Caryle Racing
Old 09-11-2010, 12:48 PM   #1
Merc
In The Circle
Merc's Avatar
TCI Line Lock
Tried to install TCI line lock yesterday. TCI has an issue with the fitting between the selinoid and the stock brake line fitting. Leaks big time. Called there tech line not much help. They say it's all good. Be warned it is not!
Old 09-11-2010, 01:35 PM   #2
Andro
NOICE!!! ™
Andro's Avatar
Drives: Force Fed 427
Went with SJM's line lock kit no problems here
Old 09-11-2010, 02:23 PM   #3
Merc
In The Circle
Merc's Avatar
Too late for that now. TCI has been around for a while and make good stuff generally. The issue is the connection of the stock line to the weather head fitting supplied with the kit. It apears the the threads don't go deep enough to seat the flare. Were working on a solution.
Old 09-11-2010, 05:05 PM   #4
flyby
Drives: 2010 Silver SS
Yeah, SJM works perfectly, no leaks no problems.
flyby is offline   Reply With Quote
Old 09-12-2010, 11:06 AM   #5
Merc
In The Circle
Merc's Avatar
up up
Old 09-13-2010, 10:30 AM   #6
Merc
In The Circle
Merc's Avatar
Looked at SJM. Went with TCI cause it was less noticable under the master cylinder. The issue is the brass weatherhead fitting they supply. Going to talk to TCI tech dept. this morning. Had to post the issues so nobody else will be in the same dilemma that I am in.
Old 09-13-2010, 02:50 PM   #7
Merc
In The Circle
Merc's Avatar
TCI is working with me to resolve the issue. Nobody has said they have used a TCI line lock. TCI claims they have sold 287 units. Come on somebody speak up.
DIY Brake Calipers Rotors and Line Removal Gotthat02fire Camaro DIY & HOW-TO instructions & discussions 31 02-14-2012 07:52 PM
2nd Gen. Line Lock Kit carsismeZ06 1st & 2nd Generation Camaros 2 05-29-2010 12:58 PM
2010 Camaro Line Lock Kit? Windy City Wheels and Tires Talk Sponsored by The Tire Rack 15 11-09-2009 11:05 PM
# of Cars on Line...? carguy 5th Gen Camaro SS LS LT General Discussions 6 06-09-2009 12:32 PM
