Elite Engineering
Old 09-10-2010, 02:30 PM   #1
ACS Composite
ACS Composite's Avatar
Drives: 2010 Camaro
Specter Werkes Camaro GTZ Extractor Hood
The Specter GTZ Camaro heat extractor hood not only adds an aggressive look, it also releases high pressure air and heat from the engine bay while negating front end lift. Hood design is understated, yet extremely functional, stock height is retained not to inhibit driver’s visibility.
Built using ACS’s proprietary RTM process (Resin Transfer Molding) it is injected using continuous glass mat and a specially formulated vinyl-ester resin to meet strict durability standards. Hood inner is trimmed using a precision CNC water jet cutter while the panels are bonded using OE spec adhesive. The GTZ hood is then hand finished ready for final prep. Reinforced hardware is incorporated in the design for safety and warrant a perfect fit on any 2010+ Camaro.
The Specter Werkes GTZ hood is a direct bolt on and includes all necessary hardware including grill screen and bezel for easy installation.
Hood is in production and initial shipments will be available in the coming weeks.
Swap your hood and improve the performance of your Camaro !
ACS Composite is offline
Old 09-10-2010, 03:25 PM   #2
alssiri
alssiri's Avatar
Drives: 2012 ZL1 A6
Nice looking hood
Ahmad
2012 ZL1 A6
Forged 376 CI, LSA HeartBeat, Mast Medium Bore Heads & JDP ZLR Cam, ARH LT , MagnaFlow Resonated X + Corsa Sport Catback, ADM 102mm Snout, CAI, NW 102mm TB, ID850, AGP Dual Fuel Pump, MSD Wire's, Moroso CC.
Alky Control, FIICHILLER.
2015 Rear Fascia Conversion, Z/28 Side Skirts, Flares, Spoiler & Diffuser , ACS Quarter Ports, ShowStopper's Side Marker's, LightWurkz Halo's.
Sosche With KenWood, SLP pod with PLX guage, DashLogic .
alssiri is offline
Old 09-11-2010, 02:47 AM   #3
SS22
SS22's Avatar
Drives: 2010 Blue Camaro RS
That bumper looks really good.
SS22 is offline
Old 09-11-2010, 07:54 AM   #4
NinoSS
Drives: 2SS/RS CGM LS3
I want those bumper inserts!
SOLD Vengeance stage I cam (442rwhp/412rwtq) / CAI intake w/ADM race scoop / Dynatech LT's / ATI udp / JRE tuned / Eaton Posi LPE-JRE 3.91's / L99 Corsa / Whiteline Sways & Bushings / UMI Trailing Arms & Toe Rods / ZL1 wheels / NT05 275/315
NinoSS is offline
Old 09-11-2010, 09:00 AM   #5
Bourgui
Bourgui's Avatar
Drives: 1LT/RS, VR, GFX
Looks really nice!
Do you have temperature readings with and without the hood? Just curious...
Bourgui is offline
Old 09-11-2010, 10:15 AM   #6
ACS Composite
Drives: 2010 Camaro
Originally Posted by Bourgui View Post
Looks really nice!
We will have some numbers in a few weeks, currently logging data. Rest assured it drops the temps quite a bit.
Designer has been involved in various race programs, design was purpose built
Old 09-11-2010, 10:51 AM   #7
rodjonathanss
rodjonathanss's Avatar
Drives: 2014 Black 2SS/RS
lookin good i love that bumper too
rodjonathanss is offline
Old 09-11-2010, 10:55 AM   #8
mcotton
mcotton's Avatar
Drives: 2010 Camaro
Love it.
mcotton is offline
Old 09-11-2010, 10:59 AM   #9
Looks awesome
2010 SSRS is offline
Old 09-11-2010, 11:09 AM   #10
Hylton
Hylton's Avatar
Drives: fanboys and ass kissers crazy.
I like this hood Joe. Does it have drain channels?
Hylton is offline
Old 09-11-2010, 11:30 AM   #11
ACS Composite
Drives: 2010 Camaro
Specter designed the hood for cooling and to reduce high speed lifting, adding a water management system would have reduced its efficiency.
The extractor is located very forward in the engine bay, any water entering the opening is hitting the radiator support brace, so no issues of water damage.
I have had a prototype hood on my car for quite some time... no issues whatsoever.
Old 09-11-2010, 11:34 AM   #12
Hylton
Hylton's Avatar
Will it clear an I-Force set-up?
Hylton is offline
Old 09-11-2010, 11:41 AM   #13
ACS Composite
Drives: 2010 Camaro
You mean the E-force from Edlebrock ?
I'll have to check, i think they have a different intake tube layout.... Any local Camaro forum members willing to come in for a test fit ;-)
Old 09-11-2010, 12:29 PM   #14
MyIBMssRS
Drives: 10 IBM SS RS/12 RAV4
Ditto the Maggie?
That's a really great looking hood.
MyIBMssRS is offline
camaro hood
5th Gen Suspension -- The Book JusticePete Suspension / Brakes / Chassis 151 05-07-2015 05:52 PM
PEDDERS SUCCESSFULLY FITS 305s ON ALL 4 CORNERS! Info@PeddersUSA.com Suspension / Brakes / Chassis 467 06-11-2013 09:45 PM
The DEFINITIVE EXPLANATION OF CAMARO SUSPENSION, ISSUES, AND UPGRADES Info@PeddersUSA.com Suspension / Brakes / Chassis 106 10-19-2009 06:08 PM
