JUICEDMOTORSPORTS
Old 09-08-2010, 02:58 PM   #1
ICEMAN 316
ICEMAN 316's Avatar
Drives: FAST
Trailing Arms
How hard is it to install Trailing Arms? Is it similar to sway bar installs?
ICEMAN 316 is offline   Reply With Quote
Old 09-08-2010, 03:49 PM   #2
PfadtRacing
PfadtRacing's Avatar
Drives: 2010 Camaro, 2006 Z06
Hey ICEMAN,
Take a look at this install document. It is fairly straightforward, as shown. The only caveat is that you will need to extract the upright bushing for a complete installation. This can be done with an appropriately sized set of sockets and a long bolt, or with a tool that you can purchase. Either way, its just a bolt-on installation. Let me know if you have any questions.
http://www.pfadtracing.com/blog/wp-c...on-no-tool.pdf
Old 09-08-2010, 05:26 PM   #3
JusticePete
VIR Specialist
JusticePete's Avatar
Drives: Camaro Justice
From the information in your sig, it appears you have a fresh 5th Gen. Why are you replacing your trailing arms?
Old 09-08-2010, 06:43 PM   #4
ICEMAN 316
ICEMAN 316's Avatar
Drives: FAST
just read in another thread that changing the trailing arm reduces wheel hop. Just doing research.
Old 09-08-2010, 06:46 PM   #5
BackinBlackSS/RS
Go Blue!!!!!
BackinBlackSS/RS's Avatar
Drives: 2012 Cruze LT
There are a bunch of people saying the stock ones are junk. Is this not true?
Old 09-08-2010, 06:51 PM   #6
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
The Pfadt units are a drastic improvement over stock and they include the trailing arm bushing kit. The engineering team at Pfadt managed to increase strength by 106% while simultaneously reducing mass by 17% and reducing deflection by 32%. This allows the suspension to react more quickly to the changing road surface keeping the tire in contact with the road to increase traction. Also, take a look at the Pfadt Solid Subframe Bushings. They will help eliminate subframe movement, make your car react to steering inputs more quickly, provide better control when launching hard, and eliminate wheel hop.
Old 09-08-2010, 06:54 PM   #7
mlee
www.CamaroFest.org
mlee's Avatar
Drives: 2017 A10 ZL1
Changing them out is not hard at all.. Here's a great link...
http://www.planetlsx.com/tech/How_To...010_Camaro/138
BMR Rear Trailing Arms, Tie Rods, Bushings, and More! | FREE Shipping!! AJ@ECSMotorsports Suspension / Chassis / Brakes 19 11-13-2010 04:55 PM
BMR Launches New Product - 2010 Camaro Trailing Arms w/Spherical Bearings (TCA027) BMR Suspension Suspension / Brakes / Chassis 4 05-28-2010 11:42 AM
LMPerformance, Spohn Camaro 2010 Tubular Rear Trailing Arms w/ Polyurethane Bushing LMPerformance V8 Bolt-Ons & Tunes 3 10-19-2009 04:33 PM
LM Performance, Spohn Camaro 2010 Tubular Rear Trailing Arms w/ Spherical Rod Ends LMPerformance V8 Bolt-Ons & Tunes 0 10-19-2009 02:59 PM
LM Performance, Spohn Camaro 2010 Tubular Rear Trailing Arms w/ Del-Sphere Pivot Join LMPerformance V8 Bolt-Ons & Tunes 0 10-19-2009 02:34 PM
