Jason 98 TA
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Sponsors Classifieds Marketplace > Suspension / Chassis / Brakes
Old 09-10-2010, 01:19 PM   #1
JDP Motorsports
JDP Motorsports's Avatar
Drives: 2011 Camaro SS/ 2016 Camaro SS
Pfadt Racing Coil Overs | Camaro5 Special | In Stock | Free Shipping!!!
JDP Motorsports is proud to offer Pfadt Race Engineering products!!! Pfadt has authorized a SPECIAL sale on the 5th Gen Camaro Coil Overs!!! The Coil Overs normally sale for $2490 but while supplies last they will be offered to Camaro5 members for $2099 and we'll including shipping!!! We have these units in stock ready to ship and this is the system JDP Motorsports is using on our 2011 SS Camaro project "Silver Shark"!!! You can follow our complete build on the JDP FB page! This offer is ONLY for Camaro5 members and the coupon code is CAM5FORUM!!
Info from Pfadt Race Engineering!
Developing the highest performance Camaro Coilover System on the market required almost a year of research and development. Countless hours at road courses, run-after-run at the drag strip, hundreds of autocross runs, skid pad testing, slalom testing, cold weather testing, corrosion testing, durability testing… well, you get the picture. The result of all our engineering is a coilover system for the 2010 Camaro that combines 2.5 inches of ride height flexibility, 20-clicks of damping adjustment and a long list of technical features which combine to give incredible road holding ability with unmatched ride quality.
In early testing we found an unacceptable amount of deflection in traditional non-inverted front struts. To minimize this deflection we have inverted the front strut and instead of using the shock shaft to carry the cornering loads we now use the large diameter shock body. The shock body’s large diameter is much more capable with dealing with high bending loads from cornering with far less deflection. Once the shock shaft was not subjected to these bending loads its diameter could be reduced and more importantly it’s mass. Camaro Inverted Strut Comparison One other major problem with this bending load on traditional struts is the friction that is induced from the side loading through the shaft. Again, this problem is eliminated with our inverted design. The inverted design in both the front and rear coilover is also responsible for the systems low un-sprung mass which enhances the suspensions ability to follow the contour of the road thus increases traction.
In the figure to the right you can see the differences between a standard strut and our inverted strut. The blue parts are attached to the chassis while the red parts move with the wheel.
Both the front and rear shocks in the Pfadt 2010 Camaro Coilovers utilize a mono-tube, inverted design with a floating piston to separate the shock fluid from the pressurized nitrogen. This arrangement gives our coilovers their relentless consistency from the moment you roll onto the race track to the moment you take the checked flag.
One of the benefits of moving to a coilover system is the ride height flexibility coilovers offer. The Pfadt Camaro Coilovers are no exception with ride height adjustability from factory height to 2.5 inches lower. Below are pictures of the Pfadt 2010 Camaro lowered 2.5 inches. While navigating speed bumps this low does take some time the cars performance around the race track was impressive with the car capable of exceeding 1.3g on factory tires and wheels.
Lowered Camaro on Pfadt Coilovers Lowered Camaro on Pfadt Coilovers Lowered Camaro on Pfadt Coilovers
We understand that the needs of each Camaro owner are different. We have gone to great lengths to engineer our coilovers to be multi-purpose to suit your performance needs while offering superior ride quality. For instance, both the front and rear shocks feature adjustable damping that can be accessed through a large, click knob at the bottom of each coilover. This easy-to-access, 20 click damping adjuster means that you can quickly and easily adjust the dynamics of the car to suit your drive to work, a neck snapping drag launch or the chicane at Laguna Seca.
Another example of the Pfadt Coilover flexibility is the ability to use common motorsport springs in both the front and rear. While many other coilovers on the market demand the use of custom wound springs, which limits you to a limited number of spring rates, our system has hundreds of spring rates available in 25 lb/in increments. We have developed a spring rate combination that will work for most people, but the flexibility is there for those that need it. Standard rates are 275 lbs/in Front and 500 lbs/in Rear.
Part of the reason we can use standard sized race springs is our innovation in mounting the rear coilover. The factory uses a rubber mount for the shock shaft and a separate spring seat which takes a specific spring. Many other companies use this same arrangement and it is the reason spring rates are limited. Our system inverts the rear shock and integrates the shock and spring mount. This allows the use of standard springs and provides a smooth and low friction mounting system.
With all of this adjustability it is easy to get overwhelmed. However, we have recommended starting points for many different conditions to quickly get you dominating the competition and enjoying your commute home from work.
Regular Price $2099
Camaro5 Price $Call, email or PM for coupon info!
JDP Motorsports has a lot of experience with this system so please feel free to call, email or PM me anytime with questions! CALL and order TODAY!!! We appreciate your interest in our products and have a great weekend!
Kind regards,
Jordan Priestley
888.308.6007
JDP Motorsports is offline   Reply With Quote
Old 09-17-2010, 10:43 AM   #2
fastfaster
Drives: xxxxxxxxxxxxxx
is this price for the drag coil overs or the road race coil overs?
fastfaster is offline   Reply With Quote
Old 09-17-2010, 12:28 PM   #3
JDP Motorsports
Hello fastfaster!
