Old 12-10-2008, 11:58 AM   #1
ctk1
Camarofanatic
Drives: 1969 SS, 1998 RS, 2010 VR 2SS/RS
Removing the Cats?
Shortly after I get my 2SS I plan on removing the stock mufflers and adding Corsa black case (aggressive) mufflers. I know that the cat really restricts the exhaust flow, and kills the sound. My question for you guys experienced with computer controlled engines is...If I remove the cats completely, it will obviously make it loud which is what I'm going for, but will it set off any lights on the dash or make the car run lousy because the computer will be getting strange information?
ctk1 is offline   Reply With Quote
Old 12-10-2008, 12:19 PM   #2
linkwpc
The punching cat
linkwpc's Avatar
Drives: '10 Camaro SS Black W/Hugger&W/IOI
I think the sounds is better with cats on. It give them a better sounds but not a louder sound level. I would keep my cats or maybe get some high flow cats!
My car build (COTW 7/23/12) - - - - - - > CLICK HERE! : http://www.camaro5.com/forums/showthread.php?t=80725
linkwpc is offline   Reply With Quote
Old 12-10-2008, 12:38 PM   #3
SSNIGHTMARE
SSNIGHTMARE's Avatar
Drives: 2002 SS Camaro
cats generally do not quite down an exhaust system, they can however take out the annoying rasp associated with some high flow straight through systems. Removing the cats and o2 sensors will set a code, you can either install high flow cats, o2 sims, have ur original pcm tuned for no cats. I would put on a set of long tubes with high flow cats, and have the pcm tuned accordingly.
04 GMC LB7, SOCAL DIESEL STAGE 2 HEADS, CROWER RODS, TWIN CP3 483 RWHP, 1008 FT/LBS, ATS 5K
02 SS, LSX BLOCK, 500 HP, WAITING ON BOOST
98 COBRA, EAGLE CRANK AND RODS, 568 RWHP, S-TRIM
02 SS, STOCK, THE SLO HO
08 CTS, POS
EFI Live
"Nitrous is like a hot girl with STD's, you know you wanna hit it but you're afraid of the consequences!"
"..it does not require a majority to prevail, but rather an irate, tireless minority keen to set brush fires in people's minds.."
--Samuel Adams
SSNIGHTMARE is offline   Reply With Quote
Old 12-10-2008, 12:40 PM   #4
TAG UR IT
www.Camaro5store.com
TAG UR IT's Avatar
Drives: 2014 ZL1 #705
Do it right and put on high flow cats. You are sure to trigger codes (lights) and that might even have an effect on the way it drives....who knows right now.
Best bet is to jump on a vette forum and ask those who deal w/ the LS3's on a daily basis.....or just call CamaroSpike!
Old 12-10-2008, 01:03 PM   #5
99b4c
Drives: 89 RS/99 GTP/1SS soon
I used to run two cats and no mufflers on my Monte Carlo, it sounded good and loud. I will be pulling the mufflers on my Camaro to hear what it sounds like, if not good than I will remove the cats and remove from the programming.
The cats do quite the exaust a little.
99b4c is offline   Reply With Quote
Old 12-10-2008, 01:19 PM   #6
Camaro_Corvette
36.58625, -121.7568
Camaro_Corvette's Avatar
Drives: Team 1LE
From DC Surely your info is here.
http://www.digitalcorvettes.com/foru...=removing+cats
Even better
Old 12-10-2008, 01:23 PM   #7
LSxJunkie
Snark snark snark
LSxJunkie's Avatar
Drives: RX350
Yes. Either way, you're going to need a tune, so you're better off getting a set of longtubes with catless midpipes if you want to see power. All you're going to do is piss off the PCM if you just cut the cats out without a tune. There's a downstream o2 that will detect it, most people tune them out.
What is this, CorvetteForum Lite?
LSxJunkie is offline   Reply With Quote
Old 12-10-2008, 01:35 PM   #8
MerF
Go Rays!
MerF's Avatar
Drives: 03 Trailblazer
Why? Is 5 rwhp really worth the effort of the custom exhast flanges and pipes, as well as the money to keep the ECU from being pissed about it? And don't say "the sound" because we have no idea what the car sounds like from the factory yet (though initial reports are damn good) and we definitely don't know what the car will sound like once you start modifying the exhaust. MOST cars sound like a can of rattled ass without the cats in place.
MerF is offline   Reply With Quote
Old 12-10-2008, 01:37 PM   #9
1_2Many
1_2Many's Avatar
Drives: 2008 Suzuki SX4
My buddy has a new Mustang GT and he put in a muffler delete pipe and it sounds fantastic. Not too loud and very deep.
Removing cats will definitely throw a code unless you trick the O2 sensors.
We are the early orderers...we are GM's voluntary guinea pigs and their free source of feedback. How will we be thanked?
1_2Many is offline   Reply With Quote
Old 12-10-2008, 01:39 PM   #10
Camaro_Corvette
36.58625, -121.7568
Drives: Team 1LE
Old 12-10-2008, 01:42 PM   #11
MerF
Go Rays!
MerF's Avatar
Mustangs always have, and probably alwasy will, sound better than F-bodys. It's just the way it is. You can not compare the two, one is about show and the other is about go.
Old 12-10-2008, 01:58 PM   #12
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
From the initial looks of the exhaust as I've seen it to now, I don't think cutting them off will do much except make you spend money on deleting PCM codes, pipes, and getting a lot of drone inside the car. If noise is your thing, cool, have at it, but gutting them is probably not going to do much for you. I never had much of a difference in performance when I was running a catd' Y-pipe and off-road Y-pipe with some mid-length headers on my car. The codes were deleted, and my trap speeds never reflected a gain either way. The sound didn't change as much until I went to LTs, and I still get a little rasp with the little pup cats' I use now. The catback was the same and cutout was always open.
It's your car, so do as you like
05 Hummer H2 SUV on OEM Air Ride
Forged 11.4:1 408 LQ4 (K1 crank & rods; Mahle pistons)/CPP LS3 CNC heads/BTR Stage IV LS3 cam/home ported L92 intake manifold/ported 90mm TB/custom Volant CAI/mid-length headers/AFE dual 3" CB/Corvette Servo/el cheapo lift/Cognito UCAs/Sphon poly adjustable TA/Sphon adjustable rear LCAs/e'fan conversion/DirtyMax radiator/Moroso catchcan/HPTuners/HID conversion/LED exterior lighting/LED interior accents/Autometer Cobalts/AEM WBPioneer AVH-5600BHS/Pioneer GM-9601/2-Pioneer TS-W310D4s/Obcon Labyrinth dual-12 box/lots of other little stuff
Old 12-10-2008, 02:18 PM   #13
blackZbandit
blackZbandit's Avatar
Drives: BLACK ON BLACK 2012 CAMARO SS
I'm thinking about doing electronically controlled cutouts... I at least want the option to not wake up the neighbors when i come home at 4 in the morning.
BLACK CAR + FLAT BLACK STRIPES + BLACK WHEELS = BLK PW3R!!
****Thanks to Silver Streak for the pic I used to make this sig****
blackZbandit is offline   Reply With Quote
Old 12-10-2008, 02:19 PM   #14
Camaro_Corvette
36.58625, -121.7568
Drives: Team 1LE
I like your style, more power at the flip of a switch.
LoL Cats Bumble Bee '77 Off-topic Discussions 33 12-17-2008 10:23 AM
Ohhhhh C-A-T-S Cats Cats Cats!!!!! acscamarochick06 Off-topic Discussions 1 01-14-2008 02:57 PM
