Gen5DIY
Old 09-09-2010, 01:35 PM   #1
jmlozano7
NUPOC Candidate
jmlozano7's Avatar
Drives: 2010 Camaro SS
1000 hp DSS Axles and 4.10s Please Help!
Hey guys. I have the 1000hp axles in my Camaro and I have a question.
I recently installed Richmond 4.10s along with Jannetty's Posi mod. When I back out of my parking spot, I hear a slight click from the rear and I believe it to be from the posi mod since it makes the posi tighter.
However, when I put the car on a lift and inspect the axles, there seems to be a lot of "play" between the driveshaft and wheels. So I tried to Isolate the motion and find that it seems to me that both inner CV joints of the axles have very slight "play" in them. That is, when I hold the joint next to the third member and rotate the wheel slightly, there is some slight give in the joint itself.
Is this normal?
No more Charlotte...
Currently driving an '08 Honda Accord...
Will be driving a ZL1 before you know it!
jmlozano7 is offline   Reply With Quote
Old 09-09-2010, 04:07 PM   #2
jmlozano7
NUPOC Candidate
jmlozano7's Avatar
Bump.
Old 09-09-2010, 05:00 PM   #3
Speed74SS
Speed74SS's Avatar
Drives: 2010 LPE 650+ CTS-V
Is this normal?
I have noticed this on mine as well when I had it up on the lift to put the 3.70 gears in. You can rotate the wheel slightly before anything seems to engage. I have run mine for quite a few miles like this and it seems ok. I assume that they are suppose to do that but I'm not sure.
'10 CTS-V : LPE 650+ Package 587hp / 582tq
2.55 Upper / 8.6 Lower / ID850's / Kooks Longtubes / New Era CAI
Speed74SS is offline   Reply With Quote
Old 09-09-2010, 05:10 PM   #4
jmlozano7
NUPOC Candidate
jmlozano7's Avatar
Thanks for the info!
If anyone else has had the same experience please chime in.
Old 09-10-2010, 02:23 AM   #5
jmlozano7
NUPOC Candidate
jmlozano7's Avatar
Bump.
Does anyone else experience this?
Old 09-10-2010, 01:45 PM   #6
jmlozano7
NUPOC Candidate
jmlozano7's Avatar
Bump.
Old 09-15-2010, 01:16 PM   #7
Petersimov
Drives: 2ss
SPEED74ss I know that the joints in the axles have a lil slop in them to help cool them better
Petersimov is offline   Reply With Quote
