09-11-2010, 01:08 PM | #1 |
3.73 gear in 2SS
Hello to all, I am new here. I am looking to upgrade the gear on my 2SS automatic from stock 3.27 to 3.73. Has anyone done this and how much did it end up costing you? Right now I'm looking at something between $1700 and $2K for parts and labor. Also, has anyone done this and how big of a difference do you see? Thanks
09-11-2010, 01:27 PM | #2 |
Drives: 2010 Camaro Join Date: Feb 2010
Yes, a lot of guys have done this with no complaints. Price installed is about $1500 installed (ballpark). Gears and install kit are near 8 and figure 6-8 for install. Do it and don't look back!!
09-11-2010, 02:41 PM | #3 |
Drives: 2010 Camaro 2SS/RS Join Date: Mar 2008
I believe you will need a tune for gears in an L99?
When I put gears in my 99Z28 Auto, I had mine tuned to adjust speedo and shift points. |
09-11-2010, 03:15 PM | #4 |
BAMF SS
as mentioned before... ballpark figure 1500... MAX. if they are going to charge you damn near 2,000... they are raping you for labor costs.
You will need a tune afterwards to change your speedo and shift points.
2016 1SS A8: FBO + Circle D + P1X + Meth + Tuned by Pray Performance
Stock Longblock 800 SAE rwhp. 9.4 @ 145 mph. |
09-11-2010, 04:45 PM | #5 | |
09-11-2010, 05:47 PM | #6 |
Thanks guys! I checked with 2 shops in my area and they both said the labor would be $800-$1000 plus all the parts. One shop discouraged me from upgrading to a 3.73. He said I'd be spinning the tires too much and I wouldn't go anywhere. This is hard to believe on an automatic that can barely spin the tires as it is with traction control off. I will need to first find a reputable shop that I can trust then work on the numbers a bit more.
I really want to replace the gear and get more torque at the wheels. I like to hear those tires squeal a bit more when I floor it. I also knew about the speedo tuning but didn't think of shift points. I guess it makes sense. Apex, thanks for the offer, I will keep it in mind when I'm ready to go forward. |
09-11-2010, 05:54 PM | #7 |
I don't think you need to change the shifts points. I mean for optimum performance, yes, you'll prob want to tweak them, but not required with a gear swap. The car will still shifts as is, which is fine, you'll just get to that specific rpm a little quicker. Just recal on the speedo is all that is "required" and even then its not a huge deal. You can get the formula and do the math in your head so you know what youre real doing and never touch the computers.
And those install prices are a bit on the high side. |
09-11-2010, 06:07 PM | #8 | |
Yeah, I'm not sure how much 3:73s will throw off the speedo. I don't think its all that much. |
09-11-2010, 06:14 PM | #9 |
I'm going with the 4.10's when have gears put in my L99.
09-11-2010, 06:18 PM | #10 |
09-11-2010, 06:25 PM | #11 |
Not sure how much off, but definitely will probably be way off, I'm having Jannetty Racing do mine and Ted said it will be all tuned to the correct mph.
09-11-2010, 06:35 PM | #12 | |
There is a formula out there floating around. I remember using it when doing gear swaps in my trucks back when there wasn't computer calibrated speedos, just the good ole plastic speedo gear. If someone smart doesn't chime in I would try some 4 x 4 sites. |
09-11-2010, 06:36 PM | #13 |
Lets try this:
http://www.csgnetwork.com/rgpspeedcalc.html Looks like at if you did the 3.27 to a 3.73 your actual speed is 52.6 but the speedo would read 60. Hope this helps. |
09-11-2010, 06:47 PM | #14 |
He obviously has no experience with these cars. I'd mark him off the list.
Similar Threads | ||||
2SS stock gear set 3:27 | vinnyr | Transmission / Driveline | 1 | 09-10-2011 06:54 PM |
Remaining 2010 2SS / RS Camaro's w/ Ground Effects and wheels SAVE $$$ | Cornhusker Callaway | Dealer Camaros for Sale | 1 | 07-02-2010 03:30 PM |
Rear end gear 3.73 - where to buy? | rpepka | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 67 | 09-17-2009 05:23 PM |
Do you think it was right that the mustang got to use the trackpack in the comparison | perfxn | Chevy Camaro vs... | 91 | 03-30-2009 09:44 PM |
blew second gear. | carguy_z28 | 4th Generation Camaros | 5 | 09-17-2008 11:14 PM |
