Old 09-06-2010, 09:32 PM   #1
oachalon
Drives: 2010 Camaro 1SS
LS3 Oil cooler Torque Spec
Could anyone that has access to SI please get me the correct torque spec for the oil cooler. Mine is leaking a little bit and i believe its from the bolts being a little loose. I want to follow gm's torque spec.
I also believe this is a problem for quite a few on here and would be very helpful for everyone.
Thanks
oachalon is offline   Reply With Quote
Old 09-06-2010, 10:08 PM   #2
thiggin2
thiggin2's Avatar
Drives: 05/07 Chevy's
There are 2 different specs. See attached pic .
thiggin2 is offline   Reply With Quote
Old 09-06-2010, 10:08 PM   #3
TeddyP25
TeddyP25's Avatar
Drives: 2SS
Sorry dont have torque specs, but mine was leaking and dealer covered the seal rings under warranty without a prob, even tho I'm Sc'd.
2SS/RS CGM/BLK GFX MN6418 Stroker.785rwhp/885lbtq.50 SHOT NO2..Pfadt arms,toe links,coilovers,swaybars,end links,engine mounts,dif/sub bushings.MGWshifter.Tick LVL 3.ARH1 7/8 LT's/ARH exhaust.ADM gauges/race CAI.E-FORCE SC.8 rib IW 10%OD.LPE dual pump/module.85lb inj,custom valve covers.RMCR tune.TOOLEY RACING CAM.JRE posi kit.JRE fuel upgrade.RX MONSTER CatchCan.DSS axels/DS.Hammerhead rear, 3:73's. WYOSPEED builthttp://www.camaro5.com/forums/showthread.php?t=115687
TeddyP25 is offline   Reply With Quote
Old 09-07-2010, 05:42 PM   #4
oachalon
thanks for the help.
2010 Camaro V6 Oil and Oil Filter Change azamazonqueen Camaro DIY & HOW-TO instructions & discussions 116 03-19-2017 02:36 PM
My V6 oil change experience convert Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 38 04-08-2014 05:15 PM
SPEC Clutch/Flywheel Upgrades | Single & Twin Disc!! AJ@ECSMotorsports Transmission / Driveline 21 11-13-2010 04:58 PM
BP Makes "Giant" Oil Find in Gulf of Mexico KILLER74Z28 General Automotive + Other Cars Discussion 1 09-02-2009 08:39 PM
