HeadlightArmor
Old 09-07-2010, 10:45 PM   #1
jachevy28
Camaro. Is. Life.
Drives: 2016 1SS
Frustrating rear end rattle?
Shot in the dark for thoughts....a few weeks ago I started getting a light rattle in the far rear of the vehicle, sort of sounds like a thin piece of metal bouncing around in a coffee can. It's worse when the car is warmed up, and it only occurs under light (not full throttle) acceleration. It's loudest about 45 mph in 3rd gear at half throttle, but also audible in 1st and 2nd....dies down a bit the higher the gear after that. Does not occur under deceleration, going over bumps, idle, neutral, etc.
The dealer checked for anything loose under there and didn't find anything...said it must be the aftermarket exhaust (my first thought). I replaced the mufflers on the exhuast, checked clearances, heat shields, etc. and that didn't do it...so, what would a differential or rear gear rattle sound like? Would the above description fit? Would there be any other symptoms, because everything else seems normal.
Kinda at my wits end trying to figure out where it's coming from.
jachevy28 is offline   Reply With Quote
Old 09-07-2010, 10:49 PM   #2
KnightRiderSS
Voodoo Medicine Man
KnightRiderSS's Avatar
Drives: Black 2SS with RS package
Does the exhaust have enough clearance above the cross memeber?
Did the dealer check for missing spoiler nuts?
KnightRiderSS is offline   Reply With Quote
Old 09-08-2010, 06:27 AM   #3
jachevy28
Camaro. Is. Life.
Drives: 2016 1SS
Yeah, plenty of cross member clearance, and it's not the spoiler nuts.
Old 09-08-2010, 10:43 AM   #4
t.c.tam
t.c.tam's Avatar
Drives: 2011 Camaro LS
did you check the heat shield?
http://www.camaro5.com/forums/showth...shield+exhaust
Ordered 8/7/2010
(1100) Preliminary order accepted 8/16/2010
(2500) Order preferenced 8/18/2010
(3400) Order broadcast 8/25/2010
TPW 8/30/2010
(3800) Order produced 8/31/2010
In-Transit from Osh 9/1/2010
9/15/2010 Delivered!!
t.c.tam is offline   Reply With Quote
Old 09-08-2010, 11:36 AM   #5
thekid96
Drives: Z06, 69 Camaro
I had an internal piece of a muffler break loose recently and it sounded exactly like what you are experiencing. I spent a couple days hunting for loose fittings, something hitting, etc. I finally had to pull the exhaust off and instantly figured it out.
thekid96 is offline   Reply With Quote
Old 09-08-2010, 06:05 PM   #6
flyby
Drives: 2010 Silver SS
My bet would be something actually in one of the mufflers.
flyby is offline   Reply With Quote
Old 09-21-2010, 01:35 AM   #7
mbrusco103
mbrusco103's Avatar
Drives: 2011 2SS/RS (M6) 427 Twin Turbo
when installing my friends exhaust in his camaro there was a noise that it was making and after checking everything we eventually found a coin that was stuck in between the rear seats seatbelt harness and the seat itself.
good luck!
2011 Camaro 2SS/RS ERL 427 M6 TT
-AGP Twin Turbo 55/57 .83ar | ERL 427ci | Squash Fuel System | Stainless Works Chambered 3" | Mcleod RXT | Factory Hurst Short Throw | Black Forgestar F14s | CTS V 6 Piston Brembo | VIS AMS Carbon Fiber Hood | Anvil Carbon Fiber Spoiler
mbrusco103 is offline   Reply With Quote
Rear End Noise when enabling/disabling TC/Stabilitrack Swytch Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 0 06-03-2010 01:08 PM
Richmond Rear End Gears - 3.73 & 4.10 Sean@Phastek Transmission / Driveline 0 06-02-2010 11:47 AM
rear end failure? xshortd Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 1 04-08-2010 07:59 PM
Rear end whine while under load shiftz33 5th Gen Camaro SS LS LT General Discussions 4 08-12-2009 05:15 PM
