Suspension / Brakes / Chassis All suspension, brakes and chassis discussions.
Old 09-07-2010, 10:22 AM   #1
BMR Suspension
Drives: 2010 Camaro 1SS
Talking BMR Launches New Product - Adjustable Sway Bars (SB030)
BMR Fabrication
Adjustable Sway Bars for 2010 Camaro
Improve the handling and increase the roll resistance in your 2010 Camaro with a Sway Bar Kit from BMR Fabrication. The hollow front sway bar features 3 adjustment locations that range from 98% to 214% stiffer than the OE bar. The hollow rear sway bar features 3 adjustment locations that range from 99% to 301% stiffer than the OE bar. Both sway bars are cold formed from lightweight tubular DOM steel and feature integrated thrust washers to prevent horizontal movement. A set of BMR Sway Bars (SB030) will decrease body roll and dramatically increase the cornering capabilities of your F-Body. Front sway bar (SB016) and rear sway bar (SB017) also sold separately. Available in a red and black hammertone powdercoat finishes. Installation time for both sway bars is only 2 hours.
To preview all of BMR’s high-performance suspension parts, please visit www.bmrfabrication.com, email sales@bmrfabrication.com, or contact them at BMR Fabrication, 12581 US Highway 301 North, Thonotosassa, FL 33592, 813-986-9302, Fax: 813-986-8055.
BMR Suspension is offline   Reply With Quote
Old 09-08-2010, 08:23 AM   #2
olblue75
olblue75's Avatar
Drives: Inferno Orange 2SS/RS LS-3
Can the hot chick in your signature come over and install them for me I'll be the tool bitch LMAO
Old 09-08-2010, 10:08 AM   #3
BMR guy
BMR guy's Avatar
Drives: 2010 1SS
It would be fun watching her wrestle that front swaybar out of there!
Brett
Internet Tech
BMR SUSPENSION
BMR guy is offline   Reply With Quote
Old 09-09-2010, 10:12 AM   #4
ssmike
BLACK is the new Chrome!
ssmike's Avatar
Drives: 2010 2SS/RS RJT M6
Any C5 discounts? Also, how do I know what settings to set them up with? I will be using it only on spirited street use, no racing but looking for improved cornering and handling! Thanks!
Old 09-09-2010, 11:29 AM   #5
BMR Sales
Honestly the best settings for these sway bars is at full stiff front and rear. There won't really be any change in driveabilty but when you start driving the car spiritedly and pushing it you will notice a huge difference in body roll an d handling overall. Let me see if they have anything planned sale wise in the future.
Kyle Briese - Sales Tech
BMR Suspension
www.bmrsuspension.com
813.986.9302
Like us on Facebook!
Old 09-09-2010, 05:09 PM   #6
ssmike
ssmike's Avatar
With the bars set to full stiff will this put too much strain on the stock endlinks? Also, do you recommend installing sub frame and radius bush inserts? Are hollow bars any advantage over solid, other than weight? Thanks!
Old 09-09-2010, 05:17 PM   #7
Avalnch
Avalnch's Avatar
Drives: Rally Yellow Camaro+Avalanche
Yes, heavy duty endlinks with poly bushings is definitely needed.
Something that will fit right into the stock points without drilling, please.
C.A.I., Apex Scoop, ARH LT, Pypes Cat Back, Barton Short Throw, JDP Tow Hook
Scorch Yellow Trim Kit, Shark Fin, AAC DRLs+ABLs+SMDs, ZTA Rear Spoiler
Pfadt coilovers, camber plates, trailing arms & differential bushings.
BMR adjustable toe-rods. Pedders ZL1 barz, rear cradle inserts, radius arm & steering rack bushings.
Hotchkis Max Chassis Brace (minus tunnel cross-over piece for SCCA rules)
1LE 3.91 gearzzz. Drive Shaft Shop Road Race Axle Upgrade. TurnOne power steering pump.
Forgeline GA3-R 19x11 + Hoosier R6 315/30R19
426 HP @ 5550 RPM / 427 TQ @ 4700 RPM
Avalnch is offline   Reply With Quote
Old 09-14-2010, 08:35 AM   #8
BMR Sales
We are working on some endlinks for you guys right now. I should have some information on them for you guys pretty soon.
BMR Suspension
813.986.9302
Adjustable sway bar setting for daily driver? JProberts Suspension / Brakes / Chassis 128 12-01-2010 11:19 PM
BMR Fabrication Launches New Product - 2010 Camaro Trailing Arms (TCA026) BMR Suspension Suspension / Chassis / Brakes 89 03-05-2010 08:02 AM
BMR Fabrication Launches New Product - 2010 Camaro Driveshaft Tunnel Brace (DTB004) BMR Suspension Suspension / Chassis / Brakes 30 10-12-2009 08:15 AM
BMR Fabrication Launches New Product - 2010 Camaro Driveshaft Tunnel Brace (DTB004) BMR Suspension Suspension / Chassis / Brakes 0 09-30-2009 02:03 AM