This price is for the standard street/road race set up. The Drag Pack coil overs are due to be released in November and the retail price is going to be around $2650. Please feel free to call, email or PM me anytime with questions!
We can also get you set up with some different spring rates to make the current coil over perform very well at the strip so let me know! We appreciate your interest in our products and have a great day!
Kind regards,
Jordan Priestley
888.308.6007
Old 10-08-2010, 01:52 PM   #4
JDP Motorsports
We're still offering great pricing on the ultimate performance coil over package on the market!!! This is the same set up we'll be installing on our 2011 1SS/RS "Silver Shark" build HERE. You're welcome to follow along and see the results of various products and our impressions of there performance.
Please feel free to call, email or PM me anytime with questions! Our www.jdpmotorsports.com site should be live by the end of next week and it will list all of the great products we offer, in the mean time we can take your orders over the phone and we have product in stock!!! We appreciate everyone's support and have a great weekend!!!!
Kind regards,
Jordan Priestley
888.308.6007
Old 10-08-2010, 05:53 PM   #5
JDP Motorsports
PMs replied! Please feel free to call, email or PM me anytime with questions! We appreciate everyone's interest in our products and have a great weekend!
Kind regards,
Jordan Priestley
888.308.6007
Old 10-11-2010, 01:06 PM   #6
JDP Motorsports
All PMs and emails have been replied to! Please feel free to call, email or PM me with questions or for pricing. We appreciate everyone's interest in our products and have a great day!
Kind regards,
Jordan Priestley
888.308.6007
Old 10-26-2010, 10:30 PM   #7
JDP Motorsports
BUMP! All PMs have been replied to! Please call, email, or PM with any questions or pricing info! We appreciate everyone's support and have a great evening!
Kind Regards,
Old 11-11-2010, 04:48 PM   #8
JDP Motorsports
All PMs and email have been replied to! This sale has been extended and the price for Pfadt coilovers is $2099 SHIPPED!!!! If you're on the fence get off!!!
Please feel free to call, email or PM me anytime with questions! We also have all of Pfadt's products in stock and we're offering some great deals!! We appreciate everyone's support and have a great day!
Kind regards,
Jordan Priestley
888.308.6007
Old 11-12-2010, 12:24 PM   #9
JDP Motorsports
All PM's and emails have been replied to! We appreciate everyone's interest in this great offer!! Please feel free to call, email or PM me anytime with questions or for order info! Have a great weekend and thanks again for all of the support!
Kind regards,
Jordan Priestley
888.308.6007
Old 11-15-2010, 11:57 AM   #10
JDP Sales
JDP Sales's Avatar
Drives: Chevys at the limit
Monday BUMP! I hope everybody had a fantastic weekend.
Sincerely,
Rick
Old 11-16-2010, 12:59 PM   #11
JDP Motorsports
All PMs and emails have been replied to!!! This is a great opportunity to get Pfadt's coilovers at an AWESOME price!!! Please call, email or PM me for pricing and order info! We appreciate everyone's support and have a great day!
Kind regards,
Jordan Priestley
888.308.6007
Old 11-22-2010, 11:52 AM   #12
JDP Motorsports
All PMs and emails have been replied to!!! We have the Pfadt Coilovers in stock ready to ship at great prices! Please call, email or PM us for pricing as well as order info! We truly APPRECIATE everyone's support and have a great Thanksgiving!!!!
PS - We're offering HUGE discounts on all of the Performance products we offer this week through next Monday!!! Please call, email or PM us for ANY of your performance parts needs!
THANKS again!
Kind regards,
Jordan Priestley
888.308.6007
Old 11-26-2010, 12:52 PM   #13
JDP Motorsports
Happy Holiday Weekend!!!! We've reduced the Shipped cost of the Pfadt coilovers to $1850 shipped from now until Monday 11/29 at 11:59 PM MST!!!! This opportunity rarely comes up so don't miss your chance to own the best coilovers on the market!!! Please call, email or PM us with questions or for order info! We appreciate everyone's support and have a great weekend!
Kind regards,
Jordan Priestley
888.308.6007
Old 11-27-2010, 01:50 PM   #14
JDP Motorsports
This Sale ends Monday!!! Don't miss your opportunity to get Pfadt Coilovers at an outstanding price!!!! Please call, email or PM me anytime with questions! We appreciate everyone's support and have a great weekend!
Kind regards,
Jordan Priestley
888.308.6007
Camaro Pfadt Race Engineering Coil Overs PfadtRacing Wheels and Tires Talk Sponsored by The Tire Rack 16 03-29-2011 10:10 PM
What VIN is yours? UCF w00t Camaro Price | Ordering | Tracking | Dealers Discussions 346 03-29-2010 06:55 PM
Tom Henry Racing Announces a Special Edition 2010 Camaro! TAG UR IT 5th Gen Camaro SS LS LT General Discussions 72 04-30-2009 01:57 PM
