Gen5DIY
Old 09-11-2010, 06:09 PM   #1
blackonblacksls
Drives: 2011 2ss/rs
tr6060 has a transmission cooler?
Had the radiator out the other night and noticed that there was a tranny cooler setup in my 2011 2ss camaro..
Thought that was kinda crazy..
Is it like this on all the tr6060 cars?
blackonblacksls is offline   Reply With Quote
Old 09-12-2010, 12:45 AM   #2
3min3m2
3min3m2's Avatar
Drives: 2011 2SS/RS SIM L-99
I would assume so. Might be there to heat it in winter?
3rd Time is the charm
2012 2SS/RS VR 6M.
Borla S type, Volant CAI.
3min3m2 is offline   Reply With Quote
Old 09-12-2010, 02:08 AM   #3
boostedyards86
boostedyards86's Avatar
Drives: Cummins 3500
this has been discussed in a previous thream iirc.
85 Buick TType - 5.3l GT4202r 10.86 at 126
boostedyards86 is offline   Reply With Quote
Old 09-12-2010, 07:57 AM   #4
ArkySS
Camaroless for now...
ArkySS's Avatar
Drives: 2014 Blue Topaz Silverado
Would like to see pics of that because the 2010's do not have them and doubt they changed for 2011?
It was fun while it lasted.....
ArkySS is offline   Reply With Quote
Old 09-12-2010, 10:02 AM   #5
camaro1
camaro1's Avatar
Drives: 550+RWHP 2010 camaro
2010 manual trans cars have a trans cooler just like the auto's,, and you have a power steering cooler also in the bottom 3 rows of the a/c condenser.
Old 09-12-2010, 10:13 AM   #6
blackonblacksls
Drives: 2011 2ss/rs
So i guess this confirms the 6060s have some kind of internal pump?
here goes the pic of my radiator.
Old 09-12-2010, 10:28 AM   #7
camaro1
camaro1's Avatar
yes, the manual trans has a fluid pump built into the front of the trans,
Old 09-12-2010, 04:41 PM   #8
ArkySS
ArkySS's Avatar
I was referring to an auxiliary cooler. If you have an aftermarket TC (most of them anyway) you need a separate cooler.
Old 09-12-2010, 05:25 PM   #9
danhr
BAMF SS
danhr's Avatar
Drives: 2016 Camaro 1SS A8
Send a message via AIM to danhr
so since the transmission cooler is connected to the a/c condensor, it is not considered a cooler anymore?
danhr is online now   Reply With Quote
Old 09-12-2010, 07:03 PM   #10
blackonblacksls
Drives: 2011 2ss/rs
This is talking about sixspeed cars.
Old 09-12-2010, 09:20 PM   #11
danhr
BAMF SS
danhr's Avatar
Even the automatic cars have transmission coolers from the factory
Old 09-12-2010, 10:23 PM   #12
camaro1
camaro1's Avatar
the trans cooler is in the bottom of the radiator,, the cooler built into the bottom of the a/c condenser is a power steering fluid cooler(many people think this cooler is an aux cooler for the trans because if you take the lines off, the fluid is red,, this is because the power steering in the new camaro uses the dexron 6 atf fluid for the power steering system) ,, follow the lines,, you will see it is a p/s cooler
Old 09-12-2010, 10:37 PM   #13
blackonblacksls
Drives: 2011 2ss/rs
Yes, but the point was, this is the only thing I have ever seen with a transmission cooler for manual.
Old 09-13-2010, 07:45 AM   #14
ArkySS
ArkySS's Avatar
DOH..I'm an idiot......TR6060 is not 6L80...helps if you actually read the posts...sorry gang.
