFOLD IS REMOVED,,,,OR WHAT COULD BE CAUSING MY PROBLEM????
THANK YALL FOR YALL'S HELP!!!
SEMPER FIDELIS
devildogcollier is offline   Reply With Quote
Old 12-09-2008, 11:01 AM   #2
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
I know there was a specific GM silicone for the intakes on LT1s. I have no leaks after that fix, with my dealer using that specific silicone for 60K miles - not even any sweat. It was a common enough problem for them to recommend a specific silicone so if it wasn't your intake gaskets, I bet it was the silicone on the front and rear of the valley. Hit up your dealer and get that silicone, clean all the surfaces, apply your beads, and you should be good-to-go.
05 Hummer H2 SUV on OEM Air Ride
Forged 11.4:1 408 LQ4 (K1 crank & rods; Mahle pistons)/CPP LS3 CNC heads/BTR Stage IV LS3 cam/home ported L92 intake manifold/ported 90mm TB/custom Volant CAI/Kooks 1 7/8" LTs and 3" H-pipe/AFE dual 3" CB/Corvette Servo/el cheapo lift/Cognito UCAs/Sphon poly adjustable TA/Sphon adjustable rear LCAs/e'fan conversion/DirtyMax radiator/Moroso catchcan/HPTuners/HID conversion/LED exterior lighting/LED interior accents/Autometer Cobalts/AEM WB/ Pioneer AVH-5600BHS/Pioneer GM-9601/2-Pioneer TS-W310D4s/Obcon Labyrinth dual-12 box/lots of other little stuff
Old 12-11-2008, 07:39 PM   #3
CamaroSpike23
Truth Enforcer
CamaroSpike23's Avatar
did you replace the o-rings on the injectors? I never heard back from you on that.
if so, did you fire the car up to check that that wasnt the problem?
since you've got the manifold off, I imagine that you have gotten a new gasket set. which should come with black high temp RTV that you will use to run a bead on the front and back of the block where it meets the intake manifold. (i think I sent you pics where to put the sealant.)
I piss excellence
and fart awesomeness
Old 12-13-2008, 10:09 PM   #4
CamaroSpike23
Truth Enforcer
any updates?
I piss excellence
Old 12-15-2008, 07:17 AM   #5
devildogcollier
semper fidelis
yeah , i posted em already .... lol
Manifold or headers?? RallyFever 5th Gen Camaro SS LS LT General Discussions 10 10-27-2008 08:29 PM
98 camaro z28 torque arm removal boxmonkeyracing 4th Generation Camaros 5 06-13-2008 09:02 PM
5th Gen Camaro LS3 info from Chevy Hi-Po...READ TAG UR IT Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 295 03-07-2008 11:06 AM
LS3 Specs, and Descriptions Mr. Wyndham Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 5 11-06-2007 02:04 PM
