JDP Motorsports
Old 09-06-2010, 10:32 AM   #1
Speed74SS
Speed74SS's Avatar
Drives: 2010 LPE 650+ CTS-V
Differential Bushings
Just wanted to show a pic of my differential bushing and how much they really can wear. There seemed to be excessive movement and a little noise coming from the rear and here is the play in the bushing. Time for the Pedders HD Diff Bushings!!
Name:  Differential Bushing.jpg
'10 CTS-V : LPE 650+ Package 587hp / 582tq
2.55 Upper / 8.6 Lower / ID850's / Kooks Longtubes / New Era CAI
Speed74SS is offline   Reply With Quote
Old 09-06-2010, 10:53 AM   #2
BigMatt
2010 Camaro 2 SS/RS M6
BigMatt's Avatar
Drives: 2010 Camaro SS/RS
Send a message via AIM to BigMatt
Wow that's pretty bad
LS3, JRE Smooth Idle cam, CAI Inc, ARH 1 7/8, Corsa Xtreme, Taylor Wires, MGW Shifter, Street slayer twin carbon clutch, Tick braided clutch line & speed bleeder, ZL1 Diff Swap, BMR Split drop, Sway Bars, Trailing Arms, Toe Rods, Pro bushing kit, Spohn lcas, Whipple, LPE dual fuel pumps, Rx catch can, Id850s, Alky Control
BigMatt is offline   Reply With Quote
Old 09-06-2010, 10:57 AM   #3
Silver2SSRS6spd
Prefer to be blown!
Silver2SSRS6spd's Avatar
Drives: 2010 Silver/Black 2SS/RS Manual
Thanks for posting, that is bad. I have been looking at videos of the rear end and it does move quite a bit.
MagnaCharger TVS-2300 550rwhp 540 rwt and a radical suspension under the car.
Silver2SSRS6spd is offline   Reply With Quote
Old 09-06-2010, 11:27 AM   #4
mhc1ss
Drives: 2010 1ss ls3
was that stock bushing or aftermarket
mhc1ss is offline   Reply With Quote
Old 09-06-2010, 12:20 PM   #5
Speed74SS
Speed74SS's Avatar
I believe these are the stock bushings.....I ordered the HD Diff bushings from Pedders but haven't had them installed yet. Unless LPE installed some other diff bushings, which I am going to check on tomorrow. (They kind of look like Pfadt diff bushings but I don't want to say for sure)
Old 09-06-2010, 12:48 PM   #6
Sam88gta1
Drives: 2010 Camaro SS / 2006 CC Duramax
Those are the Pfadt bushings.
How long have they been installed in the car?
Sam88gta1 is offline   Reply With Quote
Old 09-06-2010, 12:56 PM   #7
Speed74SS
Speed74SS's Avatar
Since April of this year, so about 4 months. I do road track my car twice a month and run it hard at the track.
Old 09-06-2010, 12:59 PM   #8
MillerTime
Blowin the doors off!
MillerTime's Avatar
Drives: A 2013 SS RS 6M SR
wow...that's still pretty bad for 8 times at the track...
2G1FS1EWXD9163847
MillerTime is offline   Reply With Quote
Old 09-06-2010, 02:25 PM   #9
CamaroSS8491
Drives: 2010 SS/RS LS-3
Maybe it was an instalation problem not a product problem....
CamaroSS8491 is offline   Reply With Quote
Old 09-06-2010, 03:14 PM   #10
Speed74SS
Speed74SS's Avatar
I doubt it was an installation problem and I am sure LPE has installed a few of them. You never know. I just want to get my car back on the road and drive it for a couple months before the snow flies again
Old 09-06-2010, 07:49 PM   #11
Petersimov
Drives: 2ss
wow i have the same ones and i am starting to notice sum rear end slop too. I am going to check mine out tomorrow i hope they don't look like this
Petersimov is offline   Reply With Quote
Old 09-07-2010, 10:00 AM   #12
Speed74SS
Speed74SS's Avatar
Update: I just had my rear end replaced with the 3.70 gears from LPE and I did a core exchange with LPE. When the new diff came into my dealership, they forgot to pull my Pedder's bushings out of mine and the new one that was sent had the Pfadt bushings in it already. I thought I had had the Pedder's HD Bushes installed originally - to many parts to remember sometimes. I think any street bushing isn't going to hold up to 600hp but the HD bushing from Pedder's will.
Old 09-07-2010, 02:26 PM   #13
JusticePete
VIR Specialist
JusticePete's Avatar
Drives: Camaro Justice
For those with LPE power the OEM bushes will not provide suffcient stability.
Nate,
Are you able to retrieve your Pedders EP1167HDs or do I need to get you a new set?
Old 09-07-2010, 03:36 PM   #14
Speed74SS
Speed74SS's Avatar
Nate,
Pete,
I was able to locate my EP1167HD's and they are being over-nighted to me. Anything special they need to do to reinstall?? Grease etc? Just want to make sure it is done right. Thanks again!!
Nate
Anyone install Solid Differential Mount Bushings? ANy comments? 55Designs Suspension / Brakes / Chassis 14 02-20-2017 01:11 PM
Put More Power To The Pavement With Pfadt Engine Mounts And Differential Bushings!!!! Apex Motorsports Transmission / Driveline 28 11-27-2010 11:46 AM
Pfadt Street/Race Rear Differential Bushings, get more power to the pavement! Apex Motorsports Transmission / Driveline 5 08-10-2010 06:49 PM
Urethane Bushings from Energy Suspension Bewenched Suspension / Chassis / Brakes 1 04-30-2010 06:12 AM
BMR differential bushings (BK001) BMR Sales Transmission / Driveline 0 01-18-2010 01:08 PM
