Old 09-10-2010, 09:42 AM   #1
autobotaz
Drives: Black 2010 Camaro LS
Manual Tranny Drivers..RPMs starting out in first gear?
After seeing all of the threads about problems with the clutch in some V6 and V8 Camaros I wanted to see what RPM we are all letting the clutch out at from a stop to a normal take off.
In an effort to not slip the clutch too much I have been really gentle barely getting over 1k but sometimes if I don't pay attention it will jerk a little from not enough right foot. I prefer closer to 1500. I am probably babying it too much but these clutch problem threads have me nervous.
For background purposes I am 34 and have driven manual trannys since I got my first car at 18. My little Scion Xb that I traded in for my Camaro had 70k and not one clutch issue in 5 years and I drove that thing hard. Apples and oranges I know, but just saying I'm not a noob lol.
What do you say??
autobotaz is offline   Reply With Quote
Old 09-10-2010, 10:27 AM   #2
larryt1026
larryt1026's Avatar
Drives: 2011 Camaro LT
I don't usually check the RPM when I take off from start. When I do take off from start..I used to let go of the clutch and when I feel it gets close to engaging, I just give it a little bit of gas. However, of late, I've been hitting a little gas before I start easing off the clutch as to prevent that I'd never stall. I'll check how much gas and what rpm I give it next time I drive. I'm no expert at driving stick..this Camaro is actually my first manual transmission, so I figured I'd post to also get everyones opinion.
larryt1026 is offline   Reply With Quote
Old 09-10-2010, 10:41 AM   #3
PAUL SS
The Mark of Excellence
PAUL SS's Avatar
Drives: 2010 ABM 1SS RS LS3
I just bump the rpm's up to 1,000 or so and as the clutch begins to engage apply more throttle as the clutch fully engages. It is a very smooth and seamless process.
Old 09-15-2010, 08:40 AM   #4
Chobbs11
Chobbs11's Avatar
Drives: 2011 IBM Camaro LS
If you really want to baby your clutch you can just let the clutch engage without touching the gas, this car will go without revving the engine at all( unless your on a hill)
Chobbs11 is offline   Reply With Quote
Old 09-15-2010, 09:57 AM   #5
superman
Drives: 2011 Camaro 1SS
Yup. Get good enough with your clutch so you can get it moving without hitting the gas. And once you get it rolling real slow, you can give it some gas.
I would practice by pushing it down all the way with your toes and slowing backing off with your heel on the ground and pulling your toes off the clutch. (be warned you will stall a lot until you get it right)
Best way to save your clutch. Even a 1k or 1.5k start burns more clutch than a no gas clutch start.
superman is offline   Reply With Quote
Old 09-15-2010, 10:42 AM   #6
larryt1026
larryt1026's Avatar
If you do this enough, you'll be able to do all this fast? Sounds like it takes a long time to let go of the clutch slowly till engagement and then hit gas.
Old 09-15-2010, 01:06 PM   #7
GQ4Life
Drives: 2010 Camaro SS LS3
I couldn't baby it. I bought this car to have fun. I did have clutch stick about two times but noticed slip quick & got out.
Don't worry about it enjoy the car.
2015 Corvette Z06.. Lime Rock Park 1:01; Watkins Glen 2:14; Thompson Speedway 1:21
GQ4Life is offline   Reply With Quote
Old 09-15-2010, 01:11 PM   #8
superman
I'm not talking like 1 cm per minute or something, but just slowly let it go until you feel it catch. Eventually you'll be able to do this very fast and it'll be faster than revving your engine to 1k and letting the clutch burn...then catch.
You'll get the feel of where it catches and you can balance the clutch catching and giving gas to the point it feels like an automatic starting.
Old 09-15-2010, 01:22 PM   #9
ssmike
Missing Big Red
ssmike's Avatar
Drives: 2006 Corvette DSOM, '13 Equinox CRT
I rev it up to about 3000 rpm and let er fly! LOL! Only problem is it'll suffer from premature tire wear, Oh well! Just kidding! Don't worry, just give er enough to prevent a stall and away you go!
Not a Camaro but it works for now!
CAMARO WIKI Tran Wiki 54 02-06-2016 12:33 PM
L99 AFM -- It's REALLY a tough choice, for some. Step Inside. 2KZ28_For_Now 5th Gen Camaro SS LS LT General Discussions 128 04-03-2009 05:03 PM
6-speed Manual Specifications (SS) Tran Wiki 0 10-19-2008 02:01 PM
Automatic faster than the manual??? 2sharp Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 319 09-30-2008 10:20 AM
Camaro Manual Transmission LSxcellent 5th Gen Camaro SS LS LT General Discussions 17 08-01-2007 06:11 AM
