BeckyD @ James Martin Chevy
Old 09-08-2010, 06:48 PM   #1
Avalnch
Avalnch's Avatar
Drives: Rally Yellow Camaro+Avalanche
Burning brake smell from my Hawk ceramics
Just had my first ever auto-cross event in (like) 20 years running my stock suspension/tires LS3. The Hawk pads worked great and the big Brembos had lots of stopping power. Also, there was barely any dust at the end of the day. BUT after very hard stops (not lockups), there was an extremely strong brake pad smell coming from the Hawks. Is this normal? As the day wore on and my driving got smoother, I had to brake less and the smell went away.
Anyone else have any experience with working the Hawk ceramics hard and getting a strong smell?
Thanks.
Vengeance Kaotik Cam, C.A.I., ARH LT, Pypes Cat Back, ZL1 Shifter+2012LS3VERT bushing, Quantum Brake Ducts, JDP Tow Hook Scorch Yellow Trim Kit, Shark Fin, AAC DRLs+ABLs+SMDs, ZTA Rear Spoiler, R.Y. 1LE Splitter. Pfadt coilovers, camber plates, trailing arms, Pegasus Solid Subframe. Pedders ZL1 barz, radius arm & steering rack bushings. BMR adjustable toe-rods. Hotchkis Max Chassis Brace. ZL1 GMPP Driveline Upgrade. TurnOne P/S pump.
447 HP @ 6180 RPM / 418 TQ @ 5100 RPM
Avalnch is offline   Reply With Quote
Old 09-08-2010, 07:35 PM   #2
SC2150
Thats normal. If you had a camera on he rotors you would see them glow under sustained hard braking. Good pads!
Old 09-08-2010, 07:49 PM   #3
JusticePete
JusticePete's Avatar
Drives: Camaro Justice
Brakes used hard generate massive amounts of heat and a perfume to the nose of anyone that loves to go around corners on a track or autocross. That should be normal, BUT when you run hard on a track or autocross it pays to do before and after under car inspections.
The OE SS caliper dust boots will 'burn' in extreme use, but will NOT smell. Consider the dust boots a maintenance item and inspect them after hard use.
Inspect your dust shields and look for blisters from the brake heat. It is a cosmetic issue and nothing more.
While you are under the car lay a wrench on every nut and bolt in the steering, suspension and drive-line to be sure nothing is working loose. It is the old an ounce of prevention...
Old 09-08-2010, 09:07 PM   #4
Mr Twisty
Mr Twisty's Avatar
Nuttin' like the smell of hot brakes first thing in the morning... ahhhh
-- Benjamin Franklin
Understanding Brake Fluid: DOT 3, DOT 4, DOT 5.1 TAG UR IT Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 57 05-28-2016 10:10 AM
Hawk Performance Brake Pad "Updated" KILLER74Z28 Suspension / Brakes / Chassis 34 05-04-2016 12:11 PM
Unbeatable Prices on BC / Eibach / Hawk / Hotchkis / MTI / Racing Brake / SLP / More maperformance Suspension / Chassis / Brakes 10 10-04-2010 03:36 PM
ROTORA BIG BRAKE KITS 4-12 PISTONS/ 15" & 16" ROTORS SPECIAL ADKINS PERFORMANCE Suspension / Chassis / Brakes 0 08-03-2010 01:08 PM
