Old 09-06-2010, 09:23 AM   #1
tytus03
Drives: F150/2010 camaro 2ss blk ls3
starting ls3
everytime I start my car for the first time of the day it like, dies, and I have to turn the key a second time and then it starts right up. This seemed to start shortly after I installed the aftermarket cat back about 400 miles ago. Any ideas what this could be? Appreciate any feedback.
tytus03 is offline   Reply With Quote
Old 09-06-2010, 01:56 PM   #2
SSLarry
Drives: 2SS LS3
I know its more for L99's, but maybe a fuse pull would work for you.
2010 CGM 2SS LS3, born: 4/10
SSLarry is offline   Reply With Quote
Old 09-06-2010, 04:07 PM   #3
camaro5's Avatar
Drives: 2019 Louis Chevrolet Camaro
Could be losing fuel pressure while sitting. Dealer needs to check fuel rail pressure after vehicle sits for an hour.
camaro5 is offline   Reply With Quote
Old 09-06-2010, 04:20 PM   #4
flyby
Drives: 2010 Silver SS
I concur, most likely fuel pressure problem... most likely a bad rail you can check it at the dealer or smell for gas smell while car is on but not started.
flyby is offline   Reply With Quote
Old 09-06-2010, 04:28 PM   #5
webslinger408
webslinger408's Avatar
Drives: 2010 camaro 2ss rs m6
THIS HAPPENS TO ME ALSO I HAVE TO TURN THE KEY TWICE AT TIMES..BUT THEN AGAIN I ONLY DRIVE MY CAR EVERY 8-9 DAYS BECAUSE OF WORK TRAVEL. CAN THIS BE A PROBLEM THE CAR SITTING MOST TIMES IT HAPPENS WHEN I PUT GAS IN THE TANK RIGHT AFTER FILL UP..I USALLY LEAVE 1\4 IN THE TANK AS IT SITS IN GARARGE.
webslinger408 is offline   Reply With Quote
Old 09-07-2010, 08:18 PM   #6
tytus02
tytus02's Avatar
Drives: truck/2010 camaro blk/blk 2ss ls3
what do you mean by on but not started?
tytus02 is offline   Reply With Quote
Old 09-07-2010, 08:57 PM   #7
camaro5's Avatar
Yes. Sitting will do it. And the evap system pressure is lost when refueling which may hasten the pressure loss rate.
Key ON, engine OFF. You need a Fuel Injection press gauge.
There probably is no external leak. There are check valves that fail.
Old 09-07-2010, 09:02 PM   #8
tytus02
tytus02's Avatar
ok thanks. guess i better get it checked cause it does it a lot now. if it sits more than 15 minutes then i have to turn the key twice to start it.
Mast Motorsports Cam Slugfest (VVT vs LS3) SGOS252382 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 28 05-14-2010 10:13 PM
LS3 and L99? black2black10 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 26 05-07-2010 01:58 AM
Specs on L99 vs LS3 .... Bowtie Junkman Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 3 04-28-2010 01:26 PM
Edmunds: GM Foreign-Exchange Program: Holden Special Vehicles Getting LS3 Scotsman General Automotive + Other Cars Discussion 5 03-27-2008 01:51 AM
LS3 Specs, and Descriptions Mr. Wyndham Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 5 11-06-2007 02:04 PM
