Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums -
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - > Technical Camaro Topics > Camaro Issues / Problems | Warranty Discussions | TSB and Recalls
Old 09-09-2010, 02:44 PM   #1
Camaro Sarah Beth
Camaro Sarah Beth
Drives: 2002 Camaro Convertible
HELP!! 2002 V6 Camaro problems PLEASE HELP!!
I am having issues with my 2002 Camaro it is a V6 and has 143k miles on it :(. When I go to stop the RPMs drop and my car stalls then when I try and start it, it will not start up again. I tried charging the battery with jumper cables, but then I gave up and left it for awhile......then is started up again and is running fine. It has done this twice already. When I try and start it, it acts like it is about to start up but doesn't. I have many guesses to what it could be. Fuel Filter, Fuel Pump, Coil needs replaced, Alternator etc...... Any suggestions or helpful hints will be appreciated. Thanks everyone!!!!
Camaro Sarah Beth is offline   Reply With Quote
Old 09-09-2010, 03:19 PM   #2
Drives: NA
Sounds like a clogged fuel line. I had all these signs with my 97 Silverado back in 04 and it turned out that the fuel pump had rusted. I was using octane booster at the time and it knocked off a bunch of rust that clogged the fuel line. It took forever to the start and usually only would if I mashed the gas pedal. Usually garages can check the pressure on the fuel line and determine if this is your problem pretty easily.
TOMS1SS is offline   Reply With Quote
CAMARO WIKI Tran Wiki 55 03-28-2017 12:04 PM
New Camaro Exterior and Interior Stainless Steel Trim Parts from RPI Designs! RPI Designs Exterior Parts & Accessories 30 02-20-2013 03:23 PM
Does the v6 have enough power? cstproductions Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 305 08-29-2012 09:27 PM
